title: "Respond to alerts | Grafana Cloud documentation"
description: "How to respond to and manage Kubernetes-specific alerts in Grafana Kubernetes Monitoring"
# Respond to alerts
Respond to and troubleshoot alerts about your infrastructure and the applications running within it without leaving the context of Grafana Kubernetes Monitoring.
## Start from snapshot on home page
Within the alerts section of the **Kubernetes Overview** page, two panels show container and Pod alerts. You can click directly into the container or Pod to continue your troubleshooting and problem solving.
[Jumping to container detail page from a container alert](/media/docs/grafana-cloud/k8s/navigate-to-container-from-alert.png)
## Start from Alerts page
The **Alerts** page in Kubernetes Monitoring displays all alerts related exclusively to your Kubernetes infrastructure and any applications within your infrastructure. The graphs at the top of the page show the alerts by Cluster and namespace, as well as the alert severity rating.
[Alert graphs for all alerts by Cluster, namespace, and alert severity for the last three hours](/media/docs/grafana-cloud/k8s/alert-graphs.png)
Use filtering to find alerts by:
- Cluster
- Namespace
- Severity of alert
- Name of alert
  [Filtered for all warning alerts for the last three hours](/media/docs/grafana-cloud/k8s/filtered-alerts.png)
With Grafana Play, you can explore and see how it works, learning from practical examples to accelerate your development. This feature can be seen on [the **Alerts** page](https://play.grafana.org/a/grafana-k8s-app/alerts?from=now-24h&to=now&refresh=1m&var-cluster=%24__all&var-node=%24__all&var-namespace=%24__all&var-severity=%24__all&var-alertname=%24__all&timezone=utc).
[Try it](https://play.grafana.org/a/grafana-k8s-app/alerts?from=now-24h&to=now&refresh=1m&var-cluster=%24__all&var-node=%24__all&var-namespace=%24__all&var-severity=%24__all&var-alertname=%24__all&timezone=utc)
The list of **Firing Alerts** reflects the filters at the top of the page. Additionally, you can filter further within the list to isolate a Cluster, namespace, workload, Pod, or container.
[Warning alerts filtered for one Cluster for the last three hours](/media/docs/grafana-cloud/k8s/filtered-alerts-graph-and-list.png)
With one click, you can open the alert rule itself, or the details page for the Cluster, namespace, workload, Pod, or container.
[Navigating from alert to alert rule or to Container details page](/media/docs/grafana-cloud/k8s/alerts-click-through.png)
> Note
> If you open the alert rule, the page loads in a another tab.
## Use the runbooks
From the **Alerts** page or the **Kubernetes Overview** page, click the alert name to navigate to the runbook for more information.
1. Click the name of the alert to open the **Alert rules** page for that alert.
2. Expand the **Firing** state.
3. Click **View runbook** to open to the alert in the [kubernetes-mixin](https://github.com/kubernetes-monitoring/kubernetes-mixin/blob/master/runbook.md#kubernetes-alert-runbooks).
4. Click **Link** to view the specific runbook at [kube-prometheus runbooks](https://runbooks.prometheus-operator.dev/).
   [Navigating to the runbook](/media/docs/grafana-cloud/k8s/runbook-path.gif)
## Manage alerts
Preconfigured [alerting rules](/docs/grafana-cloud/monitor-infrastructure/kubernetes-monitoring/configuration/manage-configuration/#alerting-rules) are available out of the box.
There are two ways to open an alert rule to open the Alert page in a new browser tab:
- In the **Alerts** page in the list of **Firing Alerts**, click the name of the alert.
  [Opening alert rule from Alerts page](/media/docs/grafana-cloud/k8s/nav-alert-rule.png)
- In a Cluster, namespace, Node, Pod, or container list, click the underlined number next to the list item.
  [Opening alert rule from list item](/media/docs/grafana-cloud/k8s/click-alert-number.gif)
For details on alert rules, refer to [Configure alerting](/docs/grafana-cloud/alerting-and-irm/alerting/alerting-rules/).
You can [silence](/docs/grafana-cloud/alerting-and-irm/alerting/manage-notifications/create-silence/) some default alerts temporarily as a useful strategy when you are investigating alerts.
## Copy a preconfigured alert
While you cannot alter the preconfigured alerts that are available in Kubernetes Monitoring, you can copy them and customize them. This can be helpful when troubleshooting. For example, you may want to know whether an existing state that’s causing an alert to fire is temporary or a longer term problem. To copy an alert:
1. Click the name of the alert on the **Alerts** page to open the alert rule in a new tab .
2. On the **Alert rules**, expand the **Firing** section.
3. Under Actions, click **More**, and select **Duplicate**.
   [Selecting **Duplicate** to copy an alert](/media/docs/grafana-cloud/k8s/duplicate_alert.png)
4. On the **New alert rule** page, follow the [steps](/docs/grafana-cloud/alerting-and-irm/alerting/alerting-rules/) to create and configure the rule.
5. When you set the alert evaluation behavior, select a different namespace from the current one.
## Create an alert
If you are an administrator of your Grafana Cloud stack, you can create a new alert from panels throughout Kubernetes Monitoring. To do so, complete the following steps:
1. Navigate to any CPU or Memory panel and click the menu icon.
2. Select **New alert rule**.
3. On the **New alert rule** page, follow the [steps](/docs/grafana-cloud/alerting-and-irm/alerting/alerting-rules/) to configure the rule.
   [Creating a new alert from a panel menu](/media/docs/grafana-cloud/k8s/creatingNewAlert.gif)
