title: "WSO2 Enterprise Integrator integration | Grafana Cloud documentation"
description: "Learn about WSO2 Enterprise Integrator Grafana Cloud integration."
# WSO2 Enterprise Integrator integration for Grafana Cloud
WSO2 Enterprise Integrator 7.1.0 is a powerful configuration-driven approach to integration, which allows developers to build integration solutions graphically.
This is a hybrid platform that enables API-centric integration and supports various integration architecture styles: microservices architecture, cloud-native architecture, or a centralized ESB architecture. This integration platform offers a graphical/configuration-driven approach to developing integrations for any of the architectural styles.
This integration includes 5 pre-built dashboards to help monitor and visualize WSO2 Enterprise Integrator metrics.
## Before you begin
In order for this integration to work, you have to enable the Prometheus endpoint on your WSO2 Enterprise Integrator nodes. Please refer to the [official documentation](https://ei.docs.wso2.com/en/7.2.0/micro-integrator/setup/observability/observability-deployment-strategy/).
## Install WSO2 Enterprise Integrator integration for Grafana Cloud
1. In your Grafana Cloud stack, click **Connections** in the left-hand menu.
2. Find **WSO2 Enterprise Integrator** and click its tile to open the integration.
3. Review the prerequisites in the **Configuration Details** tab and set up Grafana Alloy to send WSO2 Enterprise Integrator metrics to your Grafana Cloud instance.
4. Click **Install** to add this integration’s pre-built dashboards to your Grafana Cloud instance, and you can start monitoring your WSO2 Enterprise Integrator setup.
## Configuration snippets for Grafana Alloy
### Advanced mode
To instruct Grafana Alloy to scrape your WSO2 Enterprise Integrator instances, **manually** copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
### Advanced metrics snippets
Alloy ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```alloy
discovery.relabel "metrics_integrations_integrations_wso2_enterprise_integrator" {
	targets = [{
		__address__ = "wso2-ei-node:9201",
	rule {
		target_label = "instance"
	rule {
		target_label = "wso2_cluster"
		replacement  = "<your-cluster-name>"
prometheus.scrape "metrics_integrations_integrations_wso2_enterprise_integrator" {
	targets      = discovery.relabel.metrics_integrations_integrations_wso2_enterprise_integrator.output
	forward_to   = [prometheus.remote_write.metrics_service.receiver]
	job_name     = "integrations/wso2-enterprise-integrator"
	metrics_path = "/metric-service/metrics"
To monitor your WSO2 Enterprise Integrator instance, you must use a [discovery.relabel](/docs/alloy/latest/reference/components/discovery.relabel/) component to discover your WSO2 Enterprise Integrator Prometheus endpoint and apply appropriate labels, followed by a [prometheus.scrape](/docs/alloy/latest/reference/components/prometheus.scrape) component to scrape it.
Configure the following properties within each `discovery.relabel` component:
- `__address__`: The address to your WSO2 Enterprise Integrator Prometheus metrics endpoint.
- `instance` label: `constants.hostname` sets the `instance` label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this WSO2 Enterprise Integrator instance.
- `wso2_cluster`: The `wso2_cluster` label to group your WSO2 Enterprise Integrator instances within a cluster. Set the same value for all nodes within your cluster.
If you have multiple WSO2 Enterprise Integrator servers to scrape, configure one `discovery.relabel` for each and scrape them by including each under `targets` within the `prometheus.scrape` component.
## Dashboards
The WSO2 Enterprise Integrator integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- WSO2 API Metrics
- WSO2 Inbound Endpoint Metrics
- WSO2 Integration Cluster Metrics
- WSO2 Integration Node Metrics
- WSO2 Proxy Service Metrics
**Cluster Overview**
**Node Overview**
**Apis Overview**
## Metrics
The most important metrics provided by the WSO2 Enterprise Integrator integration, which are used on the pre-built dashboards, are as follows:
- jvm\_memory\_bytes\_max
- jvm\_memory\_bytes\_used
- jvm\_threads\_state
- process\_cpu\_seconds\_total
- process\_max\_fds
- process\_open\_fds
- up
- wso2\_integration\_api\_latency\_seconds
- wso2\_integration\_api\_request\_count\_error\_total
- wso2\_integration\_api\_request\_count\_total
- wso2\_integration\_inbound\_endpoint\_latency\_seconds
- wso2\_integration\_inbound\_endpoint\_request\_count\_error\_total
- wso2\_integration\_inbound\_endpoint\_request\_count\_total
- wso2\_integration\_proxy\_inbound\_endpoint\_count\_total
- wso2\_integration\_proxy\_latency\_seconds
- wso2\_integration\_proxy\_request\_count\_error\_total
- wso2\_integration\_proxy\_request\_count\_total
- wso2\_integration\_server\_up
- wso2\_integration\_service\_up
## Changelog
md ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```md
# 1.0.0 - February 2024
* Update mixin to replace all Angular panels with React based panels.
# 0.0.6 - September 2023
# 0.0.5 - February 2023
* Bugfix - remove unused link
# 0.0.4 - January 2023
* Add job variable filter to all dashboards.
# 0.0.3 - September 2022
* Update dashboard panels descriptions.
# 0.0.2 - October 2021
* Update mixin to latest version:
  - Update queries to use $__rate_interval
# 0.0.1 - September 2021
* Initial release
## Cost
By connecting your WSO2 Enterprise Integrator instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see [Active series and dpm usage](/docs/grafana-cloud/fundamentals/active-series-and-dpm/) and [Cloud tier pricing](/products/cloud/pricing/).
