This page is also available in Markdown, which may be easier for automated readers and AI tools to parse than HTML. The Markdown version is available at https://grafana.com/docs/grafana-cloud/observe-and-act/adaptive-telemetry/adaptive-metrics.md, or by sending Accept: text/markdown to https://grafana.com/docs/grafana-cloud/observe-and-act/adaptive-telemetry/adaptive-metrics/. For broader documentation discovery, the curated index is available at https://grafana.com/llms.txt and the complete index is available at https://grafana.com/llms-full.txt.
Adaptive Metrics
Overview
Grafana Adaptive Metrics helps you take control of your growing metric volume and associated costs in Grafana Cloud.
By analyzing how your metrics are being used across dashboards, alerts, recording rules and queries, it provides recommendations for aggregating underutilized metrics into lower-cardinality versions. It then continuously reanalyzes your usage, updating its recommendations to reflect changes in your observability needs.
Why use Adaptive Metrics?
- Get automatic recommendations based on how you actually use your metrics in Grafana, helping you identify and reduce unused data.
- Apply, remove, or adjust rules with ease through an interactive interface or automate with the API within your existing processes.
- Your existing dashboards, alerts, and queries continue to work seamlessly with the aggregated metrics, requiring no manual updates.
Explore
Was this page helpful?
