Monitor jobs
Monitor cron jobs and other job types
In the Kubernetes Monitoring app, use the main menu to select All jobs. Use the Cronjobs tab for schedules and the Jobs tab for individual runs. The lists show the following details across Clusters and namespaces for the time range you select.
  • A color-coded status indicator for each job
  • How jobs are distributed and where jobs are placed across the infrastructure
  • For cron jobs:
    • Last succeeded, to verify jobs are completing successfully
    • Last scheduled compared to succeeded, to view any gaps that reveal failed or skipped executions
  • For manual jobs, Pods/completions to track when the job was run
Cronjobs list
Cronjobs list
If a warning appears at the top of the page, the Clusters you selected aren’t reporting the kube_job_info or kube_cronjob_info metrics, so the lists have no jobs to show. To fix this, refer to Job data missing.
Identify job types
The Type column on the Jobs list categorizes Jobs by their owner reference. Scheduled Job means the Job was spawned by a CronJob. Other types you’ll encounter:
  • Manual Job: created directly with kubectl create job or an applied manifest, with no owner reference. There’s no automatic retry scheduling. After the Job completes or exhausts its backoffLimit, it stays until you delete it manually or its TTL expires.
  • Operator-managed Job: owned by a CRD controller rather than a CronJob. Common sources are Argo Workflows (tasks), Tekton (TaskRuns), Spark Operator (SparkApplication), Flink, and Kubeflow. The controlledBy field points to the operator’s custom resource, not a CronJob.
  • Helm hook Job: created by Helm during install, upgrade, or rollback with annotations like helm.sh/hook: pre-install. Helm may delete the Job after the hook runs, so these are short-lived and easy to miss in fleet views.
The monitoring implication differs by type. Scheduled Jobs have a CronJob you can inspect for missed schedules. Manual and Helm hook Jobs don’t, so stale Failed Jobs with no owner are the main signal to alert on.
On the Jobs tab of the Kubernetes Monitoring app’s All jobs page, click a Job name to open its detail page in the app.
Detail page of a job, open to the **Overview** tab
Detail page of a job, open to the Overview tab
With Grafana Play, you can explore and see how it works, learning from practical examples to accelerate your development. This feature can be seen on the Jobs list.
On the job detail page, the Overview tab contains:
  • Status, start time, end time, Pod status phase, logs, and events
  • CPU and memory usage, to identify any over or under provisioning as well spot any gradual increases that indicate memory leaks
  • Container logs for debugging failed runs
  • Events for identifying error messages or unexpected behavior
  • Runs table to track success/failure patterns over time, and understand duration and completion
You can further explore each job’s CPU and Memory tabs for greater insight.
To investigate a scheduled run in the Kubernetes Monitoring app, open the Cronjobs tab on the All jobs page and click the CronJob name. On its detail page, select the Alerts tab. For the steps to reach the affected Job and Pod in the app, refer to View alerts for a single object.
