Wildfly integration for Grafana Cloud
Wildfly is a modular & lightweight application server that handles deploying and managing several Java applications. The Wildfly integration uses the Grafana Agent to collect metrics and logs for monitoring a Wildfly instance. Including metrics for monitoring sessions, deployments, network traffic, and datasource connections. This also includes monitoring server log files of a Wildfly instance which provides valuable information for usage and operations of the instance.
This integration supports Wildfly 27.X onwards.
This integration includes 2 useful alerts and 2 pre-built dashboards to help monitor and visualize Wildfly metrics and logs.
Before you begin
In order to collect metrics from Wildfly, ensure the metric subsystem is enabled by following the official documentation.
To enable session metrics, run the following command in the CLI:
/subsystem=undertow:write-attribute(name=statistics-enabled,value=true)
To enable transaction metrics, run the following command in the CLI:
/subsystem=transactions:write-attribute(name=statistics-enabled, value=true)
Wildfly has authentication enabled by default (for Wildfly management interfaces). This includes a simple username and password from an established user. To setup a user, simply run the add-user.sh
script inside the Wildfly installation’s bin
folder. Once script is complete, add your new <wildfly_user>
and <wildfly_password>
to the username and password fields underneath basic_auth
. However, in the case that Wildlfly authentication is not enabled, basic_auth
may need to be removed in your metrics config.
More info on user creation can be found here.
The CLI is launched using jboss-cli.sh
or jboss-cli.bat
located in the WildFly bin
directory. For more information on default directory structure visit Getting Started Guide.
Next, connect to the WildFly instance. This is done by running connect
command.
./bin/jboss-cli.sh
You are disconnected at the moment. Type 'connect' to connect to the server
or 'help' for the list of supported commands.
[disconnected /]
[disconnected /] connect
[domain@localhost:9990 /]
[domain@localhost:9990 /] quit
Closed connection to localhost:9990
To terminate the session type quit
Install Wildfly integration for Grafana Cloud
- Find Wildfly and click its tile to open the integration.
- Review the prerequisites in the Configuration Details tab and set up Grafana Agent to send Wildfly metrics and logs to your Grafana Cloud instance.
- Click Install to add this integration’s pre-built dashboards and alerts to your Grafana Cloud instance, and you can start monitoring your Wildfly setup.
Simple mode
These snippets are configured to scrape a single Wildfly instance running locally with default ports.
Logs snippets
darwin
local.file_match "logs_integrations_integrations_wildfly" {
path_targets = [{
__address__ = "localhost",
__path__ = "/opt/wildfly/standalone/log/server.log",
instance = constants.hostname,
job = "integrations/wildfly",
loki.process "logs_integrations_integrations_wildfly" {
forward_to = [loki.write.grafana_cloud_loki.receiver]
stage.multiline {
firstline = "\\d+-\\d+-\\d+ \\d+:\\d+:\\d+,\\d+"
max_lines = 0
max_wait_time = "3s"
loki.source.file "logs_integrations_integrations_wildfly" {
targets = local.file_match.logs_integrations_integrations_wildfly.targets
forward_to = [loki.process.logs_integrations_integrations_wildfly.receiver]
linux
path_targets = [{
stage.multiline {
max_lines = 0
windows
path_targets = [{
stage.multiline {
max_lines = 0
Advanced mode
To instruct Grafana Alloy to scrape your Wildfly instances, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
Advanced metrics snippets
discovery.relabel "metrics_integrations_integrations_wildfly" {
targets = [{
__address__ = "localhost:9990",
rule {
target_label = "instance"
replacement = constants.hostname
prometheus.scrape "metrics_integrations_integrations_wildfly" {
targets = discovery.relabel.metrics_integrations_integrations_wildfly.output
job_name = "integrations/wildfly"
basic_auth {
username = "<wildfly_user>"
password = "<wildfly_password>"
To monitor your Wildfly instance, you must use a discovery.relabel component to discover your Wildfly Prometheus endpoint and apply appropriate labels, followed by a prometheus.scrape component to scrape it.
component:
__address__
: The address to your Wildfly Prometheus metrics endpoint.instance
label:constants.hostname
sets theinstance
label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this Wildfly instance. Make sure this label value is the same for all telemetry data collected for this instance.
If you have multiple Wildfly servers to scrape, configure one discovery.relabel
for each and scrape them by including each under targets
within the prometheus.scrape
component.
Advanced logs snippets
darwin
path_targets = [{
stage.multiline {
max_lines = 0
To monitor your Wildfly instance logs, you will use a combination of the following components:
local.file_match defines where to find the log file to be scraped. Change the following properties according to your environment:
__address__
: The Wildfly instance address__path__
: The path to the log file.instance
sets theinstance
loki.process defines how to process logs before sending it to Loki.
loki.source.file sends logs to Loki.
linux
path_targets = [{
stage.multiline {
max_lines = 0
__address__
sets theinstance
windows
path_targets = [{
stage.multiline {
max_lines = 0
__address__
sets theinstance
or jboss-cli.bat
command.
./bin/jboss-cli.sh
[disconnected /]
Post-install configuration for the Wildfly integration
After ensuring subsystem metrics are enabled, instruct the Grafana Agent to scrape Metrics from a WildFly instance.
Make sure to change targets
in the snippet according to your environment.
If you want to show logs and metrics signals in your dashboards, ensure the following:
instance
label must be set to a value that uniquely identifies your Wildfly Instance. Please replace the default hostname value according to your environment - it should be set manually.job
must be set tointegrations/wildfly
In the case that Wildlfly authentication is not enabled, basic_auth
- job_name: integrations/wildfly
metrics_path: /metrics
basic_auth:
username: '<wildfly_user>'
password: '<wildfly_password>'
relabel_configs:
- replacement: '<your-instance-name>'
target_label: instance
static_configs:
- targets: ["localhost:9990"]
static_configs:
- targets: [localhost]
labels:
instance: '<your-instance-name>'
job: integrations/wildfly
__path__: /opt/wildfly/standalone/log/server.log
pipeline_stages:
- multiline:
# match on timestamp. Format should be like '2023-01-20 09:38:23,454'
# but feel free to modify to match your logs
firstline: '\d+-\d+-\d+ \d+:\d+:\d+,\d+'
Refer to the following Grafana Agent configuration for a complete example that contains all the snippets used for the Wildfly integration. This example also includes metrics that are sent to monitor your Grafana Agent instance.
Dashboards
The Wildfly integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- Wildfly datasource
- Wildfly overview
Wildfly overview
Wildfly overview (Sessions)
Wildfly datasource dashboard
Alerts
The Wildfly integration includes the following useful alerts:
Metrics
The most important metrics provided by the Wildfly integration, which are used on the pre-built dashboards and Prometheus alerts, are as follows:
- up
- wildfly_batch_jberet_active_count
- wildfly_datasources_pool_idle_count
- wildfly_datasources_pool_in_use_count
- wildfly_transactions_number_of_aborted_transactions_total
- wildfly_transactions_number_of_inflight_transactions
- wildfly_transactions_number_of_transactions_total
- wildfly_undertow_active_sessions
- wildfly_undertow_bytes_received_total_bytes
- wildfly_undertow_bytes_sent_total_bytes
- wildfly_undertow_error_count_total
- wildfly_undertow_expired_sessions_total
- wildfly_undertow_rejected_sessions_total
- wildfly_undertow_request_count_total
Changelog
# 1.0.0 - May 2024
* Added cluster selector to dashboards for kubernetes support
# 0.0.3 - September 2023
# 0.0.2 - August 2023
# 0.0.1 - April 2023
- Initial release
Cost
By connecting your Wildfly instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
