Windows integration for Grafana Cloud
Monitor Windows instances using Grafana Alloy. The integration comes with pre installed dashboards, which give an overview of your Windows’ fleet at once, a single host overview, as well as additional dashboards that provide more metrics for further system performance analysis. The integration also provides dashboard showing Windows event logs.
This integration includes 8 useful alerts and 5 pre-built dashboards to help monitor and visualize Windows metrics and logs.
Before you begin
This integration relies on a Grafana Alloy instance running on a Windows machine. See the following sections for details.
Install Windows integration for Grafana Cloud
- Find Windows and click its tile to open the integration.
- Review the prerequisites in the Configuration Details tab and set up Grafana Alloy to send Windows metrics and logs to your Grafana Cloud instance.
- Click Install to add this integration’s pre-built dashboards and alerts to your Grafana Cloud instance, and you can start monitoring your Windows setup.
Simple mode
These snippets are configured to scrape a single Windows server with Grafana Alloy running locally.
Integrations snippets
prometheus.exporter.windows "integrations_windows_exporter" {
enabled_collectors = ["cpu", "memory", "pagefile","logical_disk", "net", "os", "service", "system", "time", "diskdrive"]
discovery.relabel "integrations_windows_exporter" {
targets = prometheus.exporter.windows.integrations_windows_exporter.targets
rule {
target_label = "job"
replacement = "integrations/windows_exporter"
rule {
target_label = "instance"
replacement = constants.hostname
prometheus.scrape "integrations_windows_exporter" {
targets = discovery.relabel.integrations_windows_exporter.output
forward_to = [prometheus.relabel.integrations_windows_exporter.receiver]
job_name = "integrations/windows_exporter"
prometheus.relabel "integrations_windows_exporter" {
rule {
source_labels = ["volume"]
regex = "HarddiskVolume.*"
action = "drop"
}Logs snippets
windows
loki.process "logs_integrations_windows_exporter_application" {
forward_to = [loki.write.grafana_cloud_loki.receiver]
stage.json {
expressions = {
level = "levelText",
source = "source",
stage.labels {
values = {
level = "",
source = "",
loki.relabel "logs_integrations_windows_exporter_application" {
forward_to = [loki.process.logs_integrations_windows_exporter_application.receiver]
rule {
source_labels = ["computer"]
target_label = "agent_hostname"
loki.source.windowsevent "logs_integrations_windows_exporter_application" {
locale = 1033
eventlog_name = "Application"
bookmark_path = "./bookmarks-app.xml"
poll_interval = "0s"
use_incoming_timestamp = true
forward_to = [loki.relabel.logs_integrations_windows_exporter_application.receiver]
labels = {
instance = constants.hostname,
job = "integrations/windows_exporter",
loki.process "logs_integrations_windows_exporter_system" {
stage.json {
expressions = {
source = "source",
stage.labels {
values = {
level = "",
source = "",
loki.relabel "logs_integrations_windows_exporter_system" {
forward_to = [loki.process.logs_integrations_windows_exporter_system.receiver]
rule {
loki.source.windowsevent "logs_integrations_windows_exporter_system" {
locale = 1033
eventlog_name = "System"
bookmark_path = "./bookmarks-sys.xml"
forward_to = [loki.relabel.logs_integrations_windows_exporter_system.receiver]
labels = {
}Advanced mode
To instruct Grafana Alloy to scrape your Windows server, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
rule {
rule {
rule {
action = "drop"
}This integration uses the prometheus.exporter.windows component to collect system metrics.
The supplied configuration is tuned to exclude any metrics from the exporter which are not used by the integration’s dashboards, alerts, or recording rules. If a broader configuration which includes additional metrics is desired, the prometheus.exporter.windows component can be adjusted accordingly.
Advanced logs snippets
windows
stage.json {
expressions = {
source = "source",
stage.labels {
values = {
level = "",
source = "",
rule {
locale = 1033
labels = {
stage.json {
expressions = {
source = "source",
stage.labels {
values = {
level = "",
source = "",
rule {
locale = 1033
labels = {
}This integration uses the loki.source.windowsevent component to collect the application and system events.
If you wish to capture other Windows events, or text log files, refer to the loki.source.windowsevent and loki.source.file components documentation.
Kubernetes instructions
Before you begin with Kubernetes
These instructions assume the use of the Kubernetes Monitoring Helm chart.
Configuration snippets for Kubernetes Helm chart
To scrape your Windows nodes of the Kubernetes cluster, ensure that your Kubernetes Monitoring Helm chart values has these configuration snippets.
Metrics snippets
alloy-metrics:
enabled: true
clusterMetrics:
enabled: true
windows-exporter:
enabled: true
metricsTuning:
useDefaultAllowList: falseDashboards
The Windows integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- Windows CPU and system
- Windows disks and filesystems
- Windows fleet overview
- Windows logs
- Windows overview
Windows overview
Windows logs
Alerts
The Windows integration includes the following useful alerts:
Metrics
The most important metrics provided by the Windows integration, which are used on the pre-built dashboards and Prometheus alerts, are as follows:
- up
- windows_cpu_interrupts_total
- windows_cpu_logical_processor
- windows_cpu_time_total
- windows_cs_logical_processors
- windows_cs_physical_memory_bytes
- windows_disk_drive_status
- windows_logical_disk_avg_read_requests_queued
- windows_logical_disk_avg_write_requests_queued
- windows_logical_disk_free_bytes
- windows_logical_disk_idle_seconds_total
- windows_logical_disk_read_bytes_total
- windows_logical_disk_read_seconds_total
- windows_logical_disk_reads_total
- windows_logical_disk_size_bytes
- windows_logical_disk_write_bytes_total
- windows_logical_disk_write_seconds_total
- windows_logical_disk_writes_total
- windows_memory_physical_free_bytes
- windows_memory_physical_total_bytes
- windows_net_bytes_received_total
- windows_net_bytes_sent_total
- windows_net_packets_outbound_discarded_total
- windows_net_packets_outbound_errors_total
- windows_net_packets_received_discarded_total
- windows_net_packets_received_errors_total
- windows_net_packets_received_unknown_total
- windows_os_info
- windows_os_paging_limit_bytes
- windows_os_physical_memory_free_bytes
- windows_os_timezone
- windows_pagefile_limit_bytes
- windows_service_status
- windows_system_boot_time_timestamp
- windows_system_boot_time_timestamp_seconds
- windows_system_context_switches_total
- windows_system_processor_queue_length
- windows_system_system_up_time
- windows_time_computed_time_offset_seconds
- windows_time_ntp_client_time_sources
- windows_time_ntp_round_trip_delay_seconds
- windows_time_timezone
Changelog
# 1.4.1 - July 2026
* Remove Asserts CPU/memory/network resource recording rules now covered natively by the Asserts base pipeline
# 1.4.0 - December 2025
* Add support for metric names introduced in windows_exporter 0.31.0 and Alloy 1.11.0
* Update to windows-observ-lib with backward-compatible metric name changes
# 1.3.1 - July 2025
Agent snippets:
- Fix list of recommended windows collectors in Advanced mode.
# 1.3.0 - July 2025
* Add support for metric names introduced in windows_exporter 0.30.0 and Alloy 1.9.0.
* Agent snippets:
- Update list of recommended windows collectors in 1.9.0: 'cs' is removed and 'memory','pagefile' are removed.
# 1.2.1 - May 2025
* Fix advanced filtered metrics snippet for Alloy.
# 1.2.0 - May 2025
* Add snippets for Kubernetes Windows nodes.
# 1.1.5 - April 2025
* Update to the latest windows mixin
- Fix fleet drill-down link
- Add WindowsNodeHasRebooted alert
# 1.1.4 - January 2025
* Fix status panel metrics datasource
# 1.1.3 - January 2025
* Fix status panel logs query
* Update mixin
# 1.1.2 - November 2024
* Update status panel check queries
# 1.1.1 - October 2024
* Agent snippets:
- Fix alloy advanced filter in prometheus.relabel "integrations_windows_exporter"
# 1.1.0 - July 2024
* Add Asserts support
# 1.0.0 - October 2023
* Grafana dashboards three-tier view:
- Fleet dashboard with with drill down and data links to other dashes
- Host overview dashboard
- Advanced metrics dashboards (Logs dashboard, CPU and system dashboard, Disks)
* Add new alerts
- NTP sync alerts
- Add disk status alert
* Add annotations across all dashboards for the following events:
- Reboot
- Failed windows service
- Critical eventlog annotation
* Update agent snippets:
- Add time collector
- Extract additional 'level' label from event logs
- Drop disk metrics for 'HarddiskVolume.*' volumes by default
* Other:
- Variable selector 'hostname' no longer used on dashboards, 'instance' label is used instead.
# 0.0.9 - August 2023
# 0.0.8 - August 2023
* Updates agent configuration:
* Separate bookmark path for system and application event logs
* Update instructions to avoid repeat
# 0.0.7 - August 2023
# 0.0.6 - January 2023
* Add basic alerts
# 0.0.5 - September 2022
* Fix confusing thresholds for C:\ Free space
# 0.0.4 - May 2022
* Add logs support
* Update mixin to latest with logs dashboard
* Update instructions for enabling logs integration
# 0.0.3 - May 2022
* Move mixin to jsonnet-libs
* Update metadata with screenshots
* Update mixin version to latest
# 0.0.2 - October 2021
* Update mixin to latest version:
- Update queries to use $__rate_interval
# 0.0.1 - May 2021
* Initial releaseCost
By connecting your Windows instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
