title: "Redis Enterprise integration | Grafana Cloud documentation"
description: "Learn about Redis Enterprise Grafana Cloud integration."
# Redis Enterprise integration for Grafana Cloud
Redis Enterprise is an enterprise-grade deployment strategy for Redis, the popular and efficient database used for caching, message brokering, and data streaming. Redis Enterprise provides deployment solutions and tools for creating and maintaining both on-prem and cloud solutions.
This integration includes useful metrics to monitor Redis Enterprise deployments. Metrics like memory usage, CPU usage, replication lag, networking and log data can help teams discern, identify and visualize their Redis Enterprise environments, allowing you to monitor your environment down to the clusters, node and database level.
This integration supports Redis Enterprise software versions v6.X+.
This integration includes 8 useful alerts and 4 pre-built dashboards to help monitor and visualize Redis Enterprise metrics and logs.
## Before you begin
You must configure your Redis Enterprise cluster to export Prometheus metrics for the integration to work properly.
If you are using Redis Enterprise Cloud to manage installs/deployments, the lowest possible tier that provisions [advanced monitoring](https://docs.redis.com/latest/rc/databases/monitor-performance/) is the [Fixed plan](https://redis.com/redis-enterprise-cloud/pricing/).
You can access Prometheus metrics out-of-the-box if you use [Redis Cloud](https://redis.io/cloud/) with a Pro plan.
Generally metrics are exposed on port `8070` and are only accessible from within the cluster for security reasons. Therefore, ensure Grafana Alloy can reach the internal endpoint of your environment.
If you deploy to Kubernetes using the [Redis Enterprise operator](https://redis.io/docs/latest/integrate/redis-data-integration/installation/install-k8s/), please ensure that Grafana Alloy is installed in the same cluster or that Alloy can reach the metrics endpoint.
## Install Redis Enterprise integration for Grafana Cloud
1. In your Grafana Cloud stack, click **Connections** in the left-hand menu.
2. Find **Redis Enterprise** and click its tile to open the integration.
3. Review the prerequisites in the **Configuration Details** tab and set up Grafana Alloy to send Redis Enterprise metrics and logs to your Grafana Cloud instance.
4. Click **Install** to add this integration’s pre-built dashboards and alerts to your Grafana Cloud instance, and you can start monitoring your Redis Enterprise setup.
## Configuration snippets for Grafana Alloy
### Advanced mode
To instruct Grafana Alloy to scrape your Redis Enterprise instances, **manually** copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
### Advanced metrics snippets
Alloy ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```alloy
discovery.relabel "metrics_integrations_integrations_redis_enterprise" {
	targets = [{
		__address__ = "<your-redis-enterprise-exporter>:8070",
	rule {
		target_label = "redis_cluster"
		replacement  = "<your-cluster-name>"
	rule {
		target_label = "instance"
prometheus.scrape "metrics_integrations_integrations_redis_enterprise" {
	targets    = discovery.relabel.metrics_integrations_integrations_redis_enterprise.output
	job_name   = "integrations/redis-enterprise"
	scheme     = "https"
	tls_config {
		insecure_skip_verify = true
To monitor your Redis Enterprise instance, you must use a [discovery.relabel](/docs/alloy/latest/reference/components/discovery.relabel/) component to discover your Redis Enterprise Prometheus endpoint and apply appropriate labels, followed by a [prometheus.scrape](/docs/alloy/latest/reference/components/prometheus.scrape) component to scrape it.
Configure the following properties within each `discovery.relabel` component:
- `__address__`: The address to your Redis Enterprise Prometheus metrics endpoint.
- `instance` label: `constants.hostname` sets the `instance` label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this Redis Enterprise instance. Make sure this label value is the same for all telemetry data collected for this instance.
- `redis_cluster`: The `redis_cluster` label to group your Redis Enterprise instances within a cluster. Set the same value for all nodes within your cluster.
If you have multiple Redis Enterprise servers to scrape, configure one `discovery.relabel` for each and scrape them by including each under `targets` within the `prometheus.scrape` component.
### Advanced logs snippets
#### linux
```alloy
local.file_match "logs_integrations_integrations_redis_enterprise" {
	path_targets = [{
		__address__   = "localhost",
		__path__      = "/var/opt/redislabs/log/redis-*.log",
		instance      = constants.hostname,
		job           = "integrations/redis-enterprise",
		redis_cluster = "<your-cluster-name>",
loki.source.file "logs_integrations_integrations_redis_enterprise" {
	targets    = local.file_match.logs_integrations_integrations_redis_enterprise.targets
	forward_to = [loki.write.grafana_cloud_loki.receiver]
To monitor your Redis Enterprise instance logs, you will use a combination of the following components:
- [local.file\_match](/docs/alloy/latest/reference/components/local.file_match) defines where to find the log file to be scraped. Change the following properties according to your environment:
  - `__address__`: The Redis Enterprise instance address
  - `__path__`: database logs are generally found at `/var/opt/redislabs/log/redis.log`, adjust to match your environment.
- [loki.source.file](/docs/alloy/latest/reference/components/loki.source.file) sends logs to Loki.
You will also need to add the `alloy` user to the `redislabs` group to get logs. Run the following command to configure the user as required:
sh ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```sh
sudo usermod -a -G redislabs alloy
## Dashboards
The Redis Enterprise integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- Redis Enterprise databases
- Redis Enterprise logs
- Redis Enterprise nodes
- Redis Enterprise overview
**Redis Enterprise overview (1/2)**
**Redis Enterprise overview (2/2)**
**Redis Enterprise node overview (1/2)**
## Alerts
The Redis Enterprise integration includes the following useful alerts:
Expand table
| Alert                                   | Description        |
| RedisEnterpriseClusterOutOfMemory       | Critical: Cluster has run out of memory.                                                     |
| RedisEnterpriseNodeNotResponding        | Critical: A node in the Redis Enterprise cluster is offline or unreachable.                  |
| RedisEnterpriseDatabaseNotResponding    | Critical: A database in the Redis Enterprise cluster is offline or unreachable.              |
| RedisEnterpriseShardNotResponding       | Critical: A shard in the Redis Enterprise cluster is offline or unreachable.                 |
| RedisEnterpriseNodeHighCPUUtilization   | Warning: Node CPU usage is above the configured threshold.                                   |
| RedisEnterpriseHighMemUtilization       | Warning: Node memory utilization is above the configured threshold.                          |
| RedisEnterpriseAverageLatencyIncreasing | Warning: Operation latency is above the configured threshold.                                |
| RedisEnterpriseKeyEvictionsIncreasing   | Warning: The number of evicted objects is greater than or equal to the configured threshold. |
## Metrics
The most important metrics provided by the Redis Enterprise integration, which are used on the pre-built dashboards and Prometheus alerts, are as follows:
- bdb\_avg\_latency
- bdb\_avg\_read\_latency
- bdb\_avg\_write\_latency
- bdb\_conns
- bdb\_crdt\_ingress\_bytes\_decompressed
- bdb\_crdt\_syncer\_ingress\_bytes
- bdb\_crdt\_syncer\_local\_ingress\_lag\_time
- bdb\_crdt\_syncer\_status
- bdb\_egress\_bytes
- bdb\_evicted\_objects
- bdb\_expired\_objects
- bdb\_ingress\_bytes
- bdb\_instantaneous\_ops\_per\_sec
- bdb\_mem\_frag\_ratio
- bdb\_mem\_size\_lua
- bdb\_memory\_limit
- bdb\_no\_of\_keys
- bdb\_read\_hits
- bdb\_read\_misses
- bdb\_read\_req
- bdb\_up
- bdb\_used\_memory
- bdb\_write\_req
- node\_available\_memory
- node\_avg\_latency
- node\_conns
- node\_cpu\_system
- node\_cpu\_user
- node\_egress\_bytes
- node\_ephemeral\_storage\_free
- node\_ingress\_bytes
- node\_persistent\_storage\_free
- node\_total\_req
- node\_up
- redis\_up
- redis\_used\_memory
- up
## Changelog
md ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```md
# 1.1.0 - March 2026
* Updated dashboards to follow new stylistic standards
# 1.0.0 - December 2025
* Chore: Fix incorrect semver to 1.0.0. No further changes
# 0.0.3 - September 2023
# 0.0.2 - August 2023
# 0.0.1 - April 2023
* Initial release
## Cost
By connecting your Redis Enterprise instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see [Active series and dpm usage](/docs/grafana-cloud/fundamentals/active-series-and-dpm/) and [Cloud tier pricing](/products/cloud/pricing/).
