This page is also available in Markdown, which may be easier for automated readers and AI tools to parse than HTML. The Markdown version is available at https://grafana.com/docs/grafana-cloud/observe-and-act/monitor-infrastructure/kubernetes-monitoring/triage-your-infrastructure/review-infrastructure-conditions.md, or by sending Accept: text/markdown to https://grafana.com/docs/grafana-cloud/observe-and-act/monitor-infrastructure/kubernetes-monitoring/triage-your-infrastructure/review-infrastructure-conditions/. For broader documentation discovery, the curated index is available at https://grafana.com/llms.txt and the complete index is available at https://grafana.com/llms-full.txt.
Review infrastructure conditions
The Infrastructure section on Kubernetes Overview surfaces platform conditions, the layer below your workloads. When this section lights up, workload symptoms in Stability usually follow.
An infrastructure check identifies:
- Nodes under resource pressure
- Pods that have been evicted or lost contact with the Cluster
Click View detail on any tile to see the affected items listed under Detail view at the bottom of the page.
Node pressure
The Node pressure tile in the Infrastructure section of Kubernetes Overview shows Nodes with an active MemoryPressure, DiskPressure, or PIDPressure condition. These are early warning signals for Pod evictions or failures. Detail view lists each active condition separately.
The app reads these conditions from kube-state-metrics or the OpenTelemetry Kubernetes Cluster Receiver (k8s_cluster). If you configure node_conditions_to_report, your list replaces the default [Ready]. Include Ready alongside MemoryPressure, DiskPressure, and PIDPressure so the receiver supplies metrics for both the Nodes not ready and Node pressure tiles.
Evicted Pods
The Evicted pods tile lists Pods whose status reason is Evicted. The kubelet can set this reason when it evicts a Pod to free resources on a Node.
To see evictions with the OpenTelemetry Kubernetes Cluster Receiver, enable its k8s.pod.status_reason metric.
Resolve the underlying Node pressure or redistribute workloads across Nodes. To influence which Pods the kubelet evicts first, adjust Pod priority classes.
If you suspect the scheduler removed a Pod to make room for a higher-priority Pod, check the Pod’s DisruptionTarget condition for PreemptionByScheduler.
Pods in unknown phase
The Pods unknown phase tile lists Pods that kube-state-metrics or the OpenTelemetry Kubernetes Cluster Receiver reports in the Unknown phase. This typically occurs when the Node hosting the Pod becomes unreachable and Kubernetes can no longer determine the Pod’s state.
Unknown Pods transition to Failed or recover once Node connectivity is restored.Nodes that cannot be scheduled
The Unschedulable nodes tile lists cordoned Nodes (spec.unschedulable: true). This check requires the kube_node_spec_unschedulable metric from kube-state-metrics. If Nodes stay cordoned for long periods, effective Cluster capacity shrinks. New Pods can stay pending or increase the load on the remaining Nodes.
Identify who or what cordoned the Node and confirm whether the maintenance window is still active. If a drain stalled, complete or cancel it. Uncordon the Node when you’re ready to return it to service.
If a Pod can’t be scheduled on an uncordoned Node, review the Node’s taints and conditions. A NoSchedule or NoExecute taint blocks new Pods that don’t tolerate it.
- An operator or controller can use a taint to reserve GPU Nodes or dedicate Nodes to particular workloads. Remove the taint if that restriction is no longer needed.
- If
MemoryPressure,DiskPressure, orPIDPressuretriggered an automatic taint, resolve the underlying Node pressure.
Was this page helpful?
