This page is also available in Markdown, which may be easier for automated readers and AI tools to parse than HTML. The Markdown version is available at https://grafana.com/docs/grafana-cloud/observe-and-act/monitor-infrastructure/kubernetes-monitoring/triage-your-infrastructure/manage-availability.md, or by sending Accept: text/markdown to https://grafana.com/docs/grafana-cloud/observe-and-act/monitor-infrastructure/kubernetes-monitoring/triage-your-infrastructure/manage-availability/. For broader documentation discovery, the curated index is available at https://grafana.com/llms.txt and the complete index is available at https://grafana.com/llms-full.txt.
Manage availability
The Availability section on Kubernetes Overview answers one question: is your infrastructure currently able to serve user traffic? It flags things that exist on paper but aren’t actually available.
Availability checks identify workloads and nodes that are down or unable to serve traffic.
Click View detail on any tile to see the affected items listed under Detail view at the bottom of the page.
Zero replica deployments
These are deployments that are configured to run at least one replica but have zero available replicas running.
The workload is fully down.
This excludes deployments intentionally scaled to zero. If you use the OpenTelemetry Kubernetes Cluster Receiver (k8s_cluster), this check compares the k8s.deployment.desired and k8s.deployment.available metrics.
Deployment rollout issues
These are deployments whose rollout has one of these conditions:
Not Progressingmeans the deployment controller has not made progress within the deadline.Replica Failuremeans at least one replica Pod could not be created or deleted.
This check requires the kube_deployment_status_condition metric from kube-state-metrics.
Nodes not ready
The Nodes not ready tile in the Availability section of Kubernetes Overview counts Nodes whose Ready condition is False or Unknown. The app reads this condition from kube-state-metrics or the OpenTelemetry Kubernetes Cluster Receiver. A NotReady node prevents new Pods from being scheduled and may disrupt running workloads.
Select View detail to see the affected Nodes in Detail view. The Status column distinguishes a confirmed NotReady state from a transient Unknown state (meaning the node is unreachable).
kubelet crash or failure to report status, Node running out of memory, disk, or Process IDs (PIDs), network connectivity loss between the Node and the control plane, underlying VM or hardware failure, expired Node certificates, kernel or OS-level crash.kubelet logs and Node events. Restart the kubelet, free up Node resources, restore network connectivity, renew certificates, or replace the failed Node.Pods not ready
The Pods not ready tile counts Pods in the Running phase that are not ready. Kubernetes Services normally send traffic only to ready Pods.
- With kube-state-metrics, the app uses the Pod’s
Readycondition, which includes any readiness gates you configured. - With the OpenTelemetry Kubernetes Cluster Receiver, the app lists a running Pod when at least one of its containers reports that it is not ready.
Was this page helpful?
