This page is also available in Markdown, which may be easier for automated readers and AI tools to parse than HTML. The Markdown version is available at https://grafana.com/docs/grafana-cloud/monitor-infrastructure/kubernetes-monitoring/triage-your-infrastructure/network-saturation.md, or by sending Accept: text/markdown to https://grafana.com/docs/grafana-cloud/monitor-infrastructure/kubernetes-monitoring/triage-your-infrastructure/network-saturation/. For broader documentation discovery, the curated index is available at https://grafana.com/llms.txt and the complete index is available at https://grafana.com/llms-full.txt.
Application latency due to network saturation
When an application has high latency, look for network saturation if you have already:
- Found no OOM killing or CPU throttling
- Increased CPU and memory
The limitation of bandwidth for an application can cause dropped packets.
Navigate to the Network tab to view bandwidth and saturation.
Bandwidth limits and saturation
In the following example, these graphs shows an approximate 6-hour time period for a Cluster.
The Network Bandwidth by node graph indicates a harmonic effect resembling a straight line. The peaks do not extend beyond 2 GiB/s, perhaps because the network interfaces of those nodes are at bandwidth capacity.
The Network Saturation by node graph shows many spikes on the receive side (upper half), indicating saturation and dropped packets. This can lead to request queueing, packet retries, and increased response latencies as a result.
A normal set of graphs for an approximate six-hour period shows no harmonic effect for bandwidth and little activity for saturation.
Resolution for network saturation
To increase bandwidth and eliminate saturation, increase the number of Nodes where the application is deployed. You can then recheck the Network tab to see the results.
Was this page helpful?
