title: "MinIO integration | Grafana Cloud documentation"
description: "Learn about MinIO Grafana Cloud integration."
# MinIO integration for Grafana Cloud
MinIO is a Kubernetes-native high-performance object storage server which is designed for large-scale private cloud infrastructure and compatible with Amazon S3.
This integration includes 2 useful alerts and 1 pre-built dashboard to help monitor and visualize MinIO metrics.
## Before you begin
By default, the Alloy configuration is expected to have `MINIO_PROMETHEUS_AUTH_TYPE` to be set to ‘public’.
If you choose not to set this flag you will need to generate a `bearer_token` with `mc admin prometheus generate <alias>` command to generate the scrape config compatible with Grafana Alloy. To learn more, see [monitoring minio docs](https://min.io/docs/minio/linux/operations/monitoring/collect-minio-metrics-using-prometheus.html).
## Install MinIO integration for Grafana Cloud
1. In your Grafana Cloud stack, click **Connections** in the left-hand menu.
2. Find **MinIO** and click its tile to open the integration.
3. Review the prerequisites in the **Configuration Details** tab and set up Grafana Alloy to send MinIO metrics to your Grafana Cloud instance.
4. Click **Install** to add this integration’s pre-built dashboard and alerts to your Grafana Cloud instance, and you can start monitoring your MinIO setup.
## Configuration snippets for Grafana Alloy
### Simple mode
These snippets are configured to scrape a single MinIO instance running locally with default ports.
First, **manually** copy and append the following snippets into your alloy configuration file.
### Metrics snippets
Alloy ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```alloy
discovery.relabel "metrics_integrations_integrations_minio" {
	targets = [{
		__address__ = "localhost:9000",
	rule {
		target_label = "instance"
prometheus.scrape "metrics_integrations_integrations_minio" {
	targets      = discovery.relabel.metrics_integrations_integrations_minio.output
	forward_to   = [prometheus.remote_write.metrics_service.receiver]
	job_name     = "integrations/minio"
	metrics_path = "/minio/prometheus/metrics"
### Advanced mode
To instruct Grafana Alloy to scrape your MinIO instances, **manually** copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
### Advanced metrics snippets
```alloy
	targets = [{
	rule {
To monitor your MinIO instance, you must use a [discovery.relabel](/docs/alloy/latest/reference/components/discovery.relabel/) component to discover your MinIO Prometheus endpoint and apply appropriate labels, followed by a [prometheus.scrape](/docs/alloy/latest/reference/components/prometheus.scrape) component to scrape it.
Configure the following properties within each `discovery.relabel` component:
- `__address__`: The address to your MinIO Prometheus metrics endpoint.
- `instance` label: `constants.hostname` sets the `instance` label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this MinIO instance.
If you have multiple MinIO servers to scrape, configure one `discovery.relabel` for each and scrape them by including each under `targets` within the `prometheus.scrape` component.
## Dashboards
The MinIO integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- MinIO distributed cluster metrics
**MinIO distributed metrics overview**
## Alerts
The MinIO integration includes the following useful alerts:
Expand table
| Alert             | Description                                        |
| MinioDisksOffline | Critical: MinIO disks offline.                     |
| MinioStorageUsed  | Warning: MinIO disks high storage used percentage. |
## Metrics
The most important metrics provided by the MinIO integration, which are used on the pre-built dashboard and Prometheus alerts, are as follows:
- bucket\_objects\_count
- bucket\_objects\_histogram
- bucket\_usage\_size
- disk\_storage\_available
- disk\_storage\_total
- disk\_storage\_used
- internode\_rx\_bytes\_total
- internode\_tx\_bytes\_total
- minio\_disks\_offline
- minio\_disks\_total
- minio\_version\_info
- s3\_errors\_total
- s3\_requests\_total
- s3\_ttfb\_seconds\_bucket
- s3\_ttfb\_seconds\_count
- s3\_ttfb\_seconds\_sum
- up
## Changelog
md ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```md
# 1.0.0 - December 2025
* Chore: Fix incorrect semver to 1.0.0. No further changes
# 0.0.6 - September 2023
# 0.0.5 - May 2023
* Fix query in 'Storage Used' panel
# 0.0.4 - December 2022
* Update mixin to latest
  - Add instance selector
* Add screenshot
# 0.0.3 - September 2022
* Update dashboard panels descriptions.
# 0.0.2 - October 2021
* Update mixin to latest version:
  - Update queries to use $__rate_interval
# 0.0.1 - November 2020
* Initial release
## Cost
By connecting your MinIO instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see [Active series and dpm usage](/docs/grafana-cloud/fundamentals/active-series-and-dpm/) and [Cloud tier pricing](/products/cloud/pricing/).
