title: "Review infrastructure conditions | Grafana Cloud documentation"
description: "An infrastructure check identifies Nodes under resource pressure and Pods that have been evicted or lost contact with the Cluster."
# Review infrastructure conditions
The **Infrastructure** section on **Kubernetes Overview** surfaces platform conditions, the layer below your workloads. When this section lights up, workload symptoms in **Stability** usually follow.
An infrastructure check identifies:
- Nodes under resource pressure
- Pods that have been evicted or lost contact with the Cluster
[Infrastructure panels on **Kubernetes Overview** home page](/media/docs/grafana-cloud/k8s/infrastructure.png)
Click **View detail** on any tile to see the affected items listed under **Detail view** at the bottom of the page.
## Node pressure
These are Nodes with an active `MemoryPressure`, `DiskPressure`, or `PIDPressure` condition. These are early warning signals for Pod evictions or failures.
Potential causesSuggested actions
Potential causes Suggested actions
High memory consumption on the Node, low available disk space or inodes, or too many running processes exhausting available PIDs.
Free up Node resources by evicting or rescheduling non-critical workloads, expand disk capacity, or increase the PID limit. Address these before they cause Pod evictions or failures.
## Evicted Pods
These are Pods evicted by the `kubelet` due to Node resource pressure or by the scheduler due to priority preemption.
Node memory, disk, or PID pressure; priority preemption by higher-priority Pods.
Resolve the underlying Node pressure (refer to Node pressure above), adjust Pod priority classes, or redistribute workloads across Nodes.
## Pods in unknown phase
These are Pods in the `Unknown` phase. This typically occurs when the Node hosting the Pod becomes unreachable and Kubernetes can no longer determine the Pod’s state.
Node failure or severe network partition between the Node and the control plane.
Check Node status and network connectivity. Restart the Node or restore network access. `Unknown` Pods transition to `Failed` or recover once Node connectivity is restored.
## Nodes that cannot be scheduled
These are Nodes that have been cordoned or tainted to block new Pod placement, usually during maintenance or drains. If Nodes cannot be scheduled for long periods, effective Cluster capacity shrinks and Pods can stay pending or concentrate load on the remaining Nodes.
A manual cordon for maintenance or upgrade, an in-progress or abandoned drain, a `NoSchedule` or `NoExecute` taint added by an operator or controller (for example, GPU or dedicated workload Nodes), the cluster autoscaler marking a Node before scale-down, or automatic taints triggered by `MemoryPressure`, `DiskPressure`, or `PIDPressure`.
Identify who or what cordoned the Node and confirm the maintenance window is still active. Review the Node’s taints and conditions, then uncordon the Node, remove the offending taint, or resolve the underlying pressure condition (refer to Node pressure above). If a drain stalled, complete or cancel it.
