title: "Neon integration | Grafana Cloud documentation"
description: "Learn about Neon Grafana Cloud integration."
# Neon integration for Grafana Cloud
Neon Integration for Grafana Cloud provides monitoring for your Neon Postgres database through OpenTelemetry. This integration allows you to send telemetry data from your Neon database to Grafana Cloud using the OTLP endpoint. Neon is a serverless PostgreSQL database platform that provides autoscaling, branching, and point-in-time recovery capabilities. With this integration, you can monitor database performance, query execution times, connection metrics, and other operational insights from your Neon databases.
## Changelog
md ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```md
# 1.0.0 - August 2025
* Initial release of Neon integration
* Support for OTLP endpoint configuration
* Basic dashboard support
## Cost
By connecting your Neon instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see [Active series and dpm usage](/docs/grafana-cloud/fundamentals/active-series-and-dpm/) and [Cloud tier pricing](/products/cloud/pricing/).
