Manage stability
The Stability section on Kubernetes Overview catches workloads that haven’t stopped serving traffic yet but are showing stress that will likely cause outages if you ignore them.
A stability check detects containers and Pods that are crashing, restarting, or stuck.
Stability panels on **Kubernetes Overview** home page
Stability panels on Kubernetes Overview home page
Click View detail on any tile to see the affected items listed under Detail view at the bottom of the page.
Restarting containers
The Restarting containers tile in the Stability section of Kubernetes Overview uses the last hour of restart data.
  • If kube-state-metrics reports a container’s restart count, the container appears after more than two restarts in that hour.
  • If only the OpenTelemetry Kubernetes Cluster Receiver (k8s_cluster) reports the count, the container appears when the reported count increases over the hour. A reset can hide earlier restarts.
Click View detail to see the affected containers, sorted by highest reported restart count. A high restart count typically signals a crash loop.
OOM kills, failed liveness probes, or application errors.
Inspect Pod logs and events to determine why the container is crashing. Adjust resource limits, correct the liveness probe configuration, or fix the underlying application error.
OOMKilled containers
The OOMKilled containers tile counts containers whose most recent termination reason was OOMKilled, even after they restart. The app reads that reason from kube-state-metrics or the OpenTelemetry Kubernetes Cluster Receiver.
In Detail view, a container can appear even when its workload is unknown. If both sources report the same container, the table can show two rows for it.
The container exceeded its memory limit, or the Node ran out of memory.
Increase memory limits or requests for the affected container. If the Node is under memory pressure, consider scaling up or redistributing workloads.
Pending Pods
The Pending pods tile counts Pods in the Pending phase using data from kube-state-metrics or the OpenTelemetry Kubernetes Cluster Receiver. A Pod can be waiting for a Node assignment or already scheduled on a Node and waiting for a container image to download.
Insufficient cluster resources, unsatisfiable Node affinity or taints, missing PersistentVolumes, or image pull failures.
Scale up the cluster or free resources, adjust Node affinity rules or taints, provision the required PersistentVolumes, or fix image references.
Image pull errors
These are containers waiting because their image cannot be pulled. ImagePullBackOff means Kubernetes is retrying with exponential backoff. ErrImagePull is the initial failure.
The OpenTelemetry Kubernetes Cluster Receiver reports image pull errors for regular containers. To see image pull errors for init containers, collect the kube_pod_init_container_status_waiting_reason metric from kube-state-metrics.
Incorrect image names or tags, missing or expired registry credentials, or rate limiting by the registry.
Verify the image name and tag, update or create registry pull secrets, or wait for rate limits to reset and consider authenticating to increase limits.
