This page is also available in Markdown, which may be easier for automated readers and AI tools to parse than HTML. The Markdown version is available at https://grafana.com/docs/grafana-cloud/monitor-infrastructure/monitor-cloud-provider.md, or by sending Accept: text/markdown to https://grafana.com/docs/grafana-cloud/monitor-infrastructure/monitor-cloud-provider/. For broader documentation discovery, the curated index is available at https://grafana.com/llms.txt and the complete index is available at https://grafana.com/llms-full.txt.
Cloud Provider Observability
Overview
When you monitor and troubleshoot your cloud environment, you need different tools for each provider. This can raise costs and interfere with workflow and efficiency, not to mention a longer time to find and resolve issues. Cloud Provider Observability offers:
- Straightforward setup
- Instantaneous service discovery after setup
- Preconfigured views for your data, including dedicated logs for each provider
- Machine learning-powered predictions for proactive capacity planning and resource optimization
- Seamless scaling
Note
Cloud Provider Observability doesn’t support AWS PrivateLink or Azure Private Link.
Explore
Was this page helpful?
