title: "Microsoft SQL Server integration | Grafana Cloud documentation"
description: "Learn about Microsoft SQL Server Grafana Cloud integration."
# Microsoft SQL Server integration for Grafana Cloud
Microsoft SQL Server is a relational database that can be used to store and retrieve data. The Microsoft SQL Server integration uses Grafana Alloy to collect metrics for monitoring a MSSQL instance, including aspects such as active connections, read/write latency, buffer cache hit rate, and page faults. Accompanying dashboards are provided to visualize these metrics, as well as recommended alerting policies.
This integration supports SQL Server 2017, SQL Server 2019, and SQL Server 2022.
This integration includes 5 useful alerts and 3 pre-built dashboards to help monitor and visualize Microsoft SQL Server metrics and logs.
## Before you begin
In order to scrape Microsoft SQL Server metrics, you must have a user configured with the following grants:
![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```none
GRANT VIEW ANY DEFINITION TO <MONITOR_USER>;
GRANT VIEW SERVER STATE TO <MONITOR_USER>;
## Install Microsoft SQL Server integration for Grafana Cloud
1. In your Grafana Cloud stack, click **Connections** in the left-hand menu.
2. Find **Microsoft SQL Server** and click its tile to open the integration.
3. Review the prerequisites in the **Configuration Details** tab and set up Grafana Alloy to send Microsoft SQL Server metrics and logs to your Grafana Cloud instance.
4. Click **Install** to add this integration’s pre-built dashboards and alerts to your Grafana Cloud instance, and you can start monitoring your Microsoft SQL Server setup.
## Configuration snippets for Grafana Alloy
### Simple mode
These snippets are configured to scrape a single Microsoft SQL Server instance running locally with default ports.
First, **manually** copy and append the following snippets into your alloy configuration file.
### Integrations snippets
Alloy ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```alloy
prometheus.exporter.mssql "integrations_mssql" {
	connection_string = "sqlserver://user:pass@127.0.0.1:1433"
discovery.relabel "integrations_mssql" {
	targets = prometheus.exporter.mssql.integrations_mssql.targets
	rule {
		target_label = "instance"
	rule {
		target_label = "job"
		replacement  = "integrations/mssql"
prometheus.scrape "integrations_mssql" {
	targets    = discovery.relabel.integrations_mssql.output
	job_name   = "integrations/mssql"
### Logs snippets
#### linux
```alloy
local.file_match "logs_integrations_integrations_mssql_linux" {
	path_targets = [{
		__address__ = "localhost",
		__path__    = "/var/opt/mssql/log/errorlog",
loki.process "logs_integrations_integrations_mssql_linux" {
	forward_to = [loki.write.grafana_cloud_loki.receiver]
	stage.multiline {
		firstline     = "^\\s*\\d{4}-\\d{2}-\\d{2}\\s+\\d{2}:\\d{2}:\\d{2}\\.\\d+"
		max_lines     = 0
		max_wait_time = "3s"
	stage.regex {
		expression = "^(?s)(?P<timestamp>\\s*\\d{4}-\\d{2}-\\d{2}\\s+\\d{2}:\\d{2}:\\d{2}\\.\\d+)\\s+(?P<component>\\w+)\\s+(?P<message>.*)$"
	stage.timestamp {
		source = "timestamp"
		format = "RFC3339Nano"
	stage.static_labels {
		values = {
			instance = constants.hostname,
			job      = "integrations/mssql",
			log_type = "mssql_error",
	stage.labels {
		values = {
			component = null,
			message   = null,
loki.source.file "logs_integrations_integrations_mssql_linux" {
	targets    = local.file_match.logs_integrations_integrations_mssql_linux.targets
	forward_to = [loki.process.logs_integrations_integrations_mssql_linux.receiver]
#### windows
```alloy
local.file_match "logs_integrations_integrations_mssql_windows" {
	path_targets = [{
		__path__    = "/Program Files/Microsoft SQL Server/**/MSSQL/LOG/ERRORLOG",
loki.process "logs_integrations_integrations_mssql_windows" {
	stage.multiline {
		max_lines     = 0
	stage.regex {
	stage.timestamp {
		values = {
	stage.labels {
		values = {
			component = null,
			message   = null,
loki.source.file "logs_integrations_integrations_mssql_windows" {
	targets    = local.file_match.logs_integrations_integrations_mssql_windows.targets
	forward_to = [loki.process.logs_integrations_integrations_mssql_windows.receiver]
### Advanced mode
To instruct Grafana Alloy to scrape your Microsoft SQL Server instances, **manually** copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
### Advanced integrations snippets
```alloy
	rule {
	rule {
This integrations uses the [prometheus.exporter.mssql](/docs/grafana-cloud/send-data/alloy/reference/components/prometheus/prometheus.exporter.mssql/) component to generate metrics from a Microsoft SQL Server instance.
In the Alloy configuration file a connection string with the username, password, and a host:port pair must be provided.
Also, rather than using SQL Server credentials to authenticate, it is possible to use Windows credentials by modifying the `connecton_string` accordingly (see the [`Authentication` section of the Alloy MSSQL Prometheus component documentation](/docs/grafana-cloud/send-data/alloy/reference/components/prometheus/prometheus.exporter.mssql/#authentication)).
The ability to pull in custom metrics (outside of the defaults) is also available for this integration. To do this, use the [`query_config`](/docs/grafana-cloud/send-data/alloy/reference/components/prometheus/prometheus.exporter.mssql/#custom-metrics) parameter, under the `integrations.mssql` section of your configuration. After configuring to collect custom metrics, the default dashboards will have to be manually modified to include any reference to these new metrics.
For the full array of configuration options, refer to the [prometheus.exporter.mssql](/docs/grafana-cloud/send-data/alloy/reference/components/prometheus/prometheus.exporter.mssql/) component reference documentation.
This exporter must be linked with a [discovery.relabel](/docs/alloy/latest/reference/components/discovery.relabel/) component to apply the necessary relabelings.
For each Microsoft SQL Server instance to be monitored you must create a pair of these components.
Configure the following properties within each `discovery.relabel` component:
- `instance` label: `constants.hostname` sets the `instance` label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this Microsoft SQL Server instance. Make sure this label value is the same for all telemetry data collected for this instance.
You can then scrape them by including each `discovery.relabel` under `targets` within the [prometheus.scrape](/docs/alloy/latest/reference/components/prometheus.scrape/) component.
### Advanced logs snippets
#### linux
```alloy
	path_targets = [{
	stage.multiline {
		max_lines     = 0
	stage.regex {
	stage.timestamp {
		values = {
	stage.labels {
		values = {
			component = null,
			message   = null,
To monitor your Microsoft SQL Server instance logs, you will use a combination of the following components:
- [local.file\_match](/docs/alloy/latest/reference/components/local.file_match) defines where to find the log file to be scraped. Change the following properties according to your environment:
  - `__address__`: The Microsoft SQL Server instance address
  - `__path__`: The path to the log file.
- [loki.process](/docs/alloy/latest/reference/components/loki.process) defines how to process logs before sending it to Loki.
- [loki.source.file](/docs/alloy/latest/reference/components/loki.source.file) sends logs to Loki.
#### windows
```alloy
	path_targets = [{
	stage.multiline {
		max_lines     = 0
	stage.regex {
	stage.timestamp {
		values = {
	stage.labels {
		values = {
			component = null,
			message   = null,
## Kubernetes instructions
Instructions for Kubernetes
### Before you begin with Kubernetes
**Please note**: These instructions assume the use of the [Kubernetes Monitoring Helm chart](https://github.com/grafana/k8s-monitoring-helm)
```none
### Configuration snippets for Kubernetes Helm chart
To scrape your Microsoft SQL Server instances, **manually** modify your Kubernetes Monitoring Helm chart with these configuration snippets.
Replace any values between the angle brackets `<>` in the provided snippets with your desired configuration values.
#### Metrics snippets
```alloy
alloy-metrics:
    extraConfig: |-
            connection_string = "sqlserver://<db_user>:<db_password>@<mssql_service>.<mssql_namespace>.svc.cluster.local:1433"
            forward_to = [prometheus.remote_write.grafana_cloud_metrics.receiver]
#### Logs snippets
```alloy
podLogs:
    extraDiscoveryRules: |-
        rule {
            source_labels = ["__meta_kubernetes_namespace", "__meta_kubernetes_pod_name"]
            separator     = ":"
            regex         = "(<mssql_namespace>:<mssql_pod_prefix>.*)"
            replacement   = "mssql"
            target_label  = "integration"
        rule {
            source_labels = ["integration", "__meta_kubernetes_pod_node_name"]
            separator     = ":"
            regex         = "mssql:(.*)"
            target_label  = "host"
    extraLogProcessingStages: |-
        stage.match {
            selector = "{integration=\\"mssql\\"}"
            stage.multiline {
                firstline = "^\\\\s*\\\\d{4}-\\\\d{2}-\\\\d{2}\\\\s+\\\\d{2}:\\\\d{2}:\\\\d{2}\\\\.\\\\d+"
            stage.regex {
                expression = "^(?s)(?P<timestamp>\\\\s*\\\\d{4}-\\\\d{2}-\\\\d{2}\\\\s+\\\\d{2}:\\\\d{2}:\\\\d{2}\\\\.\\\\d+)\\\\s+(?P<component>\\\\w+)\\\\s+(?P<message>.*)$"
            stage.timestamp {
                values = {
                    instance = "<mssql_service>.<mssql_namespace>.svc.cluster.local:1433",
            stage.labels {
                values = {
                    message = "message",
                    component = "component",
## Dashboards
The Microsoft SQL Server integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- MSSQL logs
- MSSQL overview
- MSSQL pages
**Microsoft SQL Server overview dashboard (1/3).**
**Microsoft SQL Server overview dashboard (2/3).**
**Microsoft SQL Server overview dashboard (3/3).**
## Alerts
The Microsoft SQL Server integration includes the following useful alerts:
Expand table
| Alert                       | Description                                                          |
| MSSQLHighNumberOfDeadlocks  | Warning: There are deadlocks occurring in the database.              |
| MSSQLModerateReadStallTime  | Warning: There is a moderate amount of IO stall for database reads.  |
| MSSQLHighReadStallTime      | Critical: There is a high amount of IO stall for database reads.     |
| MSSQLModerateWriteStallTime | Warning: There is a moderate amount of IO stall for database writes. |
| MSSQLHighWriteStallTime     | Critical: There is a high amount of IO stall for database writes.    |
## Metrics
The most important metrics provided by the Microsoft SQL Server integration, which are used on the pre-built dashboards and Prometheus alerts, are as follows:
- mssql\_available\_commit\_memory\_bytes
- mssql\_batch\_requests\_total
- mssql\_buffer\_cache\_hit\_ratio
- mssql\_checkpoint\_pages\_sec
- mssql\_connections
- mssql\_deadlocks\_total
- mssql\_io\_stall\_seconds\_total
- mssql\_kill\_connection\_errors\_total
- mssql\_log\_growths\_total
- mssql\_os\_memory
- mssql\_os\_page\_file
- mssql\_page\_fault\_count\_total
- mssql\_server\_target\_memory\_bytes
- mssql\_server\_total\_memory\_bytes
- up
## Changelog
md ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```md
# 1.1.0 - March 2026
* Updated dashboards to follow new stylistic standards
# 1.0.5 - October 2024
* Pulled new mixin changes to apply a 1 minute `minstep` to any panels using `rate` or `increase`
# 1.0.4 - October 2024
* Pulled new mixin changes to use `$__rate_interval:` for all increase panels
# 1.0.3 - April 2024
* Added cluster selector to dashboards for kubernetes support
* Added default cluster label to agent config
* Bump version to 1.0.3
# 1.0.2 - March 2024
* Updates MSSQL integration with documentation for Windows authentication options
# 1.0.1 - December 2023
* Updates MSSQL integration with documentation for new query_config parameter
* Fixes prometheus metrics list to show new metrics added in 1.0.0
# 1.0.0 - December 2023
* Updates MSSQL integration to use newest MSSQL mixin
# 0.0.4 - September 2023
* Update Grafana Agent configuration snippets to include filtered metrics used in gauge panels
# 0.0.3 - September 2023
# 0.0.2 - August 2023
# 0.0.1 - February 2023
* Initial release
## Cost
By connecting your Microsoft SQL Server instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see [Active series and dpm usage](/docs/grafana-cloud/fundamentals/active-series-and-dpm/) and [Cloud tier pricing](/products/cloud/pricing/).
