Squid integration for Grafana Cloud
Squid is a popular open-source proxy server that is used to improve web performance and provide content caching for web clients. The Squid integration uses the Grafana agent to collect metrics for monitoring a Squid instance, including aspects such as cache hits & miss service time, cache hit ratios, client and server requests, server object swaps, and DNS lookup service time. The integration also supports Squid logs being scraped by the agent using Promtail. An accompanying dashboard is provided to visualize these metrics and logs.
This integration supports Squid 5+.
This integration includes 5 useful alerts and 1 pre-built dashboard to help monitor and visualize Squid metrics and logs.
Before you begin
This integration monitors a Squid proxy server instance.
In order to scrape these metrics, you must have a running and reachable Squid instance.
Install Squid integration for Grafana Cloud
- Find Squid and click its tile to open the integration.
- Review the prerequisites in the Configuration Details tab and set up Grafana Agent to send Squid metrics and logs to your Grafana Cloud instance.
- Click Install to add this integration’s pre-built dashboard and alerts to your Grafana Cloud instance, and you can start monitoring your Squid setup.
Simple mode
These snippets are configured to scrape a single Squid instance running locally with default ports.
Logs snippets
darwin
local.file_match "logs_integrations_integrations_squid" {
path_targets = [{
__address__ = "localhost",
__path__ = "/var/log/squid/cache.log",
instance = constants.hostname,
job = "integrations/squid",
__path__ = "/var/log/squid/access.log",
loki.source.file "logs_integrations_integrations_squid" {
targets = local.file_match.logs_integrations_integrations_squid.targets
forward_to = [loki.write.grafana_cloud_loki.receiver]
linux
path_targets = [{
windows
path_targets = [{
Advanced mode
To instruct Grafana Alloy to scrape your Squid instances, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
prometheus.exporter.squid "integrations_squid" {
address = "<squid_hostname>:<squid_port>"
discovery.relabel "integrations_squid" {
targets = prometheus.exporter.squid.integrations_squid.targets
rule {
target_label = "instance"
replacement = constants.hostname
prometheus.scrape "integrations_squid" {
targets = discovery.relabel.integrations_squid.output
job_name = "integrations/squid"
This integrations uses the prometheus.exporter.squid component to generate metrics from a Squid instance.
For the full array of configuration options, refer to the prometheus.exporter.squid component reference documentation.
This exporter must be linked with a discovery.relabel component to apply the necessary relabelings.
For each Squid instance to be monitored you must create a pair of these components.
component:
instance
label:constants.hostname
sets theinstance
label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this Squid instance. Make sure this label value is the same for all telemetry data collected for this instance.
You can then scrape them by including each discovery.relabel
under targets
within the prometheus.scrape component.
Advanced logs snippets
darwin
path_targets = [{
To monitor your Squid instance logs, you will use a combination of the following components:
local.file_match defines where to find the log file to be scraped. Change the following properties according to your environment:
__address__
: The Squid instance address__path__
: The path to the log file.instance
sets theinstance
loki.source.file sends logs to Loki.
linux
path_targets = [{
__address__
sets theinstance
windows
path_targets = [{
__address__
sets theinstance
Post-install configuration for the Squid integration
This integration supports metrics and logs from a Squid instance. It is configured to work with the Squid Exporter which has beeen integrated into the Grafana Agent.
Enable the integration by adding the snippets below to your agent configuration file.
If you want to show logs and metrics signals correlated in your dashboards, as a single pane of glass, ensure the following:
job
and instance
label values must match for metrics and logs scrape config in your agent configuration file.
job
label must be set to integrations/squid
(already configured in the snippets).
instance
label must be set to a value that uniquely identifies your Squid server. Please replace the default hostname value according to your environment - it must be set manually.
address
label must be set to the corresponding <squid_hostname>:<squid_port>
of your squid instance. Default Squid port is 3128
username
and password
are optional parameters for the squid integration to be used for Squid Authentication.
integrations:
squid:
enabled: true
address: <squid_hostname>:<squid_port>
logs:
configs:
scrape_configs:
- job_name: integrations/squid
static_configs:
- targets:
- localhost
labels:
job: integrations/squid
instance: <your-instance>
__path__: /var/log/squid/cache.log
- targets:
- localhost
labels:
__path__: /var/log/squid/access.log
Below integrations
squid:
enabled: true
address: '<squid_hostname>:<squid_port>'
relabel_configs:
- replacement: '<your-instance-name>'
target_label: instance
static_configs:
- targets:
- localhost
labels:
instance: '<your-instance-name>'
- targets:
- localhost
labels:
Refer to the following Grafana Agent configuration for a complete example that contains all the snippets used for the Squid integration. This example also includes metrics that are sent to monitor your Grafana Agent instance.
Dashboards
The Squid integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- Squid overview
Squid overview dashboard (client)
Squid overview dashboard (server)
Alerts
The Squid integration includes the following useful alerts:
Metrics
The most important metrics provided by the Squid integration, which are used on the pre-built dashboard and Prometheus alerts, are as follows:
- squid_Cache_Hits_50
- squid_Cache_Hits_75
- squid_Cache_Hits_95
- squid_Cache_Misses_50
- squid_Cache_Misses_75
- squid_Cache_Misses_95
- squid_DNS_Lookups_50
- squid_DNS_Lookups_75
- squid_DNS_Lookups_95
- squid_HTTP_Requests_All_50
- squid_HTTP_Requests_All_75
- squid_HTTP_Requests_All_95
- squid_client_http_errors_total
- squid_client_http_hit_kbytes_out_bytes_total
- squid_client_http_hits_total
- squid_client_http_kbytes_in_kbytes_total
- squid_client_http_kbytes_out_kbytes_total
- squid_client_http_requests_total
- squid_server_ftp_errors_total
- squid_server_ftp_kbytes_in_kbytes_total
- squid_server_ftp_kbytes_out_kbytes_total
- squid_server_ftp_requests_total
- squid_server_http_errors_total
- squid_server_http_kbytes_in_kbytes_total
- squid_server_http_kbytes_out_kbytes_total
- squid_server_http_requests_total
- squid_server_other_errors_total
- squid_server_other_kbytes_in_kbytes_total
- squid_server_other_kbytes_out_kbytes_total
- squid_server_other_requests_total
- squid_swap_ins_total
- squid_swap_outs_total
- up
Changelog
# 1.0.0 - July 2024
* Support for the Kubernetes plugin
# 0.0.3 - September 2023
# 0.0.2 - August 2023
# 0.0.1 - July 2023
* Initial Release
Cost
By connecting your Squid instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
