title: "Pinecone integration | Grafana Cloud documentation"
description: "Learn about Pinecone Grafana Cloud integration."
# Pinecone integration for Grafana Cloud
Pinecone is a serverless vector database designed for building AI applications. It provides long-term memory for AI systems, enabling semantic search, similarity search, and retrieval-augmented generation (RAG) workflows. This integration monitors Pinecone serverless indexes using Pinecone’s built-in Prometheus exporter.
This integration requires a Pinecone Standard or Enterprise plan.
This integration includes 5 useful alerts and 1 pre-built dashboard to help monitor and visualize Pinecone metrics.
## Before you begin
#### Prerequisites
- A [Pinecone](https://www.pinecone.io/) Standard or Enterprise plan.
- A Pinecone API key. Create one in the [Pinecone console](https://app.pinecone.io/) under **API Keys**.
- Your Pinecone project ID (found in the console URL or in project settings).
#### Metrics
Pinecone exposes metrics via its built-in Prometheus exporter. The integration uses HTTP discovery to find scrape targets from the Pinecone API. No exporter or extra components need to be run; configuration is done in Grafana Alloy.
## Install Pinecone integration for Grafana Cloud
1. In your Grafana Cloud stack, click **Connections** in the left-hand menu.
2. Find **Pinecone** and click its tile to open the integration.
3. Review the prerequisites in the **Configuration Details** tab and set up Grafana Alloy to send Pinecone metrics to your Grafana Cloud instance.
4. Click **Install** to add this integration’s pre-built dashboard and alerts to your Grafana Cloud instance, and you can start monitoring your Pinecone setup.
## Configuration snippets for Grafana Alloy
### Simple mode
These snippets use HTTP discovery to find Pinecone scrape targets from the Pinecone API.
Replace `<your-project-id>` with your Pinecone project ID and `<your-api-key>` with your API key in the snippet below.
**Manually** copy and append the following into your Alloy configuration file.
### Integrations snippets
Alloy ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```alloy
discovery.http "pinecone" {
  url = "https://api.pinecone.io/prometheus/projects/<your-project-id>/metrics/discovery"
  refresh_interval = "1m"
  http_headers = {
    "User-Agent" = ["source_tag=grafana"],
  authorization {
    type = "Bearer"
    credentials = "<your-api-key>"
prometheus.scrape "pinecone" {
  targets    = discovery.http.pinecone.targets
  job_name   = "integrations/pinecone"
## Dashboards
The Pinecone integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- Pinecone overview
**Pinecone overview**
**Pinecone overview write operations**
**Pinecone overview read operations**
## Alerts
The Pinecone integration includes the following useful alerts:
Expand table
| Alert                             | Description        |
| PineconeHighQueryLatencyWarning   | Warning: Query latency exceeds warning thresholds, indicating performance degradation in query operations.        |
| PineconeHighQueryLatencyCritical  | Critical: Query latency exceeds critical thresholds, indicating performance degradation in query operations.      |
| PineconeHighUpsertLatencyWarning  | Warning: Upsert latency exceeds warning thresholds, indicating performance degradation in upsert operations.      |
| PineconeHighUpsertLatencyCritical | Critical: Upsert latency exceeds critical thresholds, indicating performance degradation in upsert operations.    |
| PineconeUnitBurnDownWarning       | Warning: RU/WU usage increasing rapidly or nearing allocated limits, causing potential throttling or cost spikes. |
## Metrics
The most important metrics provided by the Pinecone integration, which are used on the pre-built dashboard and Prometheus alerts, are as follows:
- pinecone\_db\_op\_delete\_count
- pinecone\_db\_op\_delete\_duration\_sum
- pinecone\_db\_op\_fetch\_count
- pinecone\_db\_op\_fetch\_duration\_sum
- pinecone\_db\_op\_query\_count
- pinecone\_db\_op\_query\_duration\_sum
- pinecone\_db\_op\_upsert\_count
- pinecone\_db\_op\_upsert\_duration\_sum
- pinecone\_db\_read\_unit\_budget
- pinecone\_db\_read\_unit\_count
- pinecone\_db\_record\_total
- pinecone\_db\_storage\_size\_bytes
- pinecone\_db\_write\_unit\_budget
- pinecone\_db\_write\_unit\_total
- up
## Changelog
md ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```md
# 1.0.0 - February 2026
* Initial release
## Cost
By connecting your Pinecone instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see [Active series and dpm usage](/docs/grafana-cloud/fundamentals/active-series-and-dpm/) and [Cloud tier pricing](/products/cloud/pricing/).
