title: "Squid integration | Grafana Cloud documentation"
description: "Learn about Squid Grafana Cloud integration."
# Squid integration for Grafana Cloud
Squid is a popular open-source proxy server that is used to improve web performance and provide content caching for web clients. The Squid integration uses Grafana Alloy to collect metrics for monitoring a Squid instance, including aspects such as cache hits &amp; miss service time, cache hit ratios, client and server requests, server object swaps, and DNS lookup service time. The integration also supports Squid logs being scraped by Alloy using Promtail. An accompanying dashboard is provided to visualize these metrics and logs.
This integration supports Squid 5+.
This integration includes 5 useful alerts and 2 pre-built dashboards to help monitor and visualize Squid metrics and logs.
## Before you begin
This integration monitors a Squid proxy server instance.
In order to scrape these metrics, you must have a running and reachable Squid instance.
## Install Squid integration for Grafana Cloud
1. In your Grafana Cloud stack, click **Connections** in the left-hand menu.
2. Find **Squid** and click its tile to open the integration.
3. Review the prerequisites in the **Configuration Details** tab and set up Grafana Alloy to send Squid metrics and logs to your Grafana Cloud instance.
4. Click **Install** to add this integration’s pre-built dashboards and alerts to your Grafana Cloud instance, and you can start monitoring your Squid setup.
## Configuration snippets for Grafana Alloy
### Simple mode
These snippets are configured to scrape a single Squid instance running locally with default ports.
First, **manually** copy and append the following snippets into your alloy configuration file.
### Logs snippets
#### darwin
Alloy ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```alloy
local.file_match "logs_integrations_integrations_squid" {
	path_targets = [{
		__address__ = "localhost",
		__path__    = "/var/log/squid/cache.log",
		instance    = constants.hostname,
		job         = "integrations/squid",
		__path__    = "/var/log/squid/access.log",
loki.source.file "logs_integrations_integrations_squid" {
	targets    = local.file_match.logs_integrations_integrations_squid.targets
	forward_to = [loki.write.grafana_cloud_loki.receiver]
#### linux
```alloy
	path_targets = [{
#### windows
```alloy
	path_targets = [{
### Advanced mode
To instruct Grafana Alloy to scrape your Squid instances, **manually** copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
### Advanced integrations snippets
```alloy
prometheus.exporter.squid "integrations_squid" {
	address = "<squid_hostname>:<squid_port>"
discovery.relabel "integrations_squid" {
	targets = prometheus.exporter.squid.integrations_squid.targets
	rule {
		target_label = "instance"
prometheus.scrape "integrations_squid" {
	targets    = discovery.relabel.integrations_squid.output
	job_name   = "integrations/squid"
This integrations uses the [prometheus.exporter.squid](/docs/alloy/latest/reference/components/prometheus.exporter.squid/) component to generate metrics from a Squid instance.
For the full array of configuration options, refer to the [prometheus.exporter.squid](/docs/alloy/latest/reference/components/prometheus.exporter.squid/) component reference documentation.
This exporter must be linked with a [discovery.relabel](/docs/alloy/latest/reference/components/discovery.relabel/) component to apply the necessary relabelings.
For each Squid instance to be monitored you must create a pair of these components.
Configure the following properties within each `discovery.relabel` component:
- `instance` label: `constants.hostname` sets the `instance` label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this Squid instance. Make sure this label value is the same for all telemetry data collected for this instance.
You can then scrape them by including each `discovery.relabel` under `targets` within the [prometheus.scrape](/docs/alloy/latest/reference/components/prometheus.scrape/) component.
### Advanced logs snippets
#### darwin
```alloy
	path_targets = [{
To monitor your Squid instance logs, you will use a combination of the following components:
- [local.file\_match](/docs/alloy/latest/reference/components/local.file_match) defines where to find the log file to be scraped. Change the following properties according to your environment:
  - `__address__`: The Squid instance address
  - `__path__`: The path to the log file.
- [loki.source.file](/docs/alloy/latest/reference/components/loki.source.file) sends logs to Loki.
#### linux
```alloy
	path_targets = [{
#### windows
```alloy
	path_targets = [{
## Kubernetes instructions
Instructions for Kubernetes
### Before you begin with Kubernetes
**Please note**: These instructions assume the use of the [Kubernetes Monitoring Helm chart](https://github.com/grafana/k8s-monitoring-helm)
##### Metrics
To monitor your Squid instance metrics in `k8s`, you will need the following info to correctly configure the scrape snippets:
- `squid-service`: the name of the squid service
- `squid-namespace`: the namespace where the Squid pod(s) live
- `squid-port`: the configured port of your Squid deployment
##### Logs
To monitor your Squid instance logs in `k8s`, you will use a combination of the following components:
**Please note**: There are two `loki.process` components. One for the cache logs and another for access logs.
- [discovery.relabel](/docs/agent/latest/flow/reference/components/discovery.relabel/) is used to filter logs from the various components. Change the following properties according to your environment:
  - `squid-namespace`: The namespace where the Squid pod(s) live.
  - `squid-pod-name`: Regex to match the name of the Squid pod(s).
  - `squid-cluster-name`: The name of your Squid cluster.
  - `instance` label: This value needs to match the `address` value provided to the metrics exporter component.
Update the provided logs snippet for the Kubernetes Monitoring Helm chart with the variables above configured as appropriate.
### Configuration snippets for Kubernetes Helm chart
To scrape your Squid instances, **manually** modify your Kubernetes Monitoring Helm chart with these configuration snippets.
Replace any values between the angle brackets `<>` in the provided snippets with your desired configuration values.
#### Metrics snippets
```alloy
alloy-metrics:
    extraConfig: |-
        prometheus.exporter.squid "squid_exporter" {
            address = "<squid-service>.<squid-namespace>.svc.cluster.local:<squid-port>"
        prometheus.scrape "integrations_squid_default" {
            targets      = prometheus.exporter.squid.squid_exporter.targets
            forward_to   = [prometheus.remote_write.grafana_cloud_metrics.receiver]
#### Logs snippets
```alloy
alloy-logs:
    extraConfig: |-
        loki.process "squid_cache_logs_process" {
            forward_to = [loki.relabel.squid_cache_logs_label.receiver]
            stage.drop {
                expression = \`^\\d+\\.\\d+\`
            stage.multiline {
                firstline = \`^\\d{4}/\\d{2}/\\d{2} \\d{2}:\\d{2}:\\d{2}\`
            stage.regex {
                expression = \`^\\d{4}/\\d{2}/\\d{2} \\d{2}:\\d{2}:\\d{2}\`
        loki.process "squid_access_logs_process" {
            forward_to = [loki.relabel.squid_access_logs_label.receiver]
            stage.drop {
                expression = \`^\\s+listening port: \\d+\`
            stage.drop {
            stage.regex {
        loki.relabel "squid_cache_logs_label" {
            forward_to = [loki.write.logs_service.receiver]
            rule {
                replacement = "cache"
                target_label = "log_type"
        loki.relabel "squid_access_logs_label" {
            rule {
                replacement = "access"
        discovery.relabel "squid_logs" {
            targets = discovery.relabel.pod_logs.output
            rule {
                replacement  = "<your-squid-cluster>"
                target_label = "squid_cluster"
            rule {
                replacement   = "integrations/squid"
                target_label  = "job"
            rule {
                replacement   = "<squid-exporter-address-value>"
        loki.source.kubernetes "squid_logs" {
            targets      = discovery.relabel.squid_logs.output
            forward_to   = [loki.process.squid_access_logs_process.receiver,loki.process.squid_cache_logs_process.receiver]
## Dashboards
The Squid integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- Squid logs
- Squid overview
**Squid overview dashboard (client)**
**Squid overview dashboard (server)**
**Squid logs dashboard**
## Alerts
The Squid integration includes the following useful alerts:
Expand table
| Alert                             | Description        |
| SquidHighHTTPServerRequestErrors  | Critical: There are a high number of HTTP server errors.                    |
| SquidHighFTPServerRequestErrors   | Critical: There are a high number of FTP server request errors.             |
| SquidHighOtherServerRequestErrors | Critical: There are a high number of other server request errors.           |
| SquidHighClientRequestErrors      | Critical: There are a high number of HTTP client request errors.            |
| SquidLowCacheHitRatio             | Warning: The cache hit ratio has fallen below the configured threshold (%). |
## Metrics
The most important metrics provided by the Squid integration, which are used on the pre-built dashboards and Prometheus alerts, are as follows:
- squid\_Cache\_Hits\_50
- squid\_Cache\_Hits\_75
- squid\_Cache\_Hits\_95
- squid\_Cache\_Misses\_50
- squid\_Cache\_Misses\_75
- squid\_Cache\_Misses\_95
- squid\_DNS\_Lookups\_50
- squid\_DNS\_Lookups\_75
- squid\_DNS\_Lookups\_95
- squid\_HTTP\_Requests\_All\_50
- squid\_HTTP\_Requests\_All\_75
- squid\_HTTP\_Requests\_All\_95
- squid\_client\_http\_errors\_total
- squid\_client\_http\_hit\_kbytes\_out\_bytes\_total
- squid\_client\_http\_hits\_total
- squid\_client\_http\_kbytes\_in\_kbytes\_total
- squid\_client\_http\_kbytes\_out\_kbytes\_total
- squid\_client\_http\_requests\_total
- squid\_server\_ftp\_errors\_total
- squid\_server\_ftp\_kbytes\_in\_kbytes\_total
- squid\_server\_ftp\_kbytes\_out\_kbytes\_total
- squid\_server\_ftp\_requests\_total
- squid\_server\_http\_errors\_total
- squid\_server\_http\_kbytes\_in\_kbytes\_total
- squid\_server\_http\_kbytes\_out\_kbytes\_total
- squid\_server\_http\_requests\_total
- squid\_server\_other\_errors\_total
- squid\_server\_other\_kbytes\_in\_kbytes\_total
- squid\_server\_other\_kbytes\_out\_kbytes\_total
- squid\_server\_other\_requests\_total
- squid\_swap\_ins\_total
- squid\_swap\_outs\_total
- up
## Changelog
md ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```md
# 1.1.0 - April 2026
* Updated dashboards to follow new stylistic standards
* Added a Squid logs dashboard dedicated to viewing log data
# 1.0.0 - July 2024
* Support for the Kubernetes plugin
# 0.0.3 - September 2023
# 0.0.2 - August 2023
# 0.0.1 - July 2023
* Initial Release
## Cost
By connecting your Squid instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see [Active series and dpm usage](/docs/grafana-cloud/fundamentals/active-series-and-dpm/) and [Cloud tier pricing](/products/cloud/pricing/).
