title: "Monitor jobs | Grafana Cloud documentation"
description: "You can monitor manual jobs and scheduled (cron) jobs."
# Monitor jobs
## Monitor cron jobs and other job types
You can monitor manual jobs and scheduled (cron) jobs. Use the main menu to find and select **All jobs**. Use the **Cronjobs** and **Jobs** lists to view jobs across all Clusters and Namespaces, based on the time range you choose in the time range selector. You can view:
- A color-coded status indicator for each job
- How jobs are distributed and where jobs are placed across the infrastructure
- For cron jobs:
  - Last succeeded, to verify jobs are completing successfully
  - Last scheduled compared to succeeded, to view any gaps that reveal failed or skipped executions
- For manual jobs, Pods/completions to track when the job was run
[Cronjobs list](/media/docs/grafana-cloud/k8s/all-jobs-page.png)
## Identify job types
The **Type** column on the Jobs list categorizes Jobs by their owner reference. **Scheduled Job** means the Job was spawned by a CronJob. Other types you’ll encounter:
- **Manual Job**: created directly with `kubectl create job` or an applied manifest, with no owner reference. There’s no automatic retry scheduling. After the Job completes or exhausts its `backoffLimit`, it stays until you delete it manually or its TTL expires.
- **Operator-managed Job**: owned by a CRD controller rather than a CronJob. Common sources are Argo Workflows (tasks), Tekton (`TaskRun`s), Spark Operator (`SparkApplication`), Flink, and Kubeflow. The `controlledBy` field points to the operator’s custom resource, not a CronJob.
- **Helm hook Job**: created by Helm during install, upgrade, or rollback with annotations like `helm.sh/hook: pre-install`. Helm may delete the Job after the hook runs, so these are short-lived and easy to miss in fleet views.
The monitoring implication differs by type. Scheduled Jobs have a CronJob you can inspect for missed schedules. Manual and Helm hook Jobs don’t, so stale `Failed` Jobs with no owner are the main signal to alert on.
To further investigate a job, click the job name to open its detail page.
[Detail page of a job, open to the **Overview** tab](/media/docs/grafana-cloud/k8s/job-detail-page.png)
With Grafana Play, you can explore and see how it works, learning from practical examples to accelerate your development. This feature can be seen on [the Jobs list](https://play.grafana.org/a/grafana-k8s-app/navigation/all-jobs?from=now-7d&to=now&timezone=utc&refresh=1m&var-cluster=appenv-grafana-play-cluster&var-cluster=play-db-cluster).
[Try it](https://play.grafana.org/a/grafana-k8s-app/navigation/all-jobs?from=now-7d&to=now&timezone=utc&refresh=1m&var-cluster=appenv-grafana-play-cluster&var-cluster=play-db-cluster)
On the job detail page, the **Overview** tab contains:
- Status, start time, end time, Pod status phase, logs, and events
- CPU and memory usage, to identify any over or under provisioning as well spot any gradual increases that indicate memory leaks
- Container logs for debugging failed runs
- Events for identifying error messages or unexpected behavior
- Runs table to track success/failure patterns over time, and understand duration and completion
You can further explore each job’s **CPU** and **Memory** tabs for greater insight.
