title: "TensorFlow Serving integration | Grafana Cloud documentation"
description: "Learn about TensorFlow Serving Grafana Cloud integration."
# TensorFlow Serving integration for Grafana Cloud
TensorFlow Serving is an end-to-end open source platform for machine learning. The TensorFlow Serving integration uses Grafana Alloy to collect metrics for monitoring a TensorFlow Serving instance, including aspects such as model request latency, model runtime latency, batch queuing latency, graph build time, and graph run time. The integration also supports the TensorFlow Serving Docker container logs being scraped by Alloy using Promtail. An accompanying dashboard is provided to visualize these metrics and logs.
This integration supports TensorFlow Serving 2.10.0+.
This integration includes 2 useful alerts and 1 pre-built dashboard to help monitor and visualize TensorFlow Serving metrics and logs.
## Before you begin
In order for the integration to work, you must configure TensorFlow Serving’s built in Prometheus metrics server.
It is required to first enable the Prometheus metrics as [described in the TensorFlow Serving documentation](https://www.tensorflow.org/tfx/serving/serving_config#monitoring_configuration).
Special configuration is also needed in order to enable the the Prometheus batching metrics. Batching configuration can be enabled as [described in the TensorFlow Serving documentation](https://www.tensorflow.org/tfx/serving/serving_config#batching_configuration).
## Install TensorFlow Serving integration for Grafana Cloud
1. In your Grafana Cloud stack, click **Connections** in the left-hand menu.
2. Find **TensorFlow Serving** and click its tile to open the integration.
3. Review the prerequisites in the **Configuration Details** tab and set up Grafana Alloy to send TensorFlow Serving metrics and logs to your Grafana Cloud instance.
4. Click **Install** to add this integration’s pre-built dashboard and alerts to your Grafana Cloud instance, and you can start monitoring your TensorFlow Serving setup.
## Configuration snippets for Grafana Alloy
### Simple mode
These snippets are configured to scrape a single TensorFlow Serving instance running locally with default ports.
First, **manually** copy and append the following snippets into your alloy configuration file.
### Metrics snippets
Alloy ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```alloy
discovery.relabel "metrics_integrations_integrations_tensorflow" {
	targets = [{
		__address__ = "localhost:8501",
	rule {
		target_label = "instance"
prometheus.scrape "metrics_integrations_integrations_tensorflow" {
	targets      = discovery.relabel.metrics_integrations_integrations_tensorflow.output
	forward_to   = [prometheus.remote_write.metrics_service.receiver]
	job_name     = "integrations/tensorflow"
	metrics_path = "/monitoring/prometheus/metrics"
### Logs snippets
#### linux
```alloy
discovery.docker "logs_integrations_integrations_tensorflow" {
	host             = "unix:///var/run/docker.sock"
	refresh_interval = "5s"
	filter {
		name   = "name"
		values = ["tensorflow"]
discovery.relabel "logs_integrations_integrations_tensorflow" {
	targets = []
	rule {
		source_labels = ["__meta_docker_container_name"]
		target_label  = "name"
		replacement   = "tensorflow"
	rule {
		target_label  = "job"
		replacement   = "integrations/tensorflow"
	rule {
loki.source.docker "logs_integrations_integrations_tensorflow" {
	targets          = discovery.docker.logs_integrations_integrations_tensorflow.targets
	forward_to       = [loki.write.grafana_cloud_loki.receiver]
	relabel_rules    = discovery.relabel.logs_integrations_integrations_tensorflow.rules
### Advanced mode
To instruct Grafana Alloy to scrape your TensorFlow Serving instances, **manually** copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
### Advanced metrics snippets
```alloy
	targets = [{
	rule {
To monitor your TensorFlow Serving instance, you must use a [discovery.relabel](/docs/alloy/latest/reference/components/discovery.relabel/) component to discover your TensorFlow Serving Prometheus endpoint and apply appropriate labels, followed by a [prometheus.scrape](/docs/alloy/latest/reference/components/prometheus.scrape) component to scrape it.
Configure the following properties within each `discovery.relabel` component:
- `__address__`: The address to your TensorFlow Serving Prometheus metrics endpoint.
- `instance` label: `constants.hostname` sets the `instance` label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this TensorFlow Serving instance. Make sure this label value is the same for all telemetry data collected for this instance.
If you have multiple TensorFlow Serving servers to scrape, configure one `discovery.relabel` for each and scrape them by including each under `targets` within the `prometheus.scrape` component.
### Advanced logs snippets
#### linux
```alloy
	filter {
		name   = "name"
	targets = []
	rule {
	rule {
	rule {
To monitor your TensorFlow Serving instance logs, you will use a combination of the following components:
- [discovery.docker](/docs/alloy/latest/reference/components/discovery.docker) discovers docker containers. Make sure to match the filters to your environment.
- [loki.source.docker](/docs/alloy/latest/reference/components/loki.source.docker) reads log entries from Docker containers.
- [discovery.relabel](/docs/alloy/latest/reference/components/discovery.relabel) defines any relabeling needed before sending logs to Loki.
## Kubernetes instructions
Instructions for Kubernetes
### Before you begin with Kubernetes
**Please note**: These instructions assume the use of the [Kubernetes Monitoring Helm chart](https://github.com/grafana/k8s-monitoring-helm)
### Configuration snippets for Kubernetes Helm chart
To scrape your Tensorflow Serving instances, **manually** modify your Kubernetes Monitoring Helm chart with these configuration snippets.
Replace any values between the angle brackets `<>` in the provided snippets with your desired configuration values.
#### Metrics snippets
```alloy
alloy-metrics:
    extraConfig: |-
        discovery.kubernetes "tensorflow_metrics" {
            role = "pod"
            selectors {
                role = "pod"
                label = "<tensorflow_pod_label_name>=<tensorflow_pod_label_value>"
        discovery.relabel "tensorflow_metrics" {
            targets = discovery.kubernetes.tensorflow_metrics.targets
            rule {
                source_labels = ["__address__"]
                regex         = "([^:]+)(:[0-9]+)?"
                replacement   = "\${1}"
        prometheus.scrape "tensorflow_metrics" {
            targets      = discovery.relabel.tensorflow_metrics.output
            forward_to   = [prometheus.remote_write.grafana_cloud_metrics.receiver]
#### Logs snippets
```alloy
podLogs:
    extraDiscoveryRules: |-
        rule {
            source_labels = ["__meta_kubernetes_namespace", "__meta_kubernetes_pod_name"]
            separator     = ":"
            regex         = "(<tensorflow_namespace>:tensorflow.*)"
            target_label  = "integration"
        rule {
            source_labels = ["integration", "__meta_kubernetes_pod_ip"]
            separator = ":"
            regex = "tensorflow:(.*)"
        rule {
            source_labels = ["integration", "__meta_kubernetes_pod_node_name"]
            separator = ":"
            target_label = "__host__"
        rule {
            source_labels = ["integration"]
            regex = "tensorflow"
        rule {
## Dashboards
The TensorFlow Serving integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- TensorFlow Serving overview
**TensorFlow Serving overview dashboard 1**
**TensorFlow Serving overview dashboard 2**
## Alerts
The TensorFlow Serving integration includes the following useful alerts:
Expand table
| Alert                                    | Description                                                       |
| TensorFlowModelRequestHighErrorRate      | Critical: More than 30% of all model requests are not successful. |
| TensorFlowServingHighBatchQueuingLatency | Warning: Batch queuing latency more than 5000000µs.               |
## Metrics
The most important metrics provided by the TensorFlow Serving integration, which are used on the pre-built dashboard and Prometheus alerts, are as follows:
- :tensorflow:core:graph\_build\_calls
- :tensorflow:core:graph\_build\_time\_usecs
- :tensorflow:core:graph\_run\_time\_usecs
- :tensorflow:core:graph\_runs
- :tensorflow:serving:batching\_session:queuing\_latency\_count
- :tensorflow:serving:batching\_session:queuing\_latency\_sum
- :tensorflow:serving:request\_count
- :tensorflow:serving:request\_latency\_count
- :tensorflow:serving:request\_latency\_sum
- :tensorflow:serving:runtime\_latency\_count
- :tensorflow:serving:runtime\_latency\_sum
- up
## Changelog
md ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```md
# 1.0.0 - April 2024
* Added cluster selector to dashboards for kubernetes support
* Added default cluster label to agent config
* Bump version to 1.0.0
# 0.0.4 - September 2023
# 0.0.3 - August 2023
# 0.0.2 - January 2023
* Updated integration name to TensorFlow Serving
# 0.0.1 - December 2022
* Initial Release
## Cost
By connecting your TensorFlow Serving instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see [Active series and dpm usage](/docs/grafana-cloud/fundamentals/active-series-and-dpm/) and [Cloud tier pricing](/products/cloud/pricing/).
