title: "Monitor non-standard workloads | Grafana Cloud documentation"
description: "Find non-standard workloads in Kubernetes Monitoring and understand the monitoring concerns of Argo Rollouts, Strimzi PodSets, static and unmanaged Pods, and bare Pods."
# Monitor non-standard workloads
Kubernetes ships with a handful of built-in workload controllers: `Deployment`, `StatefulSet`, `DaemonSet`, `Job`, and `CronJob`. Anything that schedules Pods through a different mechanism is “non-standard”: either a custom resource definition (CRD) managed by an operator, or Pods created with no owner reference at all.
Non-standard workloads matter for fleet visibility for two reasons:
- **Blind spots in rollup views.** Most dashboards and tools aggregate by well-known owner kinds. A Pod owned by an `argo.argoproj.io/Rollout` or `kafka.strimzi.io/KafkaNodePool` doesn’t appear in the `Deployment` or `StatefulSet` summary, leaving capacity, restart counts, and failure signals invisible at the fleet level.
- **Different failure modes.** Each controller has its own readiness model and update strategy. A canary `Rollout` failing its analysis looks nothing like a crashing `Deployment` replica. The signals and remediation paths differ.
## Find non-standard workloads in your fleet
You can find non-standard workloads, including:
- Argo Rollouts
- Strimzi Pod sets
- Unmanaged (or [static](https://kubernetes.io/docs/tasks/configure-pod-container/static-pod/)) Pods
- Bare Pods
Navigate to the **Workloads** main page and filter the **Type** column.
[Filtering for workload type](/media/docs/grafana-cloud/k8s/workload-type-sort.png)
Jobs and CronJobs have their own page with a separate **Type** filter. Refer to [Monitor jobs](/docs/grafana-cloud/monitor-infrastructure/kubernetes-monitoring/monitor-jobs/).
## Argo Rollouts
Argo Rollouts replaces the standard `Deployment` controller with a `Rollout` custom resource that adds canary and blue/green update strategies. The owner chain is `Rollout` → `ReplicaSet` → `Pod`, the same shape as a `Deployment`, so Pods are owned by `ReplicaSet` objects, not directly by the `Rollout`.
Why it matters for monitoring:
- A `Rollout` can hold traffic on the stable revision while the canary revision is still running. Pod counts alone don’t tell you which revision is active.
- `AnalysisRun` objects emit pass or fail signals tied to metric queries. A failed analysis pauses the rollout but leaves two Pod sets running simultaneously, doubling resource consumption with no `Deployment`-level alert firing.
What to watch:
- The `argo_rollout_phase` gauge: values are `Healthy`, `Progressing`, `Paused`, `Degraded`, and `Unknown`. A `Rollout` stuck in `Progressing` for an extended period often signals a failed analysis or a paused canary.
- Restart counts and OOMKill events scoped to the canary `Rollout` name label.
- The Pod-to-revision label `rollouts-pod-template-hash` to distinguish stable from canary traffic.
## Strimzi PodSets
Strimzi, the Kafka operator for Kubernetes, replaced `StatefulSet` with its own `StrimziPodSet` custom resource definition (CRD) as the default in Strimzi 0.35. `KafkaNodePool`, a separate CRD for managing node pools, became generally available in Strimzi 0.41. Pods are still first-class Kubernetes objects, but their owner chain runs through `strimzi.io` resources, not `apps/v1`.
- Kafka brokers and controllers require strict quorum. Losing one broker in a three-Node Cluster is a partial outage even if Kubernetes reports the Pod as `Running`. The JVM may be live but the broker may not have rejoined the in-sync replicas (ISR).
- Standard workload health checks (available replicas ≥ desired) don’t apply. Kafka health is expressed through Kafka-level metrics: under-replicated partitions, ISR shrink rate, and leader elections.
What to watch:
- `kafka_server_replicamanager_underreplicatedpartitions`: a non-zero value means data risk.
- The Strimzi operator condition `Ready=False` on the `Kafka` or `KafkaNodePool` custom resource.
- Pod owner labels `strimzi.io/cluster` and `strimzi.io/name` for grouping in queries.
## Static and unmanaged Pods
Static Pods are defined as manifest files on a Node’s filesystem (default: `/etc/kubernetes/manifests/`) and managed directly by the `kubelet`, not the API server’s controllers. Control-plane components (`kube-apiserver`, `kube-scheduler`, `kube-controller-manager`, and `etcd`) are typically static Pods on self-managed Clusters.
*Unmanaged* Pods are API-created Pods with no owner reference, usually the result of a `kubectl run` invocation, a misconfigured operator, or a debugging session that was never cleaned up. Modern versions of `kubectl run` create a bare Pod by default, so it’s easy to leave one behind without realizing it.
- Static Pods aren’t rescheduled if the Node fails; they’re tightly coupled to a single Node. A `NotReady` Node means the static Pod is gone until the Node recovers.
- Unmanaged Pods are rescheduling orphans. If they’re evicted or OOMKilled, they disappear permanently. They also frequently represent forgotten resource consumers that escape capacity planning.
What to watch:
- Pods without owners. In Prometheus, `kube_pod_owner{owner_kind=""}` surfaces these Pods.
- The static Pod label `kubernetes.io/config.source=file` distinguishes them from unmanaged API Pods.
- Node-scoped restarts and eviction events for static Pods tied to control-plane health.
## Bare Pods
Bare Pods are a subset of unmanaged Pods created intentionally without a controller. They’re common in batch workloads, one-off migrations, and operator-injected sidecar bootstrapping. Unlike accidental unmanaged Pods, bare Pods are a deliberate pattern, but they carry the same observability gap.
- No controller means no automatic restart on failure and no replica health signal. A bare Pod that exits with code `0` looks identical to one that crashed, so you need exit code and reason tracking explicitly.
- Bare Pods often run privileged or with elevated permissions for maintenance tasks. Tracking their lifecycle (start time, runtime, termination reason) matters for both capacity and security posture.
What to watch:
- `kube_pod_container_status_last_terminated_reason` distinguishes `OOMKilled`, `Error`, and `Completed`.
- `kube_pod_start_time` combined with the absence of a matching owner reference detects long-lived bare Pods.
- Namespace and label conventions, for example `app.kubernetes.io/managed-by=manual`, to separate intentional from accidental bare Pods.
