title: "Logs with Firehose | Grafana Cloud documentation"
description: "Overview of Logs with Amazon Data Firehose for AWS"
# Logs with Amazon Data Firehose
You can stream logs from AWS to Grafana Cloud using Cloud Provider Observability and Amazon Data Firehose. Sending AWS logs with Lambda Promtail covers many use cases. However, if you have growing log volumes or have large-scale logs, sending AWS logs with Data Firehose is more scalable and almost three times cheaper.
## How it works
[Amazon Data Firehose](https://aws.amazon.com/kinesis/data-firehose/) is a fully managed service for delivering real-time streaming data to a destination, such as any custom HTTP endpoint. Data Firehose acts as a stream that allows you to:
- Send data into it.
- Configure transformations.
- Pick a destination where the data is to be delivered (such as an HTTP endpoint, S3 bucket, and so on).
The [Data Firehose delivery stream](https://docs.aws.amazon.com/firehose/latest/dev/what-is-this-service.html) can batch and send ingested records to Grafana Cloud.
You can configure multiple AWS resources to send events to Data Firehose, including:
- Amazon CloudWatch logs through [subscription filters](https://docs.aws.amazon.com/AmazonCloudWatch/latest/logs/SubscriptionFilters.html#FirehoseExample)
- [VPC flow logs](https://docs.aws.amazon.com/firehose/latest/dev/vpc-splunk-tutorial.html)
- [AWS CloudTrail logs](https://docs.aws.amazon.com/awscloudtrail/latest/userguide/send-cloudtrail-events-to-cloudwatch-logs.html)
Other services can also deliver logs data directly to Data Firehose, including [AWS Web Application Firewall](https://docs.aws.amazon.com/waf/latest/developerguide/logging-kinesis.html), [Amazon Route 53 Resolver Query Logs](https://aws.amazon.com/blogs/aws/log-your-vpc-dns-queries-with-route-53-resolver-query-logs/), and [Amazon VPC Flow](https://aws.amazon.com/blogs/networking-and-content-delivery/introducing-amazon-vpc-flow-logs-kinesis-data-firehose/).
[Logs with Data Firehose process](/media/docs/grafana-cloud/aws/AWS-firehose.png)
You can also back up events to an S3 bucket to help prevent data loss for either all log events or only those having a failed delivery and exceeding a specified retry duration. For more information about adjusting your backup based on the amount of log data you’re streaming, refer to [Amazon Data Firehose Quota](https://docs.aws.amazon.com/firehose/latest/dev/limits.html).
## Maximum payload send/receive size
The maximum send/receive size of Data Firehose logs is 5 MiB.
> Caution
> Requests coming from Data Firehose that have a payload size above the 5 MiB limit fail with a 502 HTTP status code.
