title: "rclone integration | Grafana Cloud documentation"
description: "Learn about rclone Grafana Cloud integration."
# rclone integration for Grafana Cloud
Rclone is a command line program to manage files on Cloud storage. It is a feature rich alternative to Cloud vendors’ web storage interfaces. Over 40 Cloud storage products support rclone including S3 object stores, business and consumer file storage services, and standard transfer protocols.
This integration includes 1 pre-built dashboard to help monitor and visualize rclone metrics.
## Before you begin
In order for rclone to emit metrics you must run it with the `--rc-enable-metrics`. This requires either `--rc-no-auth` to disable authentication, or an `--rc-user` and `--rc-pass` to enable basic authentication for the endpoint.
For example, to run rclone with the remote control endpoint, enabling metrics, and with basic authentication:
![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```none
rclone rcd --rc-user <user> --rc-pass <rclone123> --rc-web-gui --rc-web-gui-no-open-browser --rc-enable-metrics --rc-no-auth --rc-addr :5572
## Install rclone integration for Grafana Cloud
1. In your Grafana Cloud stack, click **Connections** in the left-hand menu.
2. Find **rclone** and click its tile to open the integration.
3. Review the prerequisites in the **Configuration Details** tab and set up Grafana Alloy to send rclone metrics to your Grafana Cloud instance.
4. Click **Install** to add this integration’s pre-built dashboard to your Grafana Cloud instance, and you can start monitoring your rclone setup.
## Configuration snippets for Grafana Alloy
### Simple mode
These snippets are configured to scrape a single rclone instance running locally with default ports.
First, **manually** copy and append the following snippets into your alloy configuration file.
### Metrics snippets
Alloy ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```alloy
discovery.relabel "metrics_integrations_integrations_rclone" {
	targets = [{
		__address__ = "localhost:5572",
	rule {
		target_label = "instance"
prometheus.scrape "metrics_integrations_integrations_rclone" {
	targets    = discovery.relabel.metrics_integrations_integrations_rclone.output
	job_name   = "integrations/rclone"
### Advanced mode
To instruct Grafana Alloy to scrape your rclone instances, **manually** copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
### Advanced metrics snippets
```alloy
	targets = [{
	rule {
To monitor your rclone instance, you must use a [discovery.relabel](/docs/alloy/latest/reference/components/discovery.relabel/) component to discover your rclone Prometheus endpoint and apply appropriate labels, followed by a [prometheus.scrape](/docs/alloy/latest/reference/components/prometheus.scrape) component to scrape it.
Configure the following properties within each `discovery.relabel` component:
- `__address__`: The address to your rclone Prometheus metrics endpoint.
- `instance` label: `constants.hostname` sets the `instance` label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this rclone instance.
If you have multiple rclone servers to scrape, configure one `discovery.relabel` for each and scrape them by including each under `targets` within the `prometheus.scrape` component.
## Dashboards
The rclone integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- rclone
**Overview**
## Metrics
The most important metrics provided by the rclone integration, which are used on the pre-built dashboard, are as follows:
- rclone\_bytes\_transferred\_total
- rclone\_checked\_files\_total
- rclone\_dirs\_deleted\_total
- rclone\_errors\_total
- rclone\_files\_deleted\_total
- rclone\_files\_renamed\_total
- rclone\_files\_transferred\_total
- rclone\_speed
- up
## Changelog
md ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```md
# 1.0.0 - December 2025
* Chore: Fix incorrect semver to 1.0.0. No further changes
# 0.0.3 - September 2023
# 0.0.2 - January 2023
* Add dashboard screenshots
# 0.0.1 - January 2022
* Initial release
## Cost
By connecting your rclone instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see [Active series and dpm usage](/docs/grafana-cloud/fundamentals/active-series-and-dpm/) and [Cloud tier pricing](/products/cloud/pricing/).
