Self-hosted Mimir integration for Grafana Cloud
Grafana Mimir is an open source software project that provides a scalable long-term storage for Prometheus. Grafana Enterprise Metrics (or GEM) is the enterprise version of Grafana Mimir. You can install both of these products via the Grafana Mimir Helm chart.
This integration comes with dashboards, recording and alerting rules to help monitor the health of your Mimir or GEM cluster as well as understand per-tenant usage and behavior.
This integration includes 80 useful alerts and 26 pre-built dashboards to help monitor and visualize Self-hosted Mimir metrics and logs.
Before you begin
This integration is primarily targeted on monitoring a Mimir or GEM cluster that has been installed via the Helm chart, but it is also possible to use this integration if Mimir has been deployed another way.
The integration relies on metrics from kube-state-metrics, cAdvisor, and kubelet. Make sure that you have installed and enabled them in your Kubernetes cluster before you begin. Otherwise, some of the dashboards in the
integration will display No data. Some of the dashboards contain panels related to disk usage. These panels rely on node_exporter metrics. To include them, see Additional resources metrics.
If you are using Helm chart version 3.0.0 or higher, you can skip setting up a Grafana Alloy instance, since it is included within the chart. All you will need to do is configure the chart to use the credentials and URLs of your Grafana Cloud Metrics and Logs instances. Please follow the instructions on Collect metrics and logs from the Helm chart. For information about how to create a Grafana Cloud API key, see Create a Grafana Cloud API key.
If you are not using the Helm chart, or are using an older version, follow the instructions on the next step.
Install Self-hosted Mimir integration for Grafana Cloud
- Find Self-hosted Mimir and click its tile to open the integration.
- Review the prerequisites in the Configuration Details tab and set up Grafana Alloy to send Self-hosted Mimir metrics and logs to your Grafana Cloud instance.
- Click Install to add this integration’s pre-built dashboards and alerts to your Grafana Cloud instance, and you can start monitoring your Self-hosted Mimir setup.
Simple mode
These snippets are configured to scrape a single Self-hosted Grafana Mimir instance running locally with default ports.
Metrics snippets
discovery.kubernetes "metrics_integrations_integrations_grafana_mimir_kube_state_metrics" {
role = "pod"
discovery.kubernetes "metrics_integrations_integrations_grafana_mimir_kubelet" {
role = "node"
discovery.kubernetes "metrics_integrations_integrations_grafana_mimir_cadvisor" {
role = "node"
discovery.kubernetes "metrics_integrations_integrations_grafana_mimir_metrics" {
role = "pod"
discovery.relabel "metrics_integrations_integrations_grafana_mimir_kube_state_metrics" {
targets = discovery.kubernetes.metrics_integrations_integrations_grafana_mimir_kube_state_metrics.targets
rule {
source_labels = ["__meta_kubernetes_pod_label_app_kubernetes_io_name"]
regex = "kube-state-metrics"
action = "keep"
rule {
source_labels = ["cluster"]
separator = ""
regex = ""
target_label = "cluster"
replacement = "k8s-cluster"
discovery.relabel "metrics_integrations_integrations_grafana_mimir_kubelet" {
targets = discovery.kubernetes.metrics_integrations_integrations_grafana_mimir_kubelet.targets
rule {
target_label = "__address__"
replacement = "kubernetes.default.svc.cluster.local:443"
rule {
source_labels = ["__meta_kubernetes_node_name"]
regex = "(.+)"
target_label = "__metrics_path__"
replacement = "/api/v1/nodes/${1}/proxy/metrics"
rule {
separator = ""
regex = ""
discovery.relabel "metrics_integrations_integrations_grafana_mimir_cadvisor" {
targets = discovery.kubernetes.metrics_integrations_integrations_grafana_mimir_cadvisor.targets
rule {
rule {
regex = "(.+)"
replacement = "/api/v1/nodes/${1}/proxy/metrics/cadvisor"
rule {
separator = ""
regex = ""
discovery.relabel "metrics_integrations_integrations_grafana_mimir_metrics" {
targets = discovery.kubernetes.metrics_integrations_integrations_grafana_mimir_metrics.targets
rule {
source_labels = ["__meta_kubernetes_pod_container_port_name"]
regex = ".*metrics"
action = "keep"
rule {
source_labels = ["__meta_kubernetes_pod_label_helm_sh_chart"]
regex = "mimir-distributed-.*"
action = "keep"
rule {
separator = ""
regex = ""
rule {
source_labels = ["__meta_kubernetes_namespace"]
target_label = "namespace"
rule {
source_labels = ["__meta_kubernetes_pod_name"]
target_label = "pod"
rule {
source_labels = ["__meta_kubernetes_pod_container_name"]
target_label = "container"
rule {
source_labels = ["__meta_kubernetes_pod_label_name", "__meta_kubernetes_pod_label_app_kubernetes_io_component"]
separator = ""
target_label = "__tmp_component_name"
rule {
source_labels = ["__meta_kubernetes_pod_node_name"]
target_label = "instance"
prometheus.scrape "metrics_integrations_integrations_grafana_mimir_kube_state_metrics" {
targets = discovery.relabel.metrics_integrations_integrations_grafana_mimir_kube_state_metrics.output
forward_to = [prometheus.relabel.metrics_integrations_integrations_grafana_mimir_kube_state_metrics.receiver]
job_name = "integrations/grafana-mimir/kube-state-metrics"
prometheus.scrape "metrics_integrations_integrations_grafana_mimir_kubelet" {
targets = discovery.relabel.metrics_integrations_integrations_grafana_mimir_kubelet.output
forward_to = [prometheus.relabel.metrics_integrations_integrations_grafana_mimir_kubelet.receiver]
job_name = "integrations/grafana-mimir/kubelet"
scheme = "https"
authorization {
type = "Bearer"
credentials_file = "/var/run/secrets/kubernetes.io/serviceaccount/token"
tls_config {
ca_file = "/var/run/secrets/kubernetes.io/serviceaccount/ca.crt"
server_name = "kubernetes"
prometheus.scrape "metrics_integrations_integrations_grafana_mimir_cadvisor" {
targets = discovery.relabel.metrics_integrations_integrations_grafana_mimir_cadvisor.output
forward_to = [prometheus.relabel.metrics_integrations_integrations_grafana_mimir_cadvisor.receiver]
job_name = "integrations/grafana-mimir/cadvisor"
scheme = "https"
authorization {
type = "Bearer"
tls_config {
prometheus.scrape "metrics_integrations_integrations_grafana_mimir_metrics" {
targets = discovery.relabel.metrics_integrations_integrations_grafana_mimir_metrics.output
job_name = "integrations/grafana-mimir/metrics"
prometheus.relabel "metrics_integrations_integrations_grafana_mimir_kube_state_metrics" {
rule {
source_labels = ["deployment", "statefulset", "pod"]
separator = ""
regex = "(.*mimir-)?alertmanager.*|(.*mimir-)?alertmanager-im.*|(.*mimir-)?(query-scheduler|ruler-query-scheduler|ruler|store-gateway|compactor|alertmanager|overrides-exporter|mimir-backend).*|(.*mimir-)?compactor.*|(.*mimir-)?distributor.*|(.*mimir-)?(gateway|cortex-gw|cortex-gw-internal).*|(.*mimir-)?ingester.*|(.*mimir-)?mimir-backend.*|(.*mimir-)?mimir-read.*|(.*mimir-)?mimir-write.*|(.*mimir-)?overrides-exporter.*|(.*mimir-)?querier.*|(.*mimir-)?query-frontend.*|(.*mimir-)?query-scheduler.*|(.*mimir-)?(query-frontend|querier|ruler-query-frontend|ruler-querier|mimir-read).*|(.*mimir-)?ruler.*|(.*mimir-)?ruler-querier.*|(.*mimir-)?ruler-query-frontend.*|(.*mimir-)?ruler-query-scheduler.*|(.*mimir-)?store-gateway.*|(.*mimir-)?(distributor|ingester|mimir-write).*"
action = "keep"
prometheus.relabel "metrics_integrations_integrations_grafana_mimir_kubelet" {
rule {
source_labels = ["__name__"]
regex = "kubelet_volume_stats.*"
action = "keep"
prometheus.relabel "metrics_integrations_integrations_grafana_mimir_cadvisor" {
rule {
source_labels = ["pod"]
action = "keep"
}Logs snippets
linux
discovery.kubernetes "logs_integrations_integrations_grafana_mimir_logs" {
role = "pod"
discovery.relabel "logs_integrations_integrations_grafana_mimir_logs" {
targets = discovery.kubernetes.logs_integrations_integrations_grafana_mimir_logs.targets
rule {
action = "keep"
rule {
target_label = "__host__"
rule {
source_labels = ["__meta_kubernetes_namespace", "__meta_kubernetes_pod_container_name"]
separator = "/"
target_label = "job"
rule {
separator = ""
regex = ""
rule {
rule {
rule {
target_label = "name"
rule {
rule {
source_labels = ["__meta_kubernetes_pod_uid", "__meta_kubernetes_pod_container_name"]
separator = "/"
target_label = "__path__"
replacement = "/var/log/pods/*$1/*.log"
local.file_match "logs_integrations_integrations_grafana_mimir_logs" {
path_targets = discovery.relabel.logs_integrations_integrations_grafana_mimir_logs.output
loki.process "logs_integrations_integrations_grafana_mimir_logs" {
forward_to = [loki.write.grafana_cloud_loki.receiver]
stage.cri { }
loki.source.file "logs_integrations_integrations_grafana_mimir_logs" {
targets = local.file_match.logs_integrations_integrations_grafana_mimir_logs.targets
forward_to = [loki.process.logs_integrations_integrations_grafana_mimir_logs.receiver]
}Advanced mode
To instruct Grafana Alloy to scrape your Self-hosted Grafana Mimir instances, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
Advanced metrics snippets
role = "pod"
role = "node"
role = "node"
role = "pod"
rule {
action = "keep"
rule {
separator = ""
regex = ""
rule {
rule {
regex = "(.+)"
rule {
separator = ""
regex = ""
rule {
rule {
regex = "(.+)"
rule {
separator = ""
regex = ""
rule {
regex = ".*metrics"
action = "keep"
rule {
action = "keep"
rule {
separator = ""
regex = ""
rule {
rule {
rule {
rule {
separator = ""
rule {
scheme = "https"
authorization {
type = "Bearer"
tls_config {
scheme = "https"
authorization {
type = "Bearer"
tls_config {
rule {
separator = ""
action = "keep"
rule {
action = "keep"
rule {
action = "keep"
}To monitor your Self-hosted Grafana Mimir instance, you must use a discovery.relabel component to discover your Self-hosted Grafana Mimir Prometheus endpoint and apply appropriate labels, followed by a prometheus.scrape component to scrape it.
Configure the following properties within each discovery.relabel component:
__address__: The address to your Self-hosted Grafana Mimir Prometheus metrics endpoint.instancelabel:constants.hostnamesets theinstancelabel to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this Self-hosted Grafana Mimir instance. Make sure this label value is the same for all telemetry data collected for this instance.cluster: Theclusterlabel to group your Self-hosted Grafana Mimir instances within a cluster. Set the same value for all nodes within your cluster.
If you have multiple Self-hosted Grafana Mimir servers to scrape, configure one discovery.relabel for each and scrape them by including each under targets within the prometheus.scrape component.
Advanced logs snippets
linux
role = "pod"
rule {
action = "keep"
rule {
rule {
separator = "/"
rule {
separator = ""
regex = ""
rule {
rule {
rule {
rule {
rule {
separator = "/"
stage.cri { }
}To monitor your Self-hosted Grafana Mimir instance logs, you will use a combination of the following components:
- local.file_match defines where to find the log file to be scraped. Change the following properties according to your environment:
__address__: The Self-hosted Grafana Mimir instance address__path__: The path to the log file.instancelabel:constants.hostnamesets theinstancelabel to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this Self-hosted Grafana Mimir instance. Make sure this label value is the same for all telemetry data collected for this instance.cluster: Theclusterlabel to group your Self-hosted Grafana Mimir instances within a cluster. Set the same value for all nodes within your cluster.
- loki.process defines how to process logs before sending it to Loki.
- discovery.relabel defines any relabeling needed before sending logs to Loki.
- loki.source.file sends logs to Loki.
Kubernetes instructions
Before you begin with Kubernetes
Please note: These instructions assume the use of the Kubernetes Monitoring Helm chart
Configuration snippets for Kubernetes Helm chart
To scrape your Mimir instances, manually modify your Kubernetes Monitoring Helm chart with these configuration snippets.
Replace any values between the angle brackets <> in the provided snippets with your desired configuration values.
Metrics snippets
integrations:
mimir:
instances:
- name: <your_mimir_instance_name>
labelSelectors:
app.kubernetes.io/name: <your_mimir_instance_name>
metrics:
enabled: trueLogs snippets
integrations:
mimir:
instances:
labelSelectors:
logs:
enabled: trueDashboards
The Self-hosted Mimir integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- Mimir / Alertmanager
- Mimir / Alertmanager resources
- Mimir / Compactor
- Mimir / Compactor resources
- Mimir / Config
- Mimir / Object Store
- Mimir / Overrides
- Mimir / Overview
- Mimir / Overview networking
- Mimir / Overview resources
- Mimir / Queries
- Mimir / Reads
- Mimir / Reads networking
- Mimir / Reads resources
- Mimir / Remote ruler reads
- Mimir / Remote ruler reads networking
- Mimir / Remote ruler reads resources
- Mimir / Rollout progress
- Mimir / Ruler
- Mimir / Scaling
- Mimir / Slow queries
- Mimir / Tenants
- Mimir / Top tenants
- Mimir / Writes
- Mimir / Writes networking
- Mimir / Writes resources
Tenants
Overview
Alerts
The Self-hosted Mimir integration includes the following useful alerts:
mimir_alerts
mimir_instance_limits_alerts
mimir-rollout-alerts
mimir-provisioning
ruler_alerts
gossip_alerts
etcd_alerts
alertmanager_alerts
mimir_blocks_alerts
mimir_compactor_alerts
mimir_autoscaling
mimir_ingest_storage_alerts
mimir_continuous_test
Metrics
The most important metrics provided by the Self-hosted Mimir integration, which are used on the pre-built dashboards and Prometheus alerts, are as follows:
- cluster_job:cortex_alertmanager_alerts_invalid_total:rate5m
- cluster_job:cortex_alertmanager_alerts_received_total:rate5m
- cluster_job:cortex_alertmanager_partial_state_merges_failed_total:rate5m
- cluster_job:cortex_alertmanager_partial_state_merges_total:rate5m
- cluster_job:cortex_alertmanager_state_replication_failed_total:rate5m
- cluster_job:cortex_alertmanager_state_replication_total:rate5m
- cluster_job:cortex_ingester_queried_exemplars_bucket:sum_rate
- cluster_job:cortex_ingester_queried_exemplars_count:sum_rate
- cluster_job:cortex_ingester_queried_exemplars_sum:sum_rate
- cluster_job:cortex_ingester_queried_samples_bucket:sum_rate
- cluster_job:cortex_ingester_queried_samples_count:sum_rate
- cluster_job:cortex_ingester_queried_samples_sum:sum_rate
- cluster_job:cortex_ingester_queried_series_bucket:sum_rate
- cluster_job:cortex_ingester_queried_series_count:sum_rate
- cluster_job:cortex_ingester_queried_series_sum:sum_rate
- cluster_job_integration:cortex_alertmanager_notifications_failed_total:rate5m
- cluster_job_integration:cortex_alertmanager_notifications_total:rate5m
- cluster_job_pod:cortex_alertmanager_alerts:sum
- cluster_job_pod:cortex_alertmanager_silences:sum
- cluster_job_route:cortex_querier_request_duration_seconds_bucket:sum_rate
- cluster_job_route:cortex_querier_request_duration_seconds_count:sum_rate
- cluster_job_route:cortex_querier_request_duration_seconds_sum:sum_rate
- cluster_job_route:cortex_request_duration_seconds_bucket:sum_rate
- cluster_job_route:cortex_request_duration_seconds_count:sum_rate
- cluster_job_route:cortex_request_duration_seconds_sum:sum_rate
- cluster_namespace_deployment:actual_replicas:count
- cluster_namespace_deployment_reason:required_replicas:count
- cluster_namespace_job:cortex_distributor_exemplars_in:rate5m
- cluster_namespace_job:cortex_distributor_received_exemplars:rate5m
- cluster_namespace_job:cortex_distributor_received_samples:rate5m
- cluster_namespace_job:cortex_ingester_ingested_exemplars:rate5m
- cluster_namespace_job:cortex_ingester_tsdb_exemplar_exemplars_appended:rate5m
- cluster_namespace_job_route:cortex_request_duration_seconds:99quantile
- cluster_namespace_pod:cortex_ingester_ingested_samples_total:rate4m
- container_cpu_usage_seconds_total
- container_fs_writes_bytes_total
- container_memory_rss
- container_memory_usage_bytes
- container_memory_working_set_bytes
- container_network_receive_bytes_total
- container_network_transmit_bytes_total
- container_spec_cpu_period
- container_spec_cpu_quota
- container_spec_memory_limit_bytes
- cortex_alertmanager_alerts
- cortex_alertmanager_alerts_invalid_total
- cortex_alertmanager_alerts_received_total
- cortex_alertmanager_dispatcher_aggregation_groups
- cortex_alertmanager_notification_latency_seconds_bucket
- cortex_alertmanager_notification_latency_seconds_count
- cortex_alertmanager_notification_latency_seconds_sum
- cortex_alertmanager_notifications_failed_total
- cortex_alertmanager_notifications_total
- cortex_alertmanager_partial_state_merges_failed_total
- cortex_alertmanager_partial_state_merges_total
- cortex_alertmanager_ring_check_errors_total
- cortex_alertmanager_silences
- cortex_alertmanager_state_fetch_replica_state_failed_total
- cortex_alertmanager_state_fetch_replica_state_total
- cortex_alertmanager_state_initial_sync_completed_total
- cortex_alertmanager_state_initial_sync_duration_seconds_bucket
- cortex_alertmanager_state_initial_sync_duration_seconds_count
- cortex_alertmanager_state_initial_sync_duration_seconds_sum
- cortex_alertmanager_state_persist_failed_total
- cortex_alertmanager_state_persist_total
- cortex_alertmanager_state_replication_failed_total
- cortex_alertmanager_state_replication_total
- cortex_alertmanager_sync_configs_failed_total
- cortex_alertmanager_sync_configs_total
- cortex_alertmanager_tenants_discovered
- cortex_alertmanager_tenants_owned
- cortex_bucket_blocks_count
- cortex_bucket_index_estimated_compaction_jobs
- cortex_bucket_index_estimated_compaction_jobs_errors_total
- cortex_bucket_index_last_successful_update_timestamp_seconds
- cortex_bucket_index_load_duration_seconds_bucket
- cortex_bucket_index_load_duration_seconds_count
- cortex_bucket_index_load_duration_seconds_sum
- cortex_bucket_index_load_failures_total
- cortex_bucket_index_loaded
- cortex_bucket_index_loads_total
- cortex_bucket_store_block_drop_failures_total
- cortex_bucket_store_block_drops_total
- cortex_bucket_store_block_load_failures_total
- cortex_bucket_store_block_loads_total
- cortex_bucket_store_blocks_loaded
- cortex_bucket_store_indexheader_lazy_load_duration_seconds_bucket
- cortex_bucket_store_indexheader_lazy_load_duration_seconds_count
- cortex_bucket_store_indexheader_lazy_load_duration_seconds_sum
- cortex_bucket_store_indexheader_lazy_load_total
- cortex_bucket_store_indexheader_lazy_unload_total
- cortex_bucket_store_series_batch_preloading_load_duration_seconds_sum
- cortex_bucket_store_series_batch_preloading_wait_duration_seconds_sum
- cortex_bucket_store_series_blocks_queried_sum
- cortex_bucket_store_series_data_size_fetched_bytes_sum
- cortex_bucket_store_series_data_size_touched_bytes_sum
- cortex_bucket_store_series_hash_cache_hits_total
- cortex_bucket_store_series_hash_cache_requests_total
- cortex_bucket_store_series_request_stage_duration_seconds_bucket
- cortex_bucket_store_series_request_stage_duration_seconds_count
- cortex_bucket_store_series_request_stage_duration_seconds_sum
- cortex_bucket_stores_blocks_last_successful_sync_timestamp_seconds
- cortex_bucket_stores_gate_duration_seconds_bucket
- cortex_bucket_stores_gate_duration_seconds_count
- cortex_bucket_stores_gate_duration_seconds_sum
- cortex_bucket_stores_tenants_synced
- cortex_build_info
- cortex_cache_memory_hits_total
- cortex_cache_memory_requests_total
- cortex_compactor_block_cleanup_failures_total
- cortex_compactor_block_cleanup_last_successful_run_timestamp_seconds
- cortex_compactor_blocks_cleaned_total
- cortex_compactor_blocks_marked_for_deletion_total
- cortex_compactor_blocks_marked_for_no_compaction_total
- cortex_compactor_group_compaction_runs_started_total
- cortex_compactor_last_successful_run_timestamp_seconds
- cortex_compactor_meta_sync_duration_seconds_bucket
- cortex_compactor_meta_sync_duration_seconds_count
- cortex_compactor_meta_sync_duration_seconds_sum
- cortex_compactor_meta_sync_failures_total
- cortex_compactor_meta_syncs_total
- cortex_compactor_runs_completed_total
- cortex_compactor_runs_failed_total
- cortex_compactor_runs_started_total
- cortex_compactor_tenants_discovered
- cortex_compactor_tenants_processing_failed
- cortex_compactor_tenants_processing_succeeded
- cortex_compactor_tenants_skipped
- cortex_config_hash
- cortex_discarded_exemplars_total
- cortex_discarded_requests_total
- cortex_discarded_samples_total
- cortex_distributor_deduped_samples_total
- cortex_distributor_exemplars_in_total
- cortex_distributor_inflight_push_requests
- cortex_distributor_instance_limits
- cortex_distributor_instance_rejected_requests_total
- cortex_distributor_latest_seen_sample_timestamp_seconds
- cortex_distributor_non_ha_samples_received_total
- cortex_distributor_received_exemplars_total
- cortex_distributor_received_requests_total
- cortex_distributor_received_samples_total
- cortex_distributor_replication_factor
- cortex_distributor_requests_in_total
- cortex_distributor_samples_in_total
- cortex_frontend_query_range_duration_seconds_count
- cortex_frontend_query_result_cache_attempted_total
- cortex_frontend_query_result_cache_hits_total
- cortex_frontend_query_result_cache_requests_total
- cortex_frontend_query_result_cache_skipped_total
- cortex_frontend_query_sharding_rewrites_attempted_total
- cortex_frontend_query_sharding_rewrites_succeeded_total
- cortex_frontend_sharded_queries_per_query_bucket
- cortex_frontend_sharded_queries_per_query_count
- cortex_frontend_sharded_queries_per_query_sum
- cortex_frontend_split_queries_total
- cortex_inflight_requests
- cortex_ingest_storage_reader_buffered_fetch_records_total
- cortex_ingest_storage_reader_fetch_errors_total
- cortex_ingest_storage_reader_fetches_total
- cortex_ingest_storage_reader_offset_commit_failures_total
- cortex_ingest_storage_reader_offset_commit_requests_total
- cortex_ingest_storage_reader_read_errors_total
- cortex_ingest_storage_reader_receive_delay_seconds_count
- cortex_ingest_storage_reader_receive_delay_seconds_sum
- cortex_ingest_storage_reader_records_failed_total
- cortex_ingest_storage_reader_records_total
- cortex_ingest_storage_strong_consistency_failures_total
- cortex_ingester_active_native_histogram_buckets
- cortex_ingester_active_native_histogram_buckets_custom_tracker
- cortex_ingester_active_native_histogram_series
- cortex_ingester_active_native_histogram_series_custom_tracker
- cortex_ingester_active_series
- cortex_ingester_active_series_custom_tracker
- cortex_ingester_client_request_duration_seconds_bucket
- cortex_ingester_client_request_duration_seconds_count
- cortex_ingester_client_request_duration_seconds_sum
- cortex_ingester_ingested_exemplars_total
- cortex_ingester_ingested_samples_total
- cortex_ingester_instance_limits
- cortex_ingester_instance_rejected_requests_total
- cortex_ingester_local_limits
- cortex_ingester_memory_series
- cortex_ingester_memory_series_created_total
- cortex_ingester_memory_series_removed_total
- cortex_ingester_memory_users
- cortex_ingester_oldest_unshipped_block_timestamp_seconds
- cortex_ingester_owned_series
- cortex_ingester_queried_exemplars_bucket
- cortex_ingester_queried_exemplars_count
- cortex_ingester_queried_exemplars_sum
- cortex_ingester_queried_samples_bucket
- cortex_ingester_queried_samples_count
- cortex_ingester_queried_samples_sum
- cortex_ingester_queried_series_bucket
- cortex_ingester_queried_series_count
- cortex_ingester_queried_series_sum
- cortex_ingester_shipper_last_successful_upload_timestamp_seconds
- cortex_ingester_shipper_upload_failures_total
- cortex_ingester_shipper_uploads_total
- cortex_ingester_tsdb_checkpoint_creations_failed_total
- cortex_ingester_tsdb_checkpoint_creations_total
- cortex_ingester_tsdb_checkpoint_deletions_failed_total
- cortex_ingester_tsdb_compaction_duration_seconds_bucket
- cortex_ingester_tsdb_compaction_duration_seconds_count
- cortex_ingester_tsdb_compaction_duration_seconds_sum
- cortex_ingester_tsdb_compactions_failed_total
- cortex_ingester_tsdb_compactions_total
- cortex_ingester_tsdb_exemplar_exemplars_appended_total
- cortex_ingester_tsdb_exemplar_exemplars_in_storage
- cortex_ingester_tsdb_exemplar_last_exemplars_timestamp_seconds
- cortex_ingester_tsdb_exemplar_series_with_exemplars_in_storage
- cortex_ingester_tsdb_head_max_timestamp_seconds
- cortex_ingester_tsdb_head_truncations_failed_total
- cortex_ingester_tsdb_mmap_chunk_corruptions_total
- cortex_ingester_tsdb_storage_blocks_bytes
- cortex_ingester_tsdb_symbol_table_size_bytes
- cortex_ingester_tsdb_wal_corruptions_total
- cortex_ingester_tsdb_wal_truncate_duration_seconds_count
- cortex_ingester_tsdb_wal_truncate_duration_seconds_sum
- cortex_ingester_tsdb_wal_truncations_failed_total
- cortex_ingester_tsdb_wal_truncations_total
- cortex_ingester_tsdb_wal_writes_failed_total
- cortex_kv_request_duration_seconds_bucket
- cortex_kv_request_duration_seconds_count
- cortex_kv_request_duration_seconds_sum
- cortex_limits_defaults
- cortex_limits_overrides
- cortex_prometheus_notifications_dropped_total
- cortex_prometheus_notifications_errors_total
- cortex_prometheus_notifications_queue_capacity
- cortex_prometheus_notifications_queue_length
- cortex_prometheus_notifications_sent_total
- cortex_prometheus_rule_evaluation_duration_seconds_count
- cortex_prometheus_rule_evaluation_duration_seconds_sum
- cortex_prometheus_rule_evaluation_failures_total
- cortex_prometheus_rule_evaluations_total
- cortex_prometheus_rule_group_duration_seconds_count
- cortex_prometheus_rule_group_duration_seconds_sum
- cortex_prometheus_rule_group_iterations_missed_total
- cortex_prometheus_rule_group_iterations_total
- cortex_prometheus_rule_group_rules
- cortex_querier_blocks_consistency_checks_failed_total
- cortex_querier_blocks_consistency_checks_total
- cortex_querier_queries_rejected_total
- cortex_querier_request_duration_seconds_bucket
- cortex_querier_request_duration_seconds_count
- cortex_querier_request_duration_seconds_sum
- cortex_querier_storegateway_instances_hit_per_query_bucket
- cortex_querier_storegateway_instances_hit_per_query_count
- cortex_querier_storegateway_instances_hit_per_query_sum
- cortex_querier_storegateway_refetches_per_query_bucket
- cortex_querier_storegateway_refetches_per_query_count
- cortex_querier_storegateway_refetches_per_query_sum
- cortex_query_frontend_queries_total
- cortex_query_frontend_queue_duration_seconds_bucket
- cortex_query_frontend_queue_duration_seconds_count
- cortex_query_frontend_queue_duration_seconds_sum
- cortex_query_frontend_queue_length
- cortex_query_frontend_retries_bucket
- cortex_query_frontend_retries_count
- cortex_query_frontend_retries_sum
- cortex_query_scheduler_queue_duration_seconds_bucket
- cortex_query_scheduler_queue_duration_seconds_count
- cortex_query_scheduler_queue_duration_seconds_sum
- cortex_query_scheduler_queue_length
- cortex_request_duration_seconds
- cortex_request_duration_seconds_bucket
- cortex_request_duration_seconds_count
- cortex_request_duration_seconds_sum
- cortex_ring_members
- cortex_ruler_managers_total
- cortex_ruler_queries_failed_total
- cortex_ruler_queries_total
- cortex_ruler_ring_check_errors_total
- cortex_ruler_write_requests_failed_total
- cortex_ruler_write_requests_total
- cortex_runtime_config_hash
- cortex_runtime_config_last_reload_successful
- cortex_tcp_connections
- cortex_tcp_connections_limit
- go_memstats_heap_inuse_bytes
- keda_scaler_errors
- keda_scaler_metrics_value
- kube_deployment_spec_replicas
- kube_deployment_status_replicas_unavailable
- kube_deployment_status_replicas_updated
- kube_horizontalpodautoscaler_info
- kube_horizontalpodautoscaler_spec_max_replicas
- kube_horizontalpodautoscaler_spec_min_replicas
- kube_horizontalpodautoscaler_spec_target_metric
- kube_horizontalpodautoscaler_status_condition
- kube_horizontalpodautoscaler_status_current_replicas
- kube_pod_container_info
- kube_pod_container_resource_requests
- kube_pod_container_resource_requests_cpu_cores
- kube_pod_container_resource_requests_memory_bytes
- kube_pod_container_status_restarts_total
- kube_statefulset_replicas
- kube_statefulset_status_current_revision
- kube_statefulset_status_replicas_current
- kube_statefulset_status_replicas_ready
- kube_statefulset_status_replicas_updated
- kube_statefulset_status_update_revision
- kubelet_volume_stats_capacity_bytes
- kubelet_volume_stats_used_bytes
- memberlist_client_cluster_members_count
- memcached_limit_bytes
- mimir_continuous_test_queries_failed_total
- mimir_continuous_test_query_result_checks_failed_total
- mimir_continuous_test_writes_failed_total
- node_disk_read_bytes_total
- node_disk_written_bytes_total
- process_memory_map_areas
- process_memory_map_areas_limit
- prometheus_tsdb_compaction_duration_seconds_bucket
- prometheus_tsdb_compaction_duration_seconds_count
- prometheus_tsdb_compaction_duration_seconds_sum
- prometheus_tsdb_compactions_total
- rollout_operator_last_successful_group_reconcile_timestamp_seconds
- thanos_cache_hits_total
- thanos_cache_memcached_hits_total
- thanos_cache_memcached_requests_total
- thanos_cache_operation_duration_seconds_bucket
- thanos_cache_operation_duration_seconds_count
- thanos_cache_operation_duration_seconds_sum
- thanos_cache_operation_failures_total
- thanos_cache_operations_total
- thanos_cache_requests_total
- thanos_memcached_operation_duration_seconds_bucket
- thanos_memcached_operation_duration_seconds_count
- thanos_memcached_operation_duration_seconds_sum
- thanos_memcached_operation_failures_total
- thanos_memcached_operations_total
- thanos_objstore_bucket_last_successful_upload_time
- thanos_objstore_bucket_operation_duration_seconds_bucket
- thanos_objstore_bucket_operation_duration_seconds_count
- thanos_objstore_bucket_operation_duration_seconds_sum
- thanos_objstore_bucket_operation_failures_total
- thanos_objstore_bucket_operations_total
- thanos_store_index_cache_hits_total
- thanos_store_index_cache_requests_total
- up
Changelog
# 2.3.0 - February 2025
* [ENHANCEMENT] Dashboards: Add panels for querier, query-frontend, ruler, distributor autoscaling.
# 2.2.0 - July 2024
* [ENHANCEMENT] Dashboards: Add panels for alertmanager activity of a tenant.
* [ENHANCEMENT] Dashboards: Update all deprecated "graph" panels to "timeseries" panels.
* [ENHANCEMENT] Recording rules: add native histogram recording rules to `cortex_request_duration_seconds`.
* [ENHANCEMENT] Dashboards: Add total owned series, and per-ingester in-memory and owned series to "Tenants" dashboard.
* [ENHANCEMENT] Dashboards: allow switching between using classic or native histograms in dashboards.
* Overview dashboard: status, read/write latency and queries/ingestion per sec panels, `cortex_request_duration_seconds` metric.
* [ENHANCEMENT] Dashbaords, alerts: add support for exmeprimental Kafka-based ingest storage.
* [BUGFIX] Recording rules: drop rules for metrics removed in 2.0: `cortex_memcache_request_duration_seconds` and `cortex_cache_request_duration_seconds`.
* [BUGFIX] Dashboards: fix "current replicas" in autoscaling panels when HPA is not active.
# 2.1.0 - March 2024
* [ENHANCEMENT] Dashboards: Show queries per second for the `/api/v1/cardinality/` endpoints on the "Overview" dashboard.
* [ENHANCEMENT] Dashboards: show query-scheduler queue length on "Reads" and "Remote Ruler Reads" dashboards.
* [ENHANCEMENT] Dashboards: Add estimated number of compaction jobs to "Compactor", "Tenants" and "Top tenants" dashboards.
* [BUGFIX] Dashboards: drop `step` parameter from targets as it is not supported.
* [BUGFIX] Dashboards: replace deprecated `graph` panels with `timeseries` panels.
# 2.0.0 - November 2023
This updates the Mixin to its version close to the release of Mimir v2.11.
* [CHANGE] KEDA metrics only work for KEDA versions > 2.9 and require scraping the KEDA operator instead of the KEDA metrics server.
* [CHANGE] Alerts: Remove `MimirQuerierHighRefetchRate`.
* [CHANGE] Alerts: Remove `MimirTenantHasPartialBlocks`. This is obsoleted by the changed default of `-compactor.partial-block-deletion-delay` to `1d`, which will auto remediate this alert.
* [CHANGE] Alerts: don't raise `MimirRequestErrors` or `MimirRequestLatency` alert for the `/debug/pprof` endpoint.
* [CHANGE] Alerts: remove `MimirGossipMembersMismatch` alert and replace it with `MimirGossipMembersTooHigh` and `MimirGossipMembersTooLow` alerts that should have a higher signal-to-noise ratio.
* [CHANGE] Alerts: removed `MimirProvisioningTooManyActiveSeries` alert. You should configure `-ingester.instance-limits.max-series` and rely on `MimirIngesterReachingSeriesLimit` alert instead.
* [CHANGE] Alerts: removed `MimirProvisioningTooManyWrites` alert. The alerting threshold used in this alert was chosen arbitrarily and ingesters receiving an higher number of samples / sec don't necessarily have any issue. You should rely on SLOs metrics and alerts instead.
* [CHANGE] Dashboards: default to shared crosshair on all dashboards.
* [CHANGE] Dashboards: enabled reporting gRPC codes as `status_code` label in Mimir dashboards. In case of gRPC calls, the successful `status_code` label on `cortex_request_duration_seconds` and gRPC client request duration metrics has changed from 'success' and '2xx' to 'OK'.
* [CHANGE] Dashboards: removed "Query results cache misses" panel on the "Mimir / Queries" dashboard.
* [CHANGE] Dashboards: show all workloads in selected namespace on "rollout progress" dashboard.
* [CHANGE] Dashboards: show the number of updated and ready pods for each workload in the "rollout progress" panel on the "rollout progress" dashboard.
* [CHANGE] Dashboards: sort variable drop-down lists from A to Z, rather than Z to A.
* [CHANGE] The `job` label matcher for distributor and gateway have been extended to include any deployment matching `distributor.*` and `cortex-gw.*` respectively. This change allows to match custom and multi-zone distributor and gateway deployments too.
* [BUGFIX] Alerts: Fix `MimirGossipMembersMismatch` to include `admin-api` and custom compactor pods. `admin-api` is a GEM component.
* [BUGFIX] Alerts: Fix autoscaling alerts for KEDA > 2.9. [Requires scraping the KEDA operator for metrics since they moved](https://github.com/kedacore/keda/issues/3972).
* [BUGFIX] Alerts: fix `MimirIngesterRestarts` to fire only when the ingester container is restarted, excluding the cases the pod is rescheduled.
* [BUGFIX] Alerts: fixed `MimirIngesterHasNotShippedBlocks` and `MimirIngesterHasNotShippedBlocksSinceStart` alerts.
* [BUGFIX] Alerts: fixed issue where `GossipMembersMismatch` warning message referred to per-instance labels that were not produced by the alert query.
* [BUGFIX] Dashboards: Fix autoscaling dashboard panels for KEDA > 2.9. [Requires scraping the KEDA operator for metrics since they moved](https://github.com/kedacore/keda/issues/3972).
* [BUGFIX] Dashboards: fix "unhealthy pods" panel on "rollout progress" dashboard showing only a number rather than the name of the workload and the number of unhealthy pods if only one workload has unhealthy pods.
* [BUGFIX] Dashboards: fix autoscaling dashboard panels that could show multiple series for a single component.
* [BUGFIX] Dashboards: fix dashboard panels that showed percentages with axes from 0 to 10000%.
* [BUGFIX] Dashboards: fix ruler-querier scaling metric panel query and split into CPU and memory scaling metric panels.
* [BUGFIX] Dashboards: show cancelled requests in a different color to successful requests in throughput panels on dashboards.
* [ENHANCEMENT] Alertmanager dashboard: display active aggregation groups
* [ENHANCEMENT] Alerts: Add `MimirIngestedDataTooFarInTheFuture` warning alert that triggers when Mimir ingests sample with timestamp more than 1h in the future.
* [ENHANCEMENT] Alerts: `MimirIngesterTSDBWALCorrupted` now only fires when there are more than one corrupted WALs in single-zone deployments and when there are more than two zones affected in multi-zone deployments.
* [ENHANCEMENT] Alerts: added a critical alert for `CompactorSkippedBlocksWithOutOfOrderChunks` when multiple blocks are affected.
* [ENHANCEMENT] Alerts: added labels to duplicated `MimirRolloutStuck` and `MimirCompactorHasNotUploadedBlocks` rules in order to distinguish them.
* [ENHANCEMENT] Alerts: do not fire `MimirAllocatingTooMuchMemory` alert for any matching container outside of namespaces where Mimir is running.
* [ENHANCEMENT] Dashboards: Added the min-replicas for autoscaling dashboards.
* [ENHANCEMENT] Dashboards: Optionally show rejected requests on Mimir Writes dashboard. Useful when used together with "early request rejection" in ingester and distributor.
* [ENHANCEMENT] Dashboards: add "rejected queries" panel to "queries" dashboard.
* [ENHANCEMENT] Dashboards: add native histogram active series and active buckets to "tenants" dashboard.
* [ENHANCEMENT] Dashboards: add panels to "Mimir / Writes" for requests rejected for per-instance limits.
* [ENHANCEMENT] Dashboards: adjust layout of "rollout progress" dashboard panels so that the "rollout progress" panel doesn't require scrolling.
* [ENHANCEMENT] Dashboards: fix holes in graph for lightly loaded clusters
* [ENHANCEMENT] Dashboards: rename "Blocks currently loaded" to "Blocks currently owned" in the "Mimir / Queries" dashboard.
* [ENHANCEMENT] Dashboards: show container name first in "pods count per version" panel on "rollout progress" dashboard.
* [ENHANCEMENT] Dashboards: show time spend waiting for turn when lazy loading index headers in the "index-header lazy load gate latency" panel on the "queries" dashboard.
* [ENHANCEMENT] Dashboards: split query results cache hit ratio by request type in "Query results cache hit ratio" panel on the "Mimir / Queries" dashboard.
* [ENHANCEMENT] Dashboards: Add graphs to "Slow Queries" dashboard.
* [ENHANCEMENT] Dashboards: remove legacy `graph` panel from Rollout Progress dashboard.
* [ENHANCEMENT] Dashboards: Make most columns in "Slow Queries" sortable.
* [ENHANCEMENT] Dashboards: Render graph panels at full resolution as opposed to at half resolution.
# 1.0.2 - September 2023
# 1.0.1 - August 2023
# 1.0.0 - June 2023
* [FEATURE] Enable alerts.
* [BUGFIX] Dashboards: Fix `Rollout Progress` dashboard incorrectly using Gateway metrics when Gateway was not enabled.
* [BUGFIX] Pod selector regex for deployments: change `(.*-mimir-)` to `(.*mimir-)`.
* [BUGFIX] Ruler dashboard: show data for reads from ingesters.
* [BUGFIX] Tenants dashboard: Correctly show the ruler-query-scheduler queue size.
* [BUGFIX] Tenants dashboard: Make it compatible with all deployment types.
* [CHANGE] Make distributor auto-scaling metric panels show desired number of replicas.
* [CHANGE] Move auto-scaling panel rows down beneath logical network path in Reads and Writes dashboards.
* [ENHANCEMENT] Add auto-scaling panels to ruler dashboard.
* [ENHANCEMENT] Add gateway auto-scaling panels to Reads and Writes dashboards.
* [ENHANCEMENT] Add query-frontend and ruler-query-frontend auto-scaling panels to Reads and Ruler dashboards.
* [ENHANCEMENT] Dashboards: Add read path insights row to the "Mimir / Tenants" dashboard.
* [ENHANCEMENT] Dashboards: distinguish between label names and label values queries.
* [ENHANCEMENT] Dashboards: querier autoscaling now supports multiple scaled objects (configurable via `$._config.autoscale.querier.hpa_name`).
* [ENHANCEMENT] Queries dashboard: remove mention to store-gateway "streaming enabled" in panels because store-gateway only support streaming series since Mimir 2.7.
* [ENHANCEMENT] Queries: Display data touched per sec in bytes instead of number of items.
* [ENHANCEMENT] Ruler: Add panel description for Read QPS panel in Ruler dashboard to explain values when in remote ruler mode.
* [ENHANCEMENT] Support for baremetal deployment for alerts and scaling recording rules.
* [ENHANCEMENT] `_config.job_names.<job>` values can now be arrays of regular expressions in addition to a single string. Strings are still supported and behave as before.
* [ENHANCEMENT] dashboards: fix holes in graph for lightly loaded clusters
# 0.0.6 - March 2023
* [ENHANCEMENT] Add support for kubernetes via Grafana Agent Operator
# 0.0.5 - January 2023
* [BUGFIX] Dashboards: Fix legend showing `persistentvolumeclaim` when using `deployment_type=baremetal` for `Disk space utilization` panels.
* [BUGFIX] Dashboards: Remove "Inflight requests" from object store panels because the panel is not tracking the inflight requests to object storage.
* [BUGFIX] Ingester: remove series from ephemeral storage even if there are no persistent series.
* [CHANGE] Configuration: The format of the `autoscaling` section of the configuration has changed to support more components.
* Instead of specific config variables for each component, they are listed in a dictionary. For example, `autoscaling.querier_enabled` becomes `autoscaling.querier.enabled`.
* [CHANGE] Dashboards: Removed the `Querier > Stages` panel from the `Mimir / Queries` dashboard.
* [ENHANCEMENT] Configuration: Make it possible to configure namespace label, job label, and job prefix.
* [ENHANCEMENT] Dashboards: Add "remote read", "metadata", and "exemplar" queries to "Mimir / Overview" dashboard.
* [ENHANCEMENT] Dashboards: Add optional row about the Distributor's metric forwarding feature to the `Mimir / Writes` dashboard.
* [ENHANCEMENT] Dashboards: Add support to multi-zone deployments for the experimental read-write deployment mode.
* [ENHANCEMENT] Dashboards: Fix legend showing on per-pod panels.
* [ENHANCEMENT] Dashboards: If enabled, add new row to the `Mimir / Writes` for distributor autoscaling metrics.
* [ENHANCEMENT] Dashboards: Include inflight object store requests in "Reads" dashboard.
* [ENHANCEMENT] Dashboards: Include per-tenant request rate in "Tenants" dashboard.
* [ENHANCEMENT] Dashboards: Include rate of label and series queries in "Reads" dashboard.
* [ENHANCEMENT] Dashboards: Make queries used to find job, cluster and namespace for dropdown menus configurable.
* [ENHANCEMENT] Dashboards: Remove the "Instance Mapper" row from the "Alertmanager Resources Dashboard". This is a Grafana Cloud specific service and not relevant for external users.
* [ENHANCEMENT] Dashboards: Updated the "Writes" and "Rollout progress" dashboards to account for samples ingested via the new OTLP ingestion endpoint.
* [ENHANCEMENT] Dashboards: Use a consistent color across dashboards for the error rate.
* [ENHANCEMENT] Dashboards: Use non-red colors for non-error series in the "Mimir / Overview" dashboard.
* [ENHANCEMENT] Dashboards: Use the "req/s" unit on panels showing the requests rate.
* [ENHANCEMENT] Dashboards: improved resources and networking dashboards to work with read-write deployment mode too.
* [ENHANCEMENT] Improve phrasing in Overview dashboard.
* [ENHANCEMENT] Support for baremetal deployment for scaling recording rules.
* [FEATURE] Compile baremetal mixin along k8s mixin.
* [FEATURE] Dashboards: Added "Mimir / Overview networking" dashboard, providing an high level view over a Mimir cluster network bandwidth, inflight requests and TCP connections.
* [FEATURE] Dashboards: Added "Mimir / Overview resources" dashboard, providing an high level view over a Mimir cluster resources utilization.
* [FEATURE] Dashboards: Added "Mimir / Overview" dashboards, providing an high level view over a Mimir cluster.
# 0.0.4 - October 2022
* [CHANGE] remove the "Cache - Latency (old)" panel from the "Mimir / Queries" dashboard.
* [FEATURE] Added "Mimir / Overview" dashboards, providing an high level view over a Mimir cluster.
* [FEATURE] added support to experimental read-write deployment mode.
* [ENHANCEMENT] Updated the "Writes" and "Rollout progress" dashboards to account for samples ingested via the new OTLP ingestion endpoint.
* [ENHANCEMENT] Include per-tenant request rate in "Tenants" dashboard.
* [ENHANCEMENT] Include inflight object store requests in "Reads" dashboard.
* [ENHANCEMENT] Make queries used to find job, cluster and namespace for dropdown menus configurable.
* [ENHANCEMENT] Include rate of label and series queries in "Reads" dashboard.
* [ENHANCEMENT] Fix legend showing on per-pod panels.
* [ENHANCEMENT] Use the "req/s" unit on panels showing the requests rate.
* [ENHANCEMENT] Use a consistent color across dashboards for the error rate.
* [ENHANCEMENT] allow to configure graph tooltip.
* [ENHANCEMENT] added support to query-tee in front of ruler-query-frontend in the "Remote ruler reads" dashboard.
* [ENHANCEMENT] Introduce support for baremetal deployment, setting `deployment_type: 'baremetal'` in the mixin `_config`.
* [ENHANCEMENT] use timeseries panel to show exemplars.
* [BUGFIX] stop setting 'interval' in dashboards; it should be set on your datasource.
# 0.0.3 - September 2022
* Update mixin to latest version.
# 0.0.2 - June 2022
* Update documentation to mention the Helm chart metamonitoring feature
# 0.0.1 - June 2022
* Initial releaseCost
By connecting your Self-hosted Mimir instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
