title: "Ruby Rack integration | Grafana Cloud documentation"
description: "Learn about Ruby Rack Grafana Cloud integration."
# Ruby Rack integration for Grafana Cloud
The Rack webserver interface for Ruby allows easily building web applications. This integration enables Grafana Alloy to send metrics to Grafana Cloud along with a useful default dashboard for visualization.
This integration includes 1 pre-built dashboard to help monitor and visualize Ruby Rack metrics.
## Before you begin
This integration monitors a Rack web application (e.g. any Sinatra or Rails application) using the `Collector` middleware included in the Ruby [Prometheus client library](https://github.com/prometheus/client_ruby).
To get started, add the Prometheus client library to your Gemfile:
rb ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```rb
gem 'prometheus-client'
Then change the `config.ru` file of your Rack application to use the Prometheus `Collector` and `Exporter` middlewares before running your app:
```rb
require 'prometheus/middleware/collector'
require 'prometheus/middleware/exporter'
use Prometheus::Middleware::Collector
use Prometheus::Middleware::Exporter
run Sinatra::Application
You can refer to this example [Sinatra app](https://github.com/grafana/ruby-sinatra-app) for a complete setup of the Prometheus client library.
## Install Ruby Rack integration for Grafana Cloud
1. In your Grafana Cloud stack, click **Connections** in the left-hand menu.
2. Find **Ruby Rack** and click its tile to open the integration.
3. Review the prerequisites in the **Configuration Details** tab and set up Grafana Alloy to send Ruby Rack metrics to your Grafana Cloud instance.
4. Click **Install** to add this integration’s pre-built dashboard to your Grafana Cloud instance, and you can start monitoring your Ruby Rack setup.
## Configuration snippets for Grafana Alloy
### Simple mode
These snippets are configured to scrape a single Ruby Rack instance running locally with default ports.
First, **manually** copy and append the following snippets into your alloy configuration file.
### Metrics snippets
Alloy ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```alloy
discovery.relabel "metrics_integrations_integrations_ruby_rack" {
	targets = [{
		__address__ = "localhost:9292",
	rule {
		target_label = "instance"
prometheus.scrape "metrics_integrations_integrations_ruby_rack" {
	targets    = discovery.relabel.metrics_integrations_integrations_ruby_rack.output
	job_name   = "integrations/ruby-rack"
### Advanced mode
To instruct Grafana Alloy to scrape your Ruby Rack instances, **manually** copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
### Advanced metrics snippets
```alloy
	targets = [{
	rule {
To monitor your Ruby Rack instance, you must use a [discovery.relabel](/docs/alloy/latest/reference/components/discovery.relabel/) component to discover your Ruby Rack Prometheus endpoint and apply appropriate labels, followed by a [prometheus.scrape](/docs/alloy/latest/reference/components/prometheus.scrape) component to scrape it.
Configure the following properties within each `discovery.relabel` component:
- `__address__`: The address to your Ruby Rack Prometheus metrics endpoint.
- `instance` label: `constants.hostname` sets the `instance` label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this Ruby Rack instance.
If you have multiple Ruby Rack servers to scrape, configure one `discovery.relabel` for each and scrape them by including each under `targets` within the `prometheus.scrape` component.
## Dashboards
The Ruby Rack integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- Ruby Rack application overview
**Ruby Rack Overview**
## Metrics
The most important metrics provided by the Ruby Rack integration, which are used on the pre-built dashboard, are as follows:
- http\_server\_request\_duration\_seconds\_bucket
- http\_server\_request\_duration\_seconds\_count
- http\_server\_request\_duration\_seconds\_sum
- http\_server\_requests\_total
- up
## Changelog
md ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```md
# 1.0.0 - February 2024
* Update mixin to replace all Angular panels with React based panels.
# 0.0.4 - September 2023
# 0.0.3 - September 2022
* Update dashboard panels descriptions.
# 0.0.2 - October 2021
* Update mixin to latest version:
  - Update queries to use $__rate_interval
# 0.0.1 - February 2021
* Initial release
## Cost
By connecting your Ruby Rack instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see [Active series and dpm usage](/docs/grafana-cloud/fundamentals/active-series-and-dpm/) and [Cloud tier pricing](/products/cloud/pricing/).
