title: "Release notes for Grafana Kubernetes Monitoring | Grafana Cloud documentation"
description: "Release notes for the various elements that make up Kubernetes Monitoring"
# Release notes for Grafana Kubernetes Monitoring
Grafana Kubernetes Monitoring includes these elements, which all have their own releases:
- [Frontend GUI](#frontend-release-notes) of the app (also called plugin)
- [Backend mixin](#backend-release-notes) (also called integration), covering the alert and recording rules
- [Helm chart](#helm-chart-release-notes) for the default and other configurations of Kubernetes Monitoring
## Frontend release notes
The following are release notes for the Kubernetes Monitoring GUI.
### 2.30.1
04/22/26
Expand table
| Type        | Description        |
| Enhancement | CPU metrics: Added CPU efficiency stats (requests/capacity, usage/capacity, usage/requests) to the Cluster detail page’s CPU tab. These metrics lay the foundation for OpenTelemetry support. |
| Enhancement | CPU metrics: Added CPU requests and limits to Pod and container detail pages. These metrics lay the foundation for OpenTelemetry support.                                                     |
| Fix         | Cluster CPU tab: Fixed extra table columns incorrectly appearing as links in the Cluster CPU tab.        |
| Fix         | Logs: Fixed log and event queries not refreshing when the time range changes.        |
| Fix         | Alerts: Fixed the Namespace detail page showing alerts from other clusters with the same namespace name.        |
| Fix         | Security: Updated Go to 1.26.2 and updated dependencies to address multiple CVEs.        |
### 2.30.0
04/14/26
Expand table
| Feature     | Alerts: Added an Alerts tab to the Cluster detail page.        |
| Enhancement | Knowledge Graph: Added Knowledge Graph health annotations to time series panels on detail pages (Cluster, Namespace, Node, Pod, and workload), showing detected issues as highlighted time regions.        |
| Enhancement | Pyroscope integration: Fixed the “View profiles” button and flame graphs. This was due to not finding Pyroscope data when the container name differs from the workload name. When a workload has multiple containers with Pyroscope data, a drop-down menu lets you choose which one to view. |
| Fix         | Init containers: Fixed native sidecar containers (for example, Istio) showing no data in resource views. Kubernetes registers these as init containers, and the UI was only querying regular container metrics.        |
| Fix         | Alerts: Fixed Grafana-managed alerts not appearing on the main Alerts page. Only data source alerts were displayed.        |
| Fix         | Energy: Fixed the workload Energy tab showing incorrect data because queries weren’t filtering by namespace.        |
| Fix         | Predictions: Fixed the “Predict CPU usage” and “Predict memory usage” buttons rarely working. They only succeeded on fresh page loads and failed after navigating between pages.        |
| Fix         | Configuration: Fixed the “Create token” button being disabled during onboarding. The button required the backend to be installed first, but the backend requires a token to install, so users couldn’t proceed.        |
| Fix         | Security: Updated dependencies to address multiple CVEs.        |
### 2.29.0
04/02/26
Expand table
| Feature | Search: Added contextual subtitles (Cluster, Namespace, workload) to search autocomplete results, making it easier to distinguish between resources with similar names.        |
| Fix     | CPU metrics: Fixed Node CPU usage showing roughly twice the actual value when both node-exporter and `kubelet` report the same metric, because the query summed both instead of removing duplicates. Also fixed an incorrect CPU usage/capacity calculation on the Home page. |
| Fix     | Energy: Fixed broken links on Energy pages when navigating from Node to Pod or from Cluster to Namespace.        |
| Fix     | Configuration: Fixed the configuration page showing disabled buttons for Kubernetes Monitoring admins who weren’t also Grafana org admins. The page now correctly uses the Kubernetes Monitoring plugin role for access.                                                      |
### 2.28.2
03/25/26
Expand table
| Fix  | Continuous profiling: Fixed profiling time range to use the dashboard time range instead of a hardcoded 24-hour lookback, and disabled the “View profiles” button when the specific profile type doesn’t exist for a workload. |
| Fix  | Continuous profiling: Fixed Pyroscope service name matching for `namespace/workload` format when multiple service names share the workload name as a substring.        |
| Fix  | Configuration: Renamed configuration wizard step labels to match instructions (“Stack information” to “Stack and platform”, “Platform and features” to “Monitoring type”).                                                     |
### 2.28.1
03/16/26
Expand table
| Enhancement | Continuous profiling: Added Pyroscope integration with embedded flame graphs on workload and Pod detail pages, and direct links to Profiles Drilldown from CPU and Memory tabs. |
| Enhancement | Configuration: Renamed and clarified all four configuration wizard step labels for consistency, and reworded the step two instructions to better match the workflow order.      |
| Fix         | Search: Fixed search page not loading previous search terms when opened from a shared or bookmarked URL.        |
| Fix         | Configuration: Fixed the Integration Hub onboarding flow where pasting an existing access token did not populate the token in the generated `helm upgrade` command.             |
| Fix         | Configuration: Fixed the OpenCost documentation link not displaying as a clickable link in the cost metrics alert.                                                              |
| Fix         | Security: Updated dependencies to address CVEs.        |
### 2.28.0
03/11/26
Expand table
| Feature     | Configuration: Redesigned the configuration page into four steps for a clearer setup experience.        |
| Feature     | Health: Added a new Health page showing a live snapshot of active issues across all Clusters.        |
| Enhancement | OpenTelemetry: As part of adding support for OpenTelemetry, added CPU metrics for OTel data sources in Node, Namespace, and Cluster views.                                                   |
| Fix         | Error messaging: Improved error messages for recording rule operations to show the actual error instead of a generic failure message.                                                        |
| Fix         | Metrics accuracy: Panels now filter out internal bookkeeping metrics reported by the container runtime (cAdvisor), so CPU and memory values reflect only your actual application containers. |
| Fix         | Workload metrics: Used workload-level recording rules instead of Pod filtering for more accurate workload metrics.        |
| Fix         | Panel queries: Added unique query reference IDs to prevent data conflicts in panels with multiple queries sharing the same runner.                                                           |
### 2.27.2
03/04/26
Expand table
| Fix  | Predictions: Dynamically load prediction modules to prevent page crashes if a prediction module fails to load. |
### 2.27.1
03/03/26
Expand table
| Feature     | Search: Redesigned the search page for better user experience.        |
| Enhancement | OpenTelemetry: As part of adding support for OpenTelemetry, added CPU limit metrics for OTel data sources in Namespace, Node, and Cluster views so you can compare CPU usage against configured limits. |
| Enhancement | Configuration: Added a disabled state to feature toggles that aren’t supported on the selected platform.        |
| Fix         | Logs: Fixed Loki data source picker to only show Grafana Cloud Loki data sources, which previously could show non-Grafana-Cloud data sources that wouldn’t work correctly.                              |
| Fix         | Events: Added a dedicated query for `object_name` and `object_kind` fields in event logs so that event details display correctly.        |
| Fix         | Workload detail: Renamed “Pods” label to “Pods in time range” to more accurately reflect the metric.        |
### 2.27.0
02/23/26
Expand table
| Enhancement | OpenTelemetry: Added support for OpenTelemetry `kubeletstatsreceiver` CPU metrics.                 |
| Fix         | IOPS by Pod: Fixed write IOPS to use correct `container_fs_writes_total` metric.                   |
| Fix         | Pod filtering: Fixed page breaks with many Pods by using recording rule instead of URL parameters. |
| Fix         | OpenTelemetry events: Fixed events labels not displaying correctly for OpenTelemetry events.       |
| Fix         | Configuration: Changed default Cluster name to ‘my-cluster’ in onboarding instructions.            |
### 2.26.0
02/10/26
Expand table
| Feature     | Manage costs: Redesigned the costs and savings view.                                                         |
| Enhancement | Logs: Use node filter (if available) for OTel logs in node logs view for more accurate filtering.            |
| Enhancement | Configuration instructions: Added cluster name to the simplified Alloy Helm instructions for better clarity. |
| Fix         | Alerts: Removed node filter in pods table alerts to prevent incorrect filtering.                             |
### 2.25.3
02/03/26
Expand table
| Feature     | Search: Added ability to search by container image name, making it easier to find all instances of a specific image.                                              |
| Enhancement | Alert detection: Enhanced alert detection to support both Prometheus Alertmanager-based alerts and Grafana-managed alerts during the alerting platform migration. |
| Enhancement | Knowledge Graph integration: Added banner to enable and navigate to Knowledge Graph for root cause analysis when not enabled.                                     |
### 2.25.2
01/27/26
Expand table
| Feature | Pod count: Added Pod count panel to workload detail pages.                   |
| Fix     | Logs: Fallback to default logs query if no data found in any of the queries. |
### 2.25.1
01/27/26
Expand table
| Fix  | Logs: Fallback to OTel logs queries as expected.                   |
| Fix  | Security: Updated dependencies to satisfy CVEs and updated eslint. |
### 2.25.0
01/20/26
Expand table
| Feature     | Logs: Replaced logs with new drilldown logs extension for improved log exploration.                  |
| Enhancement | Network metrics: Added network metrics for Windows nodes.                                            |
| Fix         | Logs: Use query runner as data provider to get the logs query.                                       |
| Fix         | Security: Updated @remix-run/router to v1.23.2 to fix vulnerability.                                 |
| Fix         | Pod metrics: Removed by label filter in Pod level request and memory sets for more accurate metrics. |
| Fix         | Cronjob: Fixed cronjob filtering to properly filter by namespace.                                    |
### 2.24.3
12/11/25
Expand table
| Feature     | Configuration: Added the capability to enable or disable forwarding traces to application receivers.                                       |
| Enhancement | Changed the default view in the **Logs and Events** tab from the table view to the logs list view.                                         |
| Fix         | Jobs: Fixed **Reason** column in the Pods table under Jobs.        |
| Fix         | Jobs: Fixed an issue where empty or missing schedules could cause errors when displaying Cronjob schedules.                                |
| Fix         | Workloads list: Fixed workload counts on the namespace list so that they now accurately reflect the number of workloads in each namespace. |
### 2.24.2
11/20/25
Expand table
| Feature     | EC2 instances: Added links showing which EC2 instances correspond to which Cluster nodes.                                 |
| Enhancement | Explore link: The **Explore** link opens in a new browser tab, offering stability of the GUI with large datasets.         |
| Fix         | Jobs: Fixed job URL creation to use the job name instead of owner kind, ensuring more accurate links for Kubernetes jobs. |
### 2.24.1
11/20/25
Expand table
| Fix  | Knowledge graph: ObjectDetailExtension now uses the Kubernetes `workload` concept instead of `entityName`. This ensures displayed details are more accurate and terminology matches current Kubernetes standards. |
| Fix  | Jobs: - Fixed job URL creation to use the job name instead of owner kind, ensuring more accurate links for Kubernetes jobs.        |
### 2.24.0
11/13/25
Expand table
| Feature | Access control: Added the ability to use RBAC roles.                                       |
| Fix     | Jobs: Assigned a default owner if no owner type exists, to ensure job links work properly. |
### 2.23.0
10/30/25
Expand table
| Feature | Grafana Assistant: Added Grafana Assistant icons to most panels and added the **Investigate with Assistant** button to all detail pages. |
### 2.22.0
10/22/25
Expand table
| Feature     | Jobs: Added jobs and cron jobs monitoring.                |
| Enhancement | Filtering: Enabled column filtering on all tables.        |
| Enhancement | Activation: Changed name of activation tab to Manage app. |
| Fix         | Workbench: Removed filter from columns with a checkbox.   |
| Fix         | Node table queries: Used node filter for accuracy.        |
| Fix         | Column headings: Removed incorrect units.                 |
### 2.20.0
8/29/25
Expand table
| Enhancement | Integrations: Added a Kubernetes filter to the Connections page.    |
| Enhancement | Configuration: Added the ability to activate Kubernetes Monitoring. |
### 2.19.8
8/21/25
Expand table
| Enhancement | Integrations: Removed integrations from the Configuration page. |
### 2.19.7
8/19/25
Expand table
| Enhancement | Configuration: Removed the selection in configuration to switch on Application Observability now that users can activate it from the product. |
8/5/25
Expand table
| Enhancement | Asserts: Added new term ‘insights’ instead of ‘assertions’.                                       |
| Fix         | OTel: Updated the cluster events query to improve support with OpenTelemetry Collectors.          |
| Fix         | Scrape intervals: Removed hard-coded time interval so that panels reflect custom scrape interval. |
### 2.19.5
7/25/25
Expand table
| Enhancement | Asserts: Added health indicator icons to lists of components.                  |
| Fix         | Pod CPU and memory: Reverted fix from 2.19.3 due to bugs it was causing.       |
| Fix         | Container memory: Fixed container memory panels to aggregate correctly.        |
| Fix         | Cluster list: Corrected the number of nodes for a cluster in the info section. |
### 2.19.3
7/16/25
Expand table
| Enhancement | Cost overview: Added ability to jump to list of Clusters from Cost Overview page.        |
| Enhancement | Integrations: Added a message on the Integrations page that integrations will soon be accessible from the Connections page.                        |
| Fix         | Pods: Include all Pods if no pod value specified and use podName value if available on Pod CPU and Memory queries to prevent no data from showing. |
### 2.19.2
7/3/25
Expand table
| Feature     | GPU: Added GPU tabs and panels to Cluster and Node pages.        |
| Feature     | EC2 link: Added link to navigate between EC2 instance in Cloud Provider Observability and Kubernetes Monitoring.                           |
| Enhancement | Cost: Added tooltips for cost panels to clarify underlying calculations and their time frame.                                              |
| Enhancement | User experience: Streamlined descriptions of panels for clarity and brevity.                                                               |
| Fix         | Storage: Changed inode values to percentages.        |
| Fix         | Workloads: Fixed query to ensure all barepods workloads are listed, whether desired Pods or ready Pods.                                    |
| Fix         | CPU and memory tabs: Corrected the calculation for the Efficiency Usage/Requests panel on the CPU and Memory tabs of the Node detail page. |
| Fix         | Argo Rollout Pods: Removed duplicate query to prevent incorrect count.        |
| Fix         | Container page: Fixed tab links to navigate to appropriate pages.        |
### 2.19.1
6/11/25
Expand table
| Enhancement | Serverless and Windows Nodes: Added support for showing Node memory usage on platforms that cannot use Node Exporter (such as GKE Autopilot and AWS EKS Fargate), and Windows. |
| Enhancement | Logs table: Added the ability for a user to rollover a line in the logs table and click an icon to see the full log message.                                                   |
| Fix         | Queries: Fixed queries for Cluster names with a `.`, which causes results to be empty.        |
| Fix         | Non-Kubernetes Nodes: Prevented the app from selecting Nodes that are not Kubernetes Nodes to be counted and displayed.                                                        |
### 2.19.0
6/4/25
Expand table
| Enhancement | Memory: Added a memory tab and panels to Node, Namespace, Workload, Pod, and Cluster detail pages.                                                        |
| Enhancement | Workloads: Added the capability to view nonstandard workloads that contain cronjobs, bare pods, static pods, Argo Rollouts, Strimzi Pod sets, and others. |
| Enhancement | Logs: Created a table format to display logs and events.        |
### 2.18.0
5/21/25
Expand table
| Enhancement | CPU tabs: Added CPU tabs to the Pod, Workload, and Namespace detail pages.        |
| Enhancement | GKE Autopilot and AWS EKS Fargate: Used `kubelet` Resource Metrics (`node_cpu_usage_seconds_total`) to show CPU usage for platforms that cannot use Node Exporter, including GKE Autopilot and AWS EKS Fargate. |
| Fix         | Link to Pod: Fixed ability to go to a specific Pod from the Network Bandwidth by Pod panel on the Node details page on the Network tab.        |
| Fix         | URL: Fixed variables not synching with URL.        |
| Fix         | Metrics status page: Corrected spacing between panels.        |
| Fix         | DNS: Added a `.` to the end of hostnames to prevent DNS confusion.        |
| Fix         | OTLP: Included the OTLP Gateway destination in the Kubernetes Helm chart to route metrics, logs, and traces using the OTLP format.        |
| Fix         | Outlier detection: Changed Outlier detection to use podNames to prevent incorrect counts of outlier Pods.        |
### 2.17.0
5/6/25
Expand table
| Feature | CPU details: Added CPU tab for Node details page and Cluster details page.                                             |
| Fix     | Table headers: Made table headers visible for light mode.                                                              |
| Fix     | Pods: Fixed Pods with the same name on different Clusters to be differentiated from each other.                        |
| Fix     | Table columns: Make it more apparent table columns can be resized.                                                     |
| Fix     | Data accuracy: Ensure that CPU and memory requests only look at active pods, not completed or failed.                  |
| Fix     | Terraform files: Ensure use of strings for usernames in Terraform files to ensure compatibility for Helm chart values. |
### 2.16.0
4/23/25
Expand table
| Enhancement | Storage: Added IOPS and throughput panels on all Storage tabs.                                                  |
| Fix         | Cost: Prevented duplicate cAdvisor scrape jobs from affecting cost allocation.                                  |
| Fix         | Alerts: Fixed namespace drop-down menu on Alerts page from not being populated.                                 |
| Fix         | Pod names: Corrected formatting of Pod names when using Explore from Pod lists.                                 |
| Fix         | Memory usage: Prevented completed and pending pods from affecting memory usage queries on the Pod details page. |
### 2.15.1
4/17/25
Expand table
| Enhancement | Alerts: Added capability to filter alerts on Alert page by Node.        |
| Enhancement | Outlier detection: Outlier detection for memory automatically runs when you visit a workload details page for multi-Pod workloads, and links to Explore to show the outlier Pod(s) using more memory. |
| Fix         | Integration: Correct the configuration snippet for the Core DNS integration.        |
### 2.15.0
4/14/25
Expand table
| Feature     | Outlier detection: Outlier detection automatically runs when you visit a workload details page for multi-Pod workloads, and links to Explore to show the outlier Pod(s) using more CPU. |
| Enhancement | Detail pages: CPU and memory columns and prediction buttons for each row have been added to the Cluster, workload, and namespace detail pages.                                          |
| Fix         | Events and logs status check: Fixed status check and Explore links for events and logs on the Metrics status tab.        |
| Fix         | Overview page: Fixed the **All** alert links on the home page.        |
| Fix         | Overview page: Corrected the workload count on the overview page to more closely correlate to the workload count shown on the workloads list page.                                      |
| Fix         | Fleet Management: Fixed reference to Fleet Management Terraform variables.        |
### 2.14.1
4/2/25
Expand table
| Enhancement | Performance: Decreased the training and inference latency of the machine learning functionality to show results quicker.        |
| Enhancement | Alerts: Added filtering by alert name.        |
| Enhancement | Overview page: After filtering by Cluster or namespace, you can click on the count of Clusters, Nodes, namespaces, or workloads and show only those objects within the scope of the filter. |
| Enhancement | User experience: On Workload and Namespace list pages, made the Cluster names clickable and added graphs to the counts.        |
| Fix         | Workload counts: Corrected calculations on workload counts on the Overview page.        |
| Fix         | List pages: Restored the alerts table column.        |
| Fix         | Alloy logs instance: Set the Pod security context for the Alloy logs instance on OpenShift.        |
| Fix         | OpenShift: Corrected the port names for OpenShift so that Alloy can discover targets to scrape.        |
| Fix         | EKS Fargate: Removed mounting of /var/log and /var/lib/docker/containers.        |
### 2.14.0
3/24/25
Expand table
| Feature     | Troubleshooting: Added a debug panel showing the source of a panel’s metrics, available from the panel menu.        |
| Enhancement | Performance: Added a view for each list page when queries extend beyond performance capabilities which degrade page loading. This view includes a message to search or filter for specific components. |
| Fix         | Performance: Stopped unrelated panels from reloading when the logs data source is changed.        |
| Fix         | Accuracy: Stopped counting containers that are not running, which caused CPU limits and requests to appear higher than they should.        |
| Fix         | Platforms: Disabled unnecessary components for specific platforms: nodelogs on Fargate, and profiling, Beyla, and Windows Exporter on Autopilot.                                                       |
### 2.13.2
3/18/25
Expand table
| Fix  | Fleet Management: Fixed interaction with Fleet Management so that Alloy installation shows positive on Metrics Status page. |
| Fix  | Fleet Management: Changed configuration to store secret for Fleet Management in secret instead of environmental variable.   |
### 2.13.1
3/13/25
Expand table
| Fix  | Removed `stabilityLevel: public-preview` in relation to Alloy from the code generated on the Configuration page. |
| Fix  | Prevented a race condition causing HTML error messages to appear.                                                |
| Fix  | Asserts: Restored RCA workbench linking.        |
### 2.13.0
3/9/25
Expand table
| Feature     | Configuration: Added toggle in easy deploy for users to add Fleet Management for management of Alloy deployments.        |
| Enhancement | Cluster detail page: Added buttons to allow users to navigate to workloads and namespaces within the cluster.        |
| Fix         | Memory queries: Switched to Working Set Size (WSS) instead of Resident Set Size (RSS) to increase accuracy of memory statistics and match `kubectl` and Linux Out-of-Memory behavior. |
### 2.12.3
2/20/25
Expand table
| Fix  | Configuration and status tabs: Fixed issue of configuration state not persisting when user switches between the tabs. |
| Fix  | URL stability: Maintain URL on refresh of page.        |
| Fix  | Integrations: Updated integrations to work with Kubernetes Monitoring Helm chart version 2.                           |
### 2.12.2
2/6/25
Expand table
| Fix  | Workload details page: Fixed TypeError to prevent unsafe access to data source. |
### 2.12.1
2/6/25
Expand table
| Fix  | Receiver URLs: Updated URLs to match the version 2 Alloy deployment.                |
| Fix  | Tempo and Logs: Updated configuration to fix Tempo protocol and autopilot for logs. |
### 2.12.0
2/5/25
Expand table
| Feature     | Storage: Added storage tabs and graphs to Cluster, Node, workload, namespace, and Pod detail pages.                                             |
| Enhancement | Configuration: Updated the easy deployment configuration page to use Helm chart v2.                                                             |
| Enhancement | Recording rules: Added the install/uninstall button to the Workload Recording Rule status for the cloud-provisioned hosted metrics data source. |
| Fix         | Prediction button: Disabled if the time range selected is less than two hours.        |
| Fix         | Data source drop-down: Removed machine learning metrics data source from the drop-down menu.                                                    |
| Fix         | Data source drop-down: Added verification that the data source is valid prior to displaying in the drop-down menu.                              |
| Fix         | Workload list page: Fixed to not display all columns if filters result in more than 1,000 results.                                              |
### 2.11.2
1/15/25
Expand table
| Fix  | Time range: Ensured the time range selected in Kubernetes Monitoring is transferred to Application Observability when the **View application layer** button is clicked. |
| Fix  | Performance loading: Resolved issues related to rerendering of pages.        |
| Fix  | Filters: Ensured when time range is changed that all filters are not returned to the default.        |
### 2.11.1
1/9/25
Expand table
| Enhancement | User experience: Added the tool tip to the Copy icon.                                            |
| Fix         | Node count: Fixed incorrect Node count on Kubernetes Overview page due to empty node labels.     |
| Fix         | Performance loading: Improve loading performance of tables in detail pages.                      |
| Fix         | Memory data: Rollback to the original recommendation for memory requests to equal memory limits. |
### 2.11.0
1/6/25
Expand table
| Enhancement | Performance: If Workload list page result is over 1,000 workloads, the page will load quickly but no usage or cost data will show. A message will display suggesting the list be filtered, and include a link to search. |
| Fix         | Metrics status: Detect duplicate container metrics.        |
| Fix         | Data source: Filter the data source drop-down menu to be limited to Grafana Cloud data sources.        |
### 2.10.0
12/9/24
Expand table
| Feature | Performance: Improve performance by performing a code split. |
| Fix     | Loop error: Fixed a history loop error and page breaking.    |
### 2.9.0
11/25/24
Expand table
| Feature | Search: Added the ability to search for any Kubernetes object.            |
| Fix     | Metrics status: Show the status checks even if no clusters were detected. |
### 2.8.8
11/12/24
Expand table
| Fix  | Erroneous no data error: Added a null check to prevent the no data message from displaying due to UID not found for a database. |
### 2.8.7
11/6/24
Expand table
| Fix  | Asserts: Fix to ensure Kubernetes Monitoring is aware Asserts is enabled. |
### 2.8.6
11/5/24
Expand table
| Fix  | Asserts: Fix the time range so that it is synchronized between Kubernetes Monitoring and Asserts. |
### 2.8.5
10/30/24
Expand table
| Fix  | Updated link to the Application Observability GUI. |
| Fix  | Properly align Cluster columns.                    |
### 2.8.4
10/17/24
Expand table
| Enhancement | User experience: Created Cluster, namespace, and Pod columns for alerts on home page.        |
| Enhancement | User experience: On the Metrics status tab, added the ability to select the status of all or many Clusters.                                                      |
| Fix         | Instead of displaying no data on the home page should an outage occur, the home page will show historical data prior to the outage and current data post-outage. |
| Fix         | GUI: Fixed various anomolies with the GUI, including the location of the navigation drop-down menu and the width of certain columns.                             |
### 2.8.3
9/23/24
Expand table
| Fix  | Alerts: Hide panel menu item for creating alerts if a user is not an administrator. |
### 2.8.2
9/12/24
Expand table
| Enhancement | User experience: Restricted the namespace field for the quick configuration process to only valid characters.        |
| Enhancement | User experience: Added the link to the Cluster below the title on detail pages.        |
| Enhancement | Troubleshooting: Added the Helm chart to the Metrics status page.        |
| Enhancement | User experience: Added waiting reasons and colors for Pods that are either waiting due to startup or due to a problem.        |
| Enhancement | Troubleshooting: Added the waiting reason for Pods that are waiting instead of running.        |
| Enhancement | Alerts: Added the ability to create an alert item from a panel.        |
| Fixes       | Fixed the container memory limit on Container detail pages to be accurate. Ensured logs and events are not listed when there are no Pods. Fixed ability to remove a ’no data’ filter when a time range is changed. |
### 2.8.1
8/25/24
Expand table
| Feature      | New platform: Added Azure AKS as a separate platform for configuration.        |
| Enhancement  | Metrics status: Added statuses for recording rules and KSM job label.        |
| Enhancements | User experience: Moved up the required backend installations step to prevent misconfigurations. Restricted integrations view to administrators only and improved message to non-administrative user. Added links to documentation on **Overview**, **Cost**, **Alerts**, and **Configuration** pages. Adjusted the width of filters and moved copy button closer to item for ease of use. Refresh home page when data starts being sent. |
| Enhancement  | Code snippets for integrations: Added configuration code snippets for Apache CouchDB, Apache Hadoop, Apache Tomcat, and IBM DB2.        |
| Fix          | CPU statistics: Fixed issue that was causing the memory legend to show in relation to CPU stats.        |
### 2.8.0
8/6/24
Expand table
| Feature | Energy use: Added energy metrics by using third-party Kepler open source software. |
| Fix     | Duplicates: Deduplication of Pods and containers.                                  |
### 2.7.0
7/29/24
Expand table
| Enhancement | User experience: Added a tab for logs and events on every detail page, including the Cluster detail page.       |
| Enhancement | Integrations: Added snippets for the Alloy and Varnish integrations.                                            |
| Enhancement | Logs: Made log queries work with OTel-style labels.                                                             |
| Fixes       | Correct time range format on home page. Ensured Kubernetes Monitoring opens in correct time range from Asserts. |
### 2.6.1
7/16/24
Expand table
| Enhancement | Alerts: Added the ability to click on the alert name from the **Kubernetes Overview** page. |
| Enhancement | Integrations: Added configuration snippets for Squid and Apache Mesos.                      |
| Fix         | Prevented continuous rendering of data in the Safari browser.                               |
### 2.6.0
7/10/24
Expand table
| Feature     | Home page: Upgraded the home page to better show the status of healthy Kubernetes objects as well as any potential issues.        |
| Feature     | Asserts button: Added Assertions button to details pages.        |
| Enhancement | User experience enhancements: Added quick ways to navigate within the app, including the drop-down menu for all main pages, the overview and network tabs, deep linking from the home page CPU and memory graphs to the Cluster, improved Helm chart configuration process, and visual tags to indicate the type of Kubernetes object for each view. |
### 2.5.0
6/25/24
Expand table
| Feature     | Network panels: Added Network Bandwidth and Network Saturation data.        |
| Feature     | Cost overview panels: Added a 90-day view of total compute cost, average cost per Pod, and average Pod count on the Cost Overview page. |
| Enhancement | OpenTelemetry: Added support for displaying events coming from the OpenTelemetry Kubernetes Events Receiver.                            |
| Fix         | Workloads with same name: Corrected CPU and memory usage data for workloads with the same name but in different Clusters.               |
### 2.4.0
6/18/24
Expand table
| Feature     | Deleted objects: Added the ability to find deleted Clusters, Nodes, Pods, containers, workloads, and namespaces. |
| Enhancement | User experience: Improved “no data” messages on home page.                                                       |
| Enhancement | Metrics: Host metrics generation.        |
| Fix         | Error messages: Fixed query to prevent an invalid error message.                                                 |
| Fix         | Update host metrics switch language and disable CRDs on OpenShift.                                               |
### 2.3.5
6/12/24
Expand table
| Enhancement | Integration: Added Apache Airflow configuration snippets for integration. |
| Fix         | Duplicates: Removed duplicate data showing on home page.                  |
| Fix         | Alerts: Improved alert count accuracy for certain kinds of Pod types.     |
### 2.3.4
6/7/24
Expand table
| Enhancement | Added time range selector to home snapshot page. |
### 2.3.3
6/3/24
Expand table
| Enhancement | Integrations: Added configuration snippets for the integrations Wildfly and OpenSearch.                                                 |
| Enhancement | Performance: Improved load time for queries spanning longer time ranges.        |
| Fix         | Refresh and Cluster filters: Fixed so refresh does not cause filters to be removed.                                                     |
| Fix         | Cardinality page: Ensured the Series per namespace column data link is accurate.                                                        |
| Fix         | Documentation links: Updated and corrected documentation links on Kubernetes Monitoring main page (that is shown prior to configuring). |
| Fix         | Workload type: Ensured different workloads that are similarly named accurately show the type of workload and the data for the workload. |
### 2.3.2
5/21/24
Expand table
| Enhancement | Performance: Improved loading performance of CPU and memory usage tables. |
| Fix         | Added a null check for provider to avoid errors on Cluster list page.     |
### 2.3.1
5/16/24
Expand table
| Enhancement | Integration: Added configuration snippets for the Apache Solr integration.        |
| Fix         | Fixed Helm chart integration snippets to be compatible with Alloy.        |
| Fix         | Fixed recording rule to include ReplicaSets, static Pods, and bare Pods so that missing workloads now show and incorrectly labeled workloads are now labeled correctly. This also fixes workload usage and cost data. |
### 2.2.5
4/25/24
Expand table
| Enhancement | Static Pod and Pod type: Added the static Pod label to all static Pods and the Pod label to bare/unmanaged Pods . |
| Enhancement | Integrations: Added flow configuration snippets for Velero and MS SQL Server integrations.                        |
| Fix         | Fixed link to alert rule after automatic refresh.        |
### 2.2.4
4/22/24
Expand table
| Enhancement | Data source persistence in URL: Persisted the Loki data source in the URL so that accurate links can be shared. |
| Fix         | Added check to prevent query errors.        |
### 2.2.3
4/18/24
Expand table
| Feature | Refresh control: Added refresh and auto-refresh choices to all pages. |
### 2.2.2
4/17/24
Expand table
| Feature     | Alerts: Added the Alerts column to the Nodes and Cluster list pages.                                           |
| Enhancement | URL data source persistence: Persisted Prometheus data source in the URL so that accurate links can be shared. |
| Enhancement | Integration: Added configuration snippets for OracleDB integration.                                            |
### 2.2.1
4/15/24
Expand table
| Feature     | Alloy update: Replace Grafana Agent with Grafana Alloy.                                          |
| Feature     | Cardinality: Added the Cardinality page to replace the Kubernetes Cardinality dashboard.         |
| Feature     | Alerts: Added the Alerts column to these pages: Pod detail, Pod list, and Workloads list.        |
| Enhancement | Integration: Added configuration snippets for TensorFlow Serving integration.                    |
| Enhancement | User experience: Added the ability to select multiple clusters for filtering.                    |
| Fix         | Removed logs panel from Node detail page for future refactoring.                                 |
| Fix         | Corrected improper indent in configuration snippet of IBM MQ integration.                        |
| Fix         | Added `kube_deployment` as well as `kube_replicaset` to ensure all workload types are collected. |
### 2.2.0
4/8/24
Expand table
| Fix  | Refactored workloads to use more efficient queries. |
### 2.1.3
4/4/24
Expand table
| Enhancement | Added the workload type when available to filter the list of Pods to improve search performance. |
| Fix         | Enhanced the multi-line regular expression to support a broader collection of logs.              |
### 2.1.2
4/2/24
Expand table
| Fix  | Reverted from support for OTel log labels. |
### 2.1.1
4/2/24
Expand table
| Feature     | Added interactivity with Sift automated machine learning investigation tool.                   |
| Enhancement | Added configuration snippets for the Couchbase and IBM MQ integrations.                        |
| Enhancement | Added support for OTel log labels.                                                             |
| Fix         | Combined `target_info` with `traces_target_info` metrics to ensure all applications are found. |
### 2.1.0
3/25/24
Expand table
| Enhancement | Configuration: Added configuration snippets for the PgBouncer integration. Added link to `extraConfig` information in the Helm documents from the code snippet areas of an integration. |
| Enhancement | Dashboards: Removed dashboards due to Angular deprecation.        |
| Enhancement | Messaging: Improve wording of default messages when a data source is updated for a view.        |
| Fix         | Persist Cluster URL values to correct broken links.        |
### 2.0.4
3/13/24
Expand table
| Feature     | Asserts workbench: Added **RCA Workbench** button to allow navigating to Asserts.                               |
| Enhancement | Explore: Expanded the explore feature to the list of all Pods. Improved the user experience for exploring data. |
| Fix         | Removed inaccurate timestamp for namespace creation on Namespace details page.                                  |
| Fix         | Corrected the query for phase state, which is shown by expanding a list item on the **Namespaces** page.        |
| Fix         | Add the `http` prefix to OTLP endpoints on the **Cluster configuration** tab when OTel receivers are selected.  |
| Fix         | Persisted the data source between views.        |
### 2.0.3
3/6/24
Expand table
| Feature     | Added the capability to navigate to Application Observability.        |
| Feature     | On the Cluster list page, you can click the **Explore** button to view the queries used in each column of the usage and cost data. This enables you not only to understand the data, but debug any issues or create your own queries or dashboards |
| Feature     | Added support for the [Istio](https://istio.io/) integration.        |
| Feature     | Added a warning icon and tooltip on column headers of lists to indicate error detection and query failure.        |
| Feature     | With the easy configuration using the Helm chart, added the capability to enable OTel and Zipkin receivers.        |
| Enhancement | Added the filter toolbar to list tables for better user experience.        |
| Enhancement | Added duplicate metrics detection to Node Exporter, Windows Exporter, OpenCost, cAdvisor, and `kubelet`. When there is an error, a yellow warning icon appears next to the item on the **Metrics status** page.                                    |
| Enhancement | Refined queries for “OOMKilled” containers to prevent counting of duplicate containers, specifically when a container is being killed and another is being created in its place.        |
| Enhancement | The link to examine an alert opens in a new tab so that context within Kubernetes Monitoring is not lost.        |
| Enhancement | Updated URL so that any shared URL includes any variables and the time range selected.        |
| Enhancement | Release note text in the app links to the release notes in documentation.        |
| Enhancement | Breadcrumbs now include page tab names.        |
| Enhancement | Corrected the query for unallocated resources (PV) panel.        |
| Fix         | Created an additional check for deep links related to breadcrumbs display.        |
| Fix         | Refined queries to ensure deduplication of metrics, including removing reliance of `uid` label and having node/instance joins also use the Cluster label.        |
| Fix         | Corrected queries for the **Explore** button on the Workloads page.        |
| Fix         | Fixed CPU usage prediction graph to display correctly within window.        |
### 2.0.2
2/15/24
Expand table
| Enhancement | Refined deduplication of KSM `kube_node_status_capacity`, and added support for node with or without trailing port numbers. |
| Fix         | Created more accurate cost calculations in the case of mixed `node` and `instance` labels.                                  |
### 2.0.1
2/15/24
Expand table
| Enhancement | Added the workloads column to the list of namespaces. |
| Fix         | Corrected the calculation for CPU average queries.    |
### 2.0.0
2/6/24
Expand table
| Feature     | The Alerts page provides a centralized location to view all alerts related to your infrastructure and the applications running within it. Graphs show alerts firing by Cluster and namespace, as well as by alert severity. The alert name and severity also display on the home page in the list of **Pods in trouble**. On the **Namespaces** and **Workloads** tabs, a column for each item shows the amount of firing alerts. |
| Feature     | The ClickHouse integration is available for use with Kubernetes Monitoring.        |
| Enhancement | On the home page, you can click the Cluster count to navigate directly to the list of Clusters on the **Clusters** tab, and click the Node count to navigate directly to the list of Nodes on the **Nodes** tab.        |
| Enhancement | On usage cost/efficiency tables, the tables are sorted by default alphabetically by the name of the item (Cluster, namespace, and so on).        |
| Enhancement | To improve loading performance, the namespaces, workloads, and Nodes lists are filtered by default by the first Cluster in the filter list.        |
| Enhancement | You can click the **Explore** button on any item on the **Metrics status** tab to troubleshoot configuration issues and customize queries for status.        |
| Enhancement | To prevent deployment failure due to timeout, increased the timeout for the Helm chart to five minutes.        |
| Enhancement | An informational banner displays on the **Dashboards** page to indicate the prebuilt dashboards are being deprecated and removed, with the exception of the Cardinality dashboard.        |
| Fix         | Resolved a duplicate series error on the container details page.        |
| Fix         | Improved the status panel failure detection for kube-state-metrics.        |
| Fix         | When you click **Start Sending Data**, the **Configuration** page displays.        |
### 1.7.0
1/22/24
Expand table
| Feature     | You can view usage and cost graphs and data on the Pod details page.        |
| Feature     | When using EKS on Fargate, Pod logs are made available by using the Kubernetes API to gather them.        |
| Feature     | Added or updated support for these integrations: Aerospike, ActiveMQ, Cassandra, Apache HTTP Server Project, cert-manager, ClickHouse, CoreDNS, GitLab, Kafka, MongoDB, NGINX, and PrestoDB .         |
| Enhancement | On the Configuration page, you can add an expiration date to the token and view the scope of the token.        |
| Fix         | Corrected the following broken links: workload links on the Pod list of the Node details page, Cluster status link on the Configuration page, and links when Cluster name contains a slash character. |
### 1.6.2
1/10/24
Expand table
| Enhancement | User experience enhancements: The home page displays the home page name on the breadcrumbs, and filter options display alphabetically. |
| Enhancement | You can copy any object in the table lists by clicking the copy button within the row.                                                 |
### 1.6.1
12/19/23
Expand table
| Feature     | IBM Cloud is available as a platform that you can select when using the configuration wizard.        |
| Enhancement | You can choose Loki from the data source selector in all detailed views.        |
| Enhancement | A link to documentation for understanding CPU limits is available on detail pages showing CPU limits set.        |
| Enhancement | All IEC units show in standard form.        |
| Enhancement | Throughout Kubernetes Monitoring, you have the copy icon available to copy any text so that you can use it in your own query, use it in the command line, send it to others, and so on.           |
| Fix         | Fixed empty Cost panels for customers who use forward slashes in Cluster names by changing to pipe formatter.        |
| Fix         | Corrected inconsistencies in the number of Nodes displayed by using an instant query for any single value result instead of using a range query. This improves app performance and data accuracy. |
| Fix         | Fixed accuracy of CPU usage data on the Node details page.        |
| Fix         | Improved accuracy of machine learning prediction by using query variables to dynamically set parameters for calculation.        |
### 1.6.0
12/10/23
Expand table
| Feature     | Cluster detail page: Added optimization panel showing CPU and memory utilization, and cost information for the time range selected.                                                     |
| Feature     | Node detail page: Added optimization panel showing CPU and memory utilization, and cost information for the time range selected.                                                        |
| Enhancement | Cost page: All panels on the Cost page provide the Explore button so you can view the query, debug issues, or create your own dashboard.                                                |
| Fix         | Storage savings: Fixed storage results, which displayed multiple series errors in cases where a PersistentVolumeClaim was present on more than one node within the selected time range. |
| Fix         | Container details page: Fixed events, which weren’t displaying.        |
### 1.5.0
11/29/23
Expand table
| Feature     | Container detail page: Added page. This page includes CPU and memory utilization, and cost information. The restart and termination panels are adjacent to each other to allow quicker correlation of restart and termination events.                           |
| Feature     | Namespace detail page: Added optimization panel showing CPU and memory utilization, and cost information.        |
| Enhancement | Workloads detail page: Added optimization panel showing CPU and memory utilization, and cost information. Updated the feature for detecting outlier CPU usage in the Pods to uses the time range selected in the time selector instead the latest/current time. |
| Fix         | Pod detail page: Updated the CPU and memory queries for accuracy. Removed duplicate containers that were sometimes listing.        |
| Fix         | Home page: Decreased load time for the Pods in trouble panel, and filtered only for issues that are currently active.        |
| Fix         | Added Zipkin port configuration to ensure traces work properly.        |
| Fix         | Updated internal release process and documents.        |
### 1.4.1
11/10/23
Expand table
| Feature | Configuration wizard: Added a selector for the platform.                                              |
| Feature | Pod detail page: Added an optimization panel containing CPU and memory utilization and cost.          |
| Fix     | Time range selector: Changed to use the time zone of the user, to ensure accuracy of time range data. |
| Fix     | Use new metrics receiver flow component in the integration code snippets.                             |
| Fix     | Fixed missing data source for k3d environment.                                                        |
### 1.4.0
11/3/23
Expand table
| Enhancement | Time range selector: Added to all appropriate pages to allow a specific time range for data to be displayed. |
| Enhancement | Metrics status page: Improved for better user experience.                                                    |
| Enhancement | Configuration wizard: Improved visibility of OpenCost configuration information.                             |
| Enhancement | Pod details page: Used Scenes to build panels on this page.                                                  |
| Fix         | Default instructions in Github for integration: Fixed the appropriate name for Prometheus component.         |
| Fix         | Error message for testing integration: Revised for validity and comprehension.                               |
| Fix         | Workload key and data list fixes: Revised to use correct key on workloads list.                              |
| Fix         | Kafka integration: Revised job name to kafka for integration to work properly.                               |
| Fix         | Status queries: Adjusted to show consistent results.                                                         |
## Backend release notes
The following are release notes for the Kubernetes Monitoring backend.
### 2.3.0
April 2026
Expand table
| Enhancement | Alert rules: Updated kubernetes-mixin to v1.5.0. Adjusted `KubeHpaMaxedOut` to not fire when an HPA’s minReplicas equals maxReplicas, which is common during incident response or load testing. No new alerts are introduced; upstream `*InstanceUnreachable` alerts are excluded from this release because they would cause false positives with the current configuration. |
### 2.2.4
February 2026
Expand table
| Enhancement | Alert detection: Re-enabled support for Grafana-managed alerts. Alert queries now check both Prometheus Alertmanager (`ALERTS` metric) and Grafana-managed alerts (`GRAFANA_ALERTS` metric) to ensure all alerts are detected. During the transition period, you may temporarily see duplicate alerts for the same condition. |
### 2.2.3
January 2026
Expand table
| Enhancement | Updated kubernetes-mixin integration to 1.4.2. |
### 2.2.2
December 2025
Expand table
| Enhancement | Alert rules: Updated `KubePodNotReady` to remove `Failed` from phase label filter; updated `KubeContainerWaiting` from aggregated metrics using sum to using raw metrics; updated `KubeCPUOverCommit` and `KubeMemoryOvercommit` to differentiate between Non-HA and HA clusters; updated `KubeQuotaAlmostFull`, `KubeQuotaFullyUsed`, `KubeQuotaExceeded` to do explicit join instead of ignore; updated `CPUThrottlingHigh` to deduplicate with topk; updated `KubeletPodStartUpLatencyHigh` with topk for deduplication. |
| Enhancement | Recording rules: Updated `scheduler_e2e_scheduling_duration_seconds` bucket to `scheduler_scheduling_attempt_duration_seconds_bucket` (recording rule name also updated); updated `scheduler_binding_duration_seconds_bucket` to `scheduler_pod_scheduling_sli_duration_seconds_bucket` (recording rule name also updated); updated the `kubelet` PLEG `node_quantile:kubelet_pleg_relist_duration_seconds:histogram_quantile` recording rule to deduplicate with max by.                                                   |
### 2.2.1
December 2025
Expand table
| Fix  | Temporarily disabled Grafana-managed alerts. |
### 2.2.0
June 2025
Expand table
| Enhancement | Alert rules: Added the `cluster` label to any alert description where it was missing. Added `KubePdbNotEnoughHealthyPods`, `KubeNodePressure`, and `KubeNodeEviction`. Updated `KubeletTooManyPods` to deduplicate Pod counts and improve evaluation performance. Updated `KubeStatefulSetReplicasMismatch` to also fire when Pods cannot be created. Updated `KubeNodeNotReady` and `KubeNodeReadinessFlapping` to filter out cordoned Nodes. Removed `KubeAPIDown` and `KubeletDown` alerts as they are misleading. |
| Enhancement | Recording rules: Added `node_namespace_pod_container:container_cpu_usage_seconds_total:sum_rate5m`. Updated `namespace_workload_pod:kube_pod_owner:relabel` to support more workloads. Updated all apiserver rules to support both Prometheus v2 and v3 histogram bucket formats. Updated `apiserver_request:availability30d` to prevent null values. Deprecated `node_namespace_pod_container:container_cpu_usage_seconds_total:sum_irate`.        |
### 2.1.2
December 2024
Expand table
| Enhancement | Alert rules: Made the `KubeDaemonSetRolloutStuck` alert configurable. Added instance label to `KubeAggregatedAPIErrors`. Added cluster label to `KubeClientCertificateExpiration` description. |
| Enhancement | Build process/tooling: Introduced automated Go dependency updates. Security updates CVE-2024-45337 and GO-2024-3333.        |
| Fix         | Recording rules: Corrected a data calculation in cluster\_verb\_scope:apiserver\_request\_sli\_duration\_seconds\_count:increase.\*.                                                           |
### 2.1.1
November 2024
Expand table
| Enhancement | Alert rules: To better support multi-cluster environments, added `cluster` label to `KubeAPIErrorBudgetBurn`, `KubeAPITerminatedRequests`, and `KubeClientCertificateExpiration`.        |
| Enhancement | Recording rules: Improved data consistency for `cluster_verb_scope_le:apiserver_request_sli_duration_seconds_bucket:increase1h`, `cluster_verb_scope_le:apiserver_request_sli_duration_seconds_bucket:increase30d`, `cluster_verb_scope:apiserver_request_sli_duration_seconds_count:increase1h`, and `cluster_verb_scope:apiserver_request_sli_duration_seconds_count:increase30d`. |
| Enhancement | Build/process tooling: Updated dependencies to address vulnerabilities.        |
### 2.1.0
September 2024
Expand table
| Enhancement | Added alert groups:  <br />\- `kubernetes-storage` (five `KubePersistent.*` alert rules)  <br />\- `kube-apiserver-slos` (four `KubeAPIErrorBudgetBurn` alert rules)  <br />\- `kubernetes-system-apiserver` (six system API Server alert rules, including `KubeAggregatedAPIDown`).                                           |
| Enhancement | Added recording rule groups:  <br />\- `kube-apiserver-.*.rules` (32 `*apiserver.*` recording rules)  <br />\- `kubelet.rules` (including `node_quantile:kubelet_pleg_relist_duration_seconds:histogram_quantile`)  <br />\- `kube-scheduler.rules` (nine `cluster_quantile:scheduler_.*:histogram_quantile` recording rules). |
| Enhancement | Updated upstream Kubernetes mixin: Split `k8s.rules.container_resource` group into four groups to improve performance.        |
### 2.0.0
March 2024
Expand table
| Enhancement | Removed dashboards from Kubernetes Monitoring now that all views are available in the application. |
### 1.1.2
January 2023
Expand table
| Fix  | Removed duplicate recording rule group.   |
| Fix  | Corrected broken links on Home dashboard. |
### 1.1.1
November 2023
Expand table
| Fix         | Disabled “all” and multi-select on Events Data Source variable.              |
| Enhancement | Split `k8s.rules` group into seven groups to improve evaluation performance. |
### 1.1.0
October 2023
Expand table
| Feature | You can focus on cardinality exclusively related to Kubernetes by using the prebuilt Kubernetes Monitoring Cardinality dashboard. |
### 1.0.0
October 2023
Expand table
| Enhancement | Added `job` label to `KubePodNotReady` alert to be compatible with new Grafana Alerting structure. |
### 0.0.14
July 2023
Expand table
| Feature     | Added recording rules for Windows Exporter, for compatibility with node-exporter queries. |
| Enhancement | Restored events selector to prevent logs from being returned as events.                   |
| Enhancement | Updated upstream Kubernetes mixin.                                                        |
### 0.0.13
May 2023
Expand table
| Enhancement | Added ability to use any (non-empty) job label on dashboards panels and rules. |
| Enhancement | Added Node Exporter to configuration status panel.                             |
| Enhancement | Added duplicate installation detection to configuration status panel.          |
| Enhancement | Added informational tooltip to configuration status panel.                     |
### 0.0.12
April 2023
Expand table
| Fix  | Updated upstream agent-operator [jsonnet-libs](https://github.com/jsonnet-libs) to inherit a fix for relabeling related to hitting a labeling limit with Loki. |
### 0.0.11
March 2023
Expand table
| Fix  | Corrected template variables on Efficiency dashboard. |
### 0.0.10
February 2023
Expand table
| Fix  | Removed the beta tag from the Events panel on the homepage dashboard. |
### 0.0.9
February 2023
Expand table
| Fix  | Corrected Cluster aggregation for some recording rules. |
## Helm chart release notes
The following are release notes for the Kubernetes Monitoring Helm chart.
For the full list of historical releases, refer to [Grafana Kubernetes Monitoring Helm chart releases](https://github.com/grafana/k8s-monitoring-helm/releases).
### 4.0.0
Expand table
| Breaking | Rebuilt log features to remove `labelsToKeep` and split Loki and OpenTelemetry log gathering. |
| Breaking | Introduced `collectors` as a map and removed named Alloy instances.                           |
| Breaking | Converted destinations into a map.                                                            |
| Breaking | Removed Prometheus Operator Object CRDs.                                                      |
| Breaking | Extracted supplemental telemetry services from config features into their own subchart.       |
### 3.8.5
Expand table
| Enhancement | Updated Beyla, Node Exporter, OpenCost, and Prometheus Operator CRDs.                                   |
| Fix         | Fixed Application Observability failing to start when only traces are enabled and metrics are disabled. |
### 3.8.4
Expand table
| Enhancement | Updated Alloy Operator to 1.5.2.                                                       |
| Enhancement | Updated options for `secretFilters` in Pod logs features to match changes in Alloy.    |
| Fix         | Fixed `tls_config` block name to `tls` in `otelcol.auth.oauth2` for OTLP destinations. |
### 3.8.3
Expand table
| Feature     | PostgreSQL: Added `stat_statements` `exclude_databases`, `exclude_users`, and `limit` options. |
| Enhancement | Disabled the OpenCost MCP server.                                                              |
| Enhancement | Updated Alloy Operator to 1.5.1.                                                               |
| Enhancement | Added more settings for profiling features.                                                    |
### 3.8.2
Expand table
| Feature     | Added TLS configuration support for OAuth2 token endpoints across all destinations.        |
| Enhancement | Added label selectors and a completed Job filter to the Istio integration sidecar scraper and wired namespace/label selectors for Istiod discovery. |
| Enhancement | Updated Beyla auto-instrumentation config to use `instrument`/`exclude_instrument`, replacing deprecated `services`/`exclude_services`.             |
| Enhancement | Updated Beyla to 1.13.0.        |
| Enhancement | MySQL: Added `perf_schema.eventsstatements` collector options.        |
| Enhancement | Updated Node Exporter, OpenCost, and Alloy Operator.        |
| Enhancement | Updated `database_observability` setup for Alloy 1.13.x features.        |
| Fix         | Fixed finding Pod logs for static pods using the `config.mirror` annotation.        |
| Fix         | Fixed cAdvisor `includeNamespaces` filter dropping non-namespaced metrics like `machine_*`.                                                         |
| Fix         | Fixed preserving user `extraEnv` in service graph collector.        |
### 3.8.1
Expand table
| Feature | Added an option to set the semantic convention version for Application Observability span names. |
| Fix     | Fixed Java profiling so annotation targeting no longer scrapes unannotated pods.                 |
| Fix     | Fixed PostgreSQL integration `includeQuery` config camelCase issue.                              |
### 3.8.0
Expand table
| Feature     | Added the ability to enrich metrics with pod or namespace labels.                                   |
| Feature     | Added the ability to set `protobufMessage` and a shortcut for the remote\_write protocol.           |
| Feature     | Added a feature for gathering logs using PodLogs objects.                                           |
| Enhancement | Set CRI as default logs processor if runtime is unset.                                              |
| Enhancement | Automatically set required environment variables when enabling remote config.                       |
| Enhancement | Updated Windows Exporter to 0.12.3, Beyla to 1.11.0, and Prometheus Operator Object CRDs to 26.0.1. |
### 3.7.5
Expand table
| Feature     | Added configuration to specify the `overrides` section of the Span Logs Connector component for the Application Observability chart. |
| Enhancement | Updated Alloy Operator to 0.4.1.        |
### 3.7.4
Expand table
| Enhancement | Improved OTLP destination protocol validation.        |
| Enhancement | Updated Prometheus Operator Object CRDs.              |
| Fix         | Fixed indentation issues for Beyla relabel.           |
| Fix         | Added `erofs` to node-exporter filesystem exclusions. |
### 3.7.3
Expand table
| Feature     | Added eBPF sample rate for profiling.                             |
| Feature     | Added the ability to skip cluster metrics ServiceMonitor checks.  |
| Enhancement | Updated Node Exporter.                                            |
| Enhancement | Made the `loki.process` CRI stage `maxPartialLines` configurable. |
### 3.7.2
Expand table
| Feature     | Added `cloudProvider` configuration support to MySQL and PostgreSQL `databaseObservability`. |
| Enhancement | Updated Node Exporter and Alloy Operator.                                                    |
### 3.7.1
Expand table
| Enhancement | Updated Node Exporter and kube-state-metrics.                                     |
| Fix         | Fixed MySQL and PostgreSQL integrations for missing log destinations and secrets. |
### 3.7.0
Expand table
| Feature     | Added an integration for Istio sidecar and service metrics.        |
| Feature     | Added an integration for PostgreSQL, including support for Database Observability.        |
| Feature     | Added the ability to set `otel_annotations` flag for the `k8sattributes` processor.        |
| Feature     | Added more options to the `secretFilter` component in the pod logs features.        |
| Enhancement | Deployed `beyla-k8s-cache` with 1 replica by default in auto-instrumentation feature chart.        |
| Enhancement | Updated Alloy Operator and Beyla.        |
| Enhancement | Added check for the presence of kube-state-metrics or Node Exporter ServiceMonitors if `clusterMetrics` and `prometheusOperatorObjects` features are enabled. |
### 3.6.2
Expand table
| Enhancement | Updated Alloy Operator to 0.3.14.                                         |
| Fix         | Fixed extra quotes for the sending queue storage in OTLP destinations.    |
| Fix         | Fixed the inclusion of the destination secret for Service Graph instance. |
### 3.6.1
Expand table
| Feature | Added the ability to override the security context for the `waitForAlloyRemoval` Helm Hook. |
| Feature | Added the ability to define the sending queue for OTLP destinations.                        |
| Feature | Added the ability to define the remote timeout for Loki destinations.                       |
### 3.6.0
Expand table
| Feature | Added Pod Init container metrics to the kube-state-metrics allow list.                           |
| Feature | Added Database Observability to the MySQL integration.                                           |
| Feature | Added the ability to disable sending traces from Beyla to the Application Observability feature. |
| Feature | Added the ability to use ScrapeConfig objects with the Prometheus Operator Objects feature.      |
| Fix     | Updated OpenCost to include an emptydir volume mount for its config path.                        |
### 3.5.7
Expand table
| Feature     | Added the ability to set `scrape_native_histograms` for Prometheus scrape configs.                |
| Enhancement | Updated kube-state-metrics and Prometheus Operator CRDs.                                          |
| Fix         | Fixed port assignment on the etcd integration and several cluster metrics control plane services. |
| Fix         | Fixed MySQL integration.        |
### 3.5.6
Expand table
| Feature     | Added the ability to set resources for the Helm hooks.     |
| Feature     | Added the ability to set K8s Attributes Processor filters. |
| Enhancement | Updated Alloy Operator and Node Exporter.                  |
### 3.5.5
Expand table
| Enhancement | Updated Beyla chart to 1.9.9.                 |
| Fix         | Set node label for Tempo service integration. |
### 3.5.4
Expand table
| Enhancement | Updated Alloy Operator, Prometheus Operator CRDs, Beyla, and OpenCost.                       |
| Enhancement | Updated default Service Graph dimensions.                                                    |
| Fix         | Ensured Jaeger Compact and Jaeger Thrift protocols use UDP.                                  |
| Fix         | Ensured Service Graph utilizes destination defaults.                                         |
| Fix         | Fixed integration scrape intervals and timeouts to check properly inside the metrics object. |
| Fix         | Set node label for certain service integrations.                                             |
### 3.5.3
Expand table
| Feature     | Made Alloy Profiles deployable on all nodes.                           |
| Feature     | Added label selectors for the Pod Logs feature.                        |
| Feature     | Added labels and annotations to Alloy CR instances.                    |
| Enhancement | Updated Alloy Operator, Beyla, OpenCost, and Prometheus Operator CRDs. |
### 3.5.2
Expand table
| Feature | Added the ability to change pod associations. |
### 3.5.1
Expand table
| Feature     | Added the ability to set the MySQL protocol.              |
| Enhancement | Updated `prometheus-node-exporter` from 4.47.3 to 4.48.0. |
| Fix         | Fixed OpenCost validation when using `destinationsMap`.   |
### 3.5.0
Expand table
| Feature     | Created a separate feature for Pod Logs via Kubernetes API.                           |
| Feature     | Added Custom type destinations.                                                       |
| Feature     | Added the ability to set scrape timeout everywhere.                                   |
| Enhancement | Updated default resource attributes remove list and labels set for profiling feature. |
| Enhancement | Span metrics: Added spans prefilter for internal.                                     |
### 3.4.1
Expand table
| Feature     | Added the ability to set labels and annotations on the hook pod.                |
| Enhancement | Updated kube-state-metrics and OpenCost.                                        |
| Enhancement | Updated Node Exporter filesystem exclusion list.                                |
| Fix         | Fixed the `excludeNamespaces` option in the Prometheus Operator Object feature. |
### 3.4.0
Expand table
| Feature | Added default attribute remove list support for OTLP destinations.               |
| Feature | Added the ability to override attributes and set TLS settings for remote config. |
| Fix     | Properly truncated tail sampling and service grapher Alloy instances.            |
| Fix     | Removed the “wait for Alloy operator” hook.                                      |
### 3.3.2
Expand table
| Feature     | Added the ability to set the default scrape timeout for Prometheus Operator Objects feature. |
| Feature     | Added `sys.env` functions to `remoteConfig` collector.                                       |
| Enhancement | Updated OpenCost to 2.2.2 and Prometheus Operator CRDs to 23.0.0.                            |
### 3.3.1
Expand table
| Feature     | Added image pull secrets and pull policy to Helm hooks.                                 |
| Enhancement | Updated OpenCost to 2.2.        |
| Enhancement | Added transform support for span metrics.                                               |
| Fix         | Fixed `scrapeProtocols` typo.                                                           |
| Fix         | Fixed hook arm64 compatibility and prevented failure if Alloy instance already deleted. |
### 3.3.0
Expand table
| Type        | Description        |
| Feature     | Added passthrough for `k8sattributes` processor.                                             |
| Feature     | Added hooks to add finalizers and Alloy instance cleanup to prevent orphaned resources.      |
| Feature     | Added pre-install hook to wait for Alloy Operator readiness before creating Alloy resources. |
| Feature     | Added `alloy-operator.waitForReadiness` configuration option to control the timing behavior. |
| Feature     | Allowed passing destinations as a map.                                                       |
| Feature     | Allowed modifying Alloy settings in one place.                                               |
| Feature     | Added span attribute support for skip metrics generation.                                    |
| Enhancement | Improved Windows Exporter discovery rules.                                                   |
| Enhancement | Added `kube_cronjob.*` to kube-state-metrics default allow list.                             |
### 3.2.6
Expand table
| Feature     | Added the ability to set error mode for filter and transform processors. |
| Enhancement | Updated Beyla Helm chart to 1.9.2 in auto-instrumentation feature chart. |
| Fix         | Skipped Beyla-generated traces in span metrics.                          |
### 3.2.5
Expand table
| Enhancement | Updated kube-state-metrics to 6.1.4.                           |
| Fix         | Allowed destination and remote config usernames to be numbers. |
### 3.2.4
Expand table
| Enhancement | Updated Beyla, Alloy, Alloy Operator, kube-state-metrics, and Prometheus Operator CRDs. |
### 3.2.3
Expand table
| Enhancement | Updated Windows Exporter to 0.12.1.                |
| Enhancement | Updated annotation handling for profiling targets. |
| Enhancement | Included `collector.id` in span metrics transform. |
| Fix         | Fixed bad double quote in CRD validation.          |
### 3.2.2
Expand table
| Enhancement | Updated Alloy Operator to 0.3.7.                                                        |
| Enhancement | Improved how integration logs and metrics are enabled so they can be properly disabled. |
### 3.2.1
Expand table
| Enhancement | Updated Node Exporter to 4.47.3.        |
| Fix         | Fixed newline handling at the end of the Prometheus file.                                                             |
| Fix         | Removed check preventing deploying if `/var/log` or `/var/lib/docker/containers` are set when they may not be needed. |
### 3.2.0
Expand table
| Feature     | New feature: Profiles Receiver.        |
| Enhancement | Prevented Node Exporter from generating metrics about `ramfs` and `tmpfs`.                                     |
| Enhancement | Set the `job` label on sources from the Annotation Autodiscovery feature to more reasonable values.            |
| Enhancement | Set `service.namespace` and `service.instance.id` labels from typical sources when using the Pod Logs feature. |
