Host-hours pricing for Kubernetes Monitoring
Kubernetes Monitoring is now established as a core Grafana Cloud application, and its usage is billed separately.
If you are a self-serve customer and began using Kubernetes Monitoring in Grafana Cloud after September 17, 2024, Grafana Cloud calculates Kubernetes Monitoring usage based on active host and container hours in a calendar month.
If you are a contract customer that started using Kubernetes Monitoring before September 17, 2024, your account team will work with you to transition to the new model.
Definition of active host or container
An active host or active container is any Kubernetes Node (whether it’s a virtual machine or a physical machine) or container actively sending observability signals using kube-state-metrics. Billable host hours are the total time that active hosts and active containers are monitored each month.
What is not a host
A Pod (a group of one or more containers) is not considered a host. Pods run within Nodes, which are the actual hosts.
How hours are tracked
Hourly pricing occurs whenever a host (a node) or a container sends kube-state-metrics
to Grafana Cloud.
Kubernetes Monitoring usage is billed during a calendar month by calculating:
- $0.015 per active Node hour
- $0.001 per active container hour
Billable hours are the sum of the time that active hosts send monitoring signals to Grafana Cloud during the month.
Windows nodes
If you are running Windows nodes within a Kubernetes Cluster, you are billed for host hours if kube-state-metrics
is present within the same Cluster.
Non-Prometheus telemetry data
If you use OTel-style telemetry or other data collection methods (such as VictoriaMetrics) with Kubernetes Monitoring, these methods result in a partial or empty set of data. Without the data available from the kube-state-metrics exporter, active nodes and containers can’t be detected, and you won’t be billed for host hours.
Invoice
For more detailed information about host-hours billing and your invoice, refer to Understand your Kubernetes Monitoring invoice.
Existing customers with ingestion-based billing
If you have been using Kubernetes Monitoring in Grafana Cloud prior September 17th, 2024, Grafana won’t automatically transfer your account to host-hours billing. However, if you want to migrate to this form of billing, contact support to evaluate your situation and accommodate your request where possible.
