title: "Kubernetes Monitoring | Grafana Cloud documentation"
description: "How to configure Grafana Kubernetes Monitoring and use it to monitor Kubernetes infrastructure and collect data on applications within Clusters."
# Kubernetes Monitoring
Monitor and troubleshoot your fleet with dashboards and alerts that you don’t have to create. View resource usage, and identify issues quickly. The Kubernetes Monitoring application is available in Grafana Cloud.
## Overview
The Kubernetes Monitoring app gives you what you need to understand and manage your infrastructure, including:
- A single platform for complete monitoring and visibility. You can check the health of your Kubernetes objects and troubleshoot issues without leaving the app. This helps you solve problems faster and with less effort.
- A [ready-to-use experience](/docs/grafana-cloud/monitor-infrastructure/kubernetes-monitoring/navigate-k8s-monitoring/) that includes tools for tracking cost, resource efficiency, jobs, and energy use. You also get built-in alerts, alert rules, recording rules, and predictions to help you stay ahead of problems.
## Guidance and help
Not sure where to go?
Answer a few questions and Grot will show you a helpful next step.
Start guide
Back
How do you want to monitor Kubernetes?
Answer a few questions to get started.
Get Started
[Docs
Grafana Play
Title]()
Get started
Next Start over
## Explore
[Introduction
Discover more about the advantages that Kubernetes Monitoring offers and what comes out of the box.](/docs/grafana-cloud/monitor-infrastructure/kubernetes-monitoring/intro-kubernetes-monitoring/)
[Explore your infrastructure
Dive into the features of Kubernetes Monitoring as a one-app experience.](/docs/grafana-cloud/monitor-infrastructure/kubernetes-monitoring/navigate-k8s-monitoring/)
[Configure
Get started quickly with quick setup, the easy deploy GUI that uses the Helm chart, or configure using other options including OpenTelemetry Collector. Learn how to manage and customize your configuration as well as troubleshoot it.](/docs/grafana-cloud/monitor-infrastructure/kubernetes-monitoring/configuration/)
[Manage costs
Cost views are available at every level of the app’s interface to show spending estimates and how to save.](/docs/grafana-cloud/monitor-infrastructure/kubernetes-monitoring/manage-costs/)
[Optimize resource and efficiency
Use optimization data and recommendations to optimize CPU and memory usage. Follow example use cases to handle resource issues.](/docs/grafana-cloud/monitor-infrastructure/kubernetes-monitoring/optimize-resource-usage/)
[Respond to alerts
Deal solely with alerts for Kubernetes, and manage them.](/docs/grafana-cloud/monitor-infrastructure/kubernetes-monitoring/respond-to-alerts/)
