title: "OpenAI Codex integration | Grafana Cloud documentation"
description: "Learn about OpenAI Codex Grafana Cloud integration."
# OpenAI Codex integration for Grafana Cloud
Track OpenAI Codex CLI usage, API requests, tool invocations, and performance metrics across your organization by exporting telemetry data through OpenTelemetry (OTel). Codex exports metrics, logs, and traces.
## Install OpenAI Codex integration for Grafana Cloud
1. In your Grafana Cloud stack, click **Connections** in the left-hand menu.
2. Find and select the **OpenAI Codex** tile to open the integration.
3. Follow the steps outlined on the **Configuration** page to set up telemetry and configure credentials.
4. Once configuration is complete, click **Install** to add the prebuilt dashboards to your Grafana Cloud instance.
## Configuration
The OpenAI Codex integration sends metrics, logs, and traces to Grafana Cloud via OpenTelemetry (OTLP HTTP), configured through `~/.codex/config.toml`.
### Configure the integration
Follow these steps to set up OpenAI Codex for Grafana Cloud:
1. **Create Grafana Cloud Token**
   - Generate a Grafana Cloud Access Policy Token with `metrics:write`, `logs:write`, and `traces:write` permissions.
   - Copy the token value and store it securely.
2. **Configure `~/.codex/config.toml`**
   Create or edit `~/.codex/config.toml` and add the following, replacing the placeholder values with your Grafana Cloud credentials:
   toml ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
   ```toml
   [otel]
   environment = "production"
   log_user_prompt = false
   exporter = { otlp-http = {
     endpoint = "<your-grafana-cloud-otlp-endpoint>/otlp/v1/logs",
     protocol = "binary",
     headers = { "Authorization" = "Basic <base64-encoded-instanceid:token>" }
   metrics_exporter = { otlp-http = {
     endpoint = "<your-grafana-cloud-otlp-endpoint>/otlp/v1/metrics",
   trace_exporter = { otlp-http = {
     endpoint = "<your-grafana-cloud-otlp-endpoint>/otlp/v1/traces",
   Restart Codex after saving the file for changes to take effect. It may take a few minutes for data to appear in Grafana Cloud.
3. **Install Dashboards**
   - Click **Install** to add the OpenAI Codex dashboards to your Grafana Cloud instance.
### Finding your credentials
- **OTLP Endpoint**: Your endpoint is displayed in the integration configuration page. You can also find it in the Grafana Cloud portal under **My Account → Stack details**.
- **Auth Header**: Use `Basic <base64(instanceId:token)>` where `instanceId` is your OpenTelemetry instance ID and `token` is the Grafana Cloud Access Policy token generated above.
## Dashboards
The OpenAI Codex integration installs the following dashboards in your Grafana Cloud instance.
- OpenAI Codex
**OpenAI Codex overview**
**OpenAI Codex usage**
**OpenAI Codex performance**
## Changelog
md ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```md
# 1.0.0 - March 2026
* Initial release of OpenAI Codex integration
