title: "Velero integration | Grafana Cloud documentation"
description: "Learn about Velero Grafana Cloud integration."
# Velero integration for Grafana Cloud
Velero is an open-source tool that helps backup and migrate Kubernetes cluster resources and persistent volumes. It allows you to create backups of your Kubernetes objects and restore them in case of disasters or when moving to a different environment. Velero provides a simple and reliable way to protect your Kubernetes applications and data, ensuring continuity and portability across various platforms.
This integration supports Velero 1.13+ and Kubernetes 1.16+
This integration includes 4 useful alerts and 3 pre-built dashboards to help monitor and visualize Velero metrics and logs.
## Before you begin
### 1. Check pre-requisites specific to the Velero integration
#### Metrics
Metrics
Velero exposes a Prometheus metrics endpoint, `/metrics`, on Velero containers by default.
You can verify that this endpoint is enabled by running the following commands:
Bash ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```bash
kubectl port-forward -n <namespace> <name-of-velero-pod> 8085:8085 &
curl http://localhost:8085/metrics
#### Logs
By default, Velero sends logs to stdout.
You can verify this by running the following command:
```bash
kubectl logs -n <namespace> <name-of-velero-pod>
### 2. Configuration &amp; Installation
#### Kubernetes Monitoring Helm chart configuration
To use this integration, modify your Kubernetes Monitoring Helm chart deployment with these configuration snippets. Metrics snippet
Copy the following and add to the `.extraConfig` value of the Kubernetes Monitoring Helm chart.
YAML ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```yaml
discovery.relabel "velero" {
  targets = discovery.kubernetes.pods.targets
  rule {
    action        = "keep"
    source_labels = ["__meta_kubernetes_pod_label_component"]
    regex         = "velero"
  rule {
    source_labels = ["__meta_kubernetes_pod_container_port_number"]
    regex = "8085"
    action = "keep"
  rule {
    source_labels = ["__meta_kubernetes_pod_name"]
    target_label = "instance"
prometheus.scrape "velero" {
  job_name     = "integrations/velero"
  targets      = discovery.relabel.velero.output
  forward_to   = [prometheus.relabel.metrics_service.receiver]
#### Logs snippet
Copy the following and add to the `.logs.extraConfig` value of the Kubernetes Monitoring Helm chart.
```yaml
discovery.relabel "logs_velero" {
  targets = discovery.relabel.pod_logs.output
  rule {
    action        = "keep"
    regex         = "velero"
  rule {
    action = "replace"
    target_label  = "pod"
loki.source.kubernetes "logs_velero" {
  targets    = discovery.relabel.logs_velero.output
  forward_to = [loki.process.logs_velero.receiver]
loki.process "logs_velero" {
  forward_to = [loki.process.logs_service.receiver]
  stage.cri {}
  stage.multiline {
    firstline = "time=\"(\\d{4}-\\d{2}-\\d{2}T\\d{2}:\\d{2}:\\d{2}Z)\""
  stage.regex {
    expression = "time=\"(\\d{4}-\\d{2}-\\d{2}T\\d{2}:\\d{2}:\\d{2}Z)\" level=(?P<level>\\w+)"
  stage.labels {
    values = {
      level  = "",
For more information about how to set values for `.extraConfig` or `.logs.extraConfig`, see the (Helm chart documentation)\[https://github.com/grafana/k8s-monitoring-helm/blob/main/charts/k8s-monitoring/docs/UsingExtraConfig.md].
## Dashboards
The Velero integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- Velero cluster view
- Velero logs
- Velero overview
**Velero overview (Backups)**
**Velero overview (snapshots)**
**Velero cluster view**
## Alerts
The Velero integration includes the following useful alerts:
Expand table
| Alert                        | Description                                       |
| VeleroBackupFailure          | Critical: Velero backup failures detected.        |
| VeleroHighBackupDuration     | Warning: Velero backups taking longer than usual. |
| VeleroHighRestoreFailureRate | Critical: Velero restore failures detected.       |
| VeleroUpStatus               | Critical: Velero is down.                         |
## Metrics
The most important metrics provided by the Velero integration, which are used on the pre-built dashboards and Prometheus alerts, are as follows:
- up
- velero\_backup\_attempt\_total
- velero\_backup\_duration\_seconds\_bucket
- velero\_backup\_failure\_total
- velero\_backup\_success\_total
- velero\_backup\_tarball\_size\_bytes
- velero\_backup\_validation\_failure\_total
- velero\_csi\_snapshot\_attempt\_total
- velero\_csi\_snapshot\_success\_total
- velero\_restore\_attempt\_total
- velero\_restore\_failed\_total
- velero\_restore\_success\_total
- velero\_restore\_validation\_failed\_total
- velero\_volume\_snapshot\_attempt\_total
- velero\_volume\_snapshot\_failure\_total
- velero\_volume\_snapshot\_success\_total
## Changelog
md ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```md
# 1.0.1 - November 2024
- Update status panel check queries
# 1.0.0 - April 2024
- Initial release
## Cost
By connecting your Velero instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see [Active series and dpm usage](/docs/grafana-cloud/fundamentals/active-series-and-dpm/) and [Cloud tier pricing](/products/cloud/pricing/).
