title: "Find usage spikes | Grafana Cloud documentation"
description: "Find CPU and memory usage spikes across your Kubernetes fleet from the Kubernetes Overview page in Grafana Kubernetes Monitoring, then drill into the affected Cluster."
# Find usage spikes
The CPU and memory usage panels on the Overview page show spikes across your fleet at a glance and let you jump directly to the affected Cluster.
[CPU and memory usage panels on **Kubernetes Overview** page](/media/docs/grafana-cloud/k8s/cpu-mem-cluster-panels.png)
Use the time range selector to focus on a time period while looking for patterns or spikes in CPU and memory usage in your Clusters. When spikes occur:
1. Zoom in on the graph to narrow the time selection.
   [Zooming in on graph to change time range](/media/docs/grafana-cloud/k8s/zoom-graph.png)
2. Hover over and click the peak of the spike to see the percentage of use compared to capacity. In the following example, the spike shows 46.5% of CPU usage compared to capacity.
   [Hovering over spike to show Cluster link](/media/docs/grafana-cloud/k8s/spike-cluster-link.png)
3. Click the **View** link to view the Cluster. The Cluster detail page shows the time range you set when zooming in on the graph.
   [Cluster detail page](/media/docs/grafana-cloud/k8s/detail-cluster-page.png)
   You can continue by sorting the list of Nodes in this Cluster by highest CPU usage to investigate the issue causing the spike.
