macOS integration for Grafana Cloud
The macOS integration uses the agent to collect metrics related to the operating system, including aspects like CPU usage, load average, memory usage, and disk and networking I/O. It also supports system logs being scraped by the agent using promtail. An accompanying dashboard is provided to visualize these metrics and logs.
The macOS integration is based on macOS mixin, which is in fact slightly modified node-observ-lib.
This integration includes 9 useful alerts and 2 pre-built dashboards to help monitor and visualize macOS metrics and logs.
Before you begin
This integration running MacOS machine running alongside Grafana Alloy.
Each MacOS node being observed must have a dedicated Grafana Alloy running.
Install macOS integration for Grafana Cloud
- Find macOS and click its tile to open the integration.
- Review the prerequisites in the Configuration Details tab and set up Grafana Agent to send macOS metrics and logs to your Grafana Cloud instance.
- Click Install to add this integration’s pre-built dashboards and alerts to your Grafana Cloud instance, and you can start monitoring your macOS setup.
Simple mode
These snippets are configured to scrape a single macOS instance running locally with default ports.
Integrations snippets
prometheus.exporter.unix "integrations_node_exporter" { }
discovery.relabel "integrations_node_exporter" {
targets = prometheus.exporter.unix.integrations_node_exporter.targets
rule {
target_label = "instance"
replacement = constants.hostname
rule {
target_label = "job"
replacement = "integrations/macos-node"
prometheus.scrape "integrations_node_exporter" {
targets = discovery.relabel.integrations_node_exporter.output
job_name = "integrations/node_exporter"
Logs snippets
darwin
Advanced mode
To instruct Grafana Alloy to scrape your macOS instances, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
rule {
rule {
This integrations uses the prometheus.exporter.unix component to generate metrics from a macOS instance.
For the full array of configuration options, refer to the prometheus.exporter.unix component reference documentation.
This exporter must be linked with a discovery.relabel component to apply the necessary relabelings.
For each macOS instance to be monitored you must create a pair of these components.
component:
instance
label:constants.hostname
sets theinstance
label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this macOS instance. Make sure this label value is the same for all telemetry data collected for this instance.
You can then scrape them by including each discovery.relabel
under targets
within the prometheus.scrape component.
Note that on Macs with an M1 architecture you might encounter errors similar to the following:
level=error integration=node_exporter msg="collector failed" name=thermal duration_seconds=0.001089125 err="no CPU power status has been recorded"
To avoid collector errors, you can add disable_collectors
setting to the prometheus.exporter.unix
component to disable it:
disable_collectors = ["thermal"]
Advanced logs snippets
darwin
To monitor your macOS instance logs, you will use a combination of the following components:
local.file_match defines where to find the log file to be scraped. Change the following properties according to your environment:
__address__
: The macOS instance address__path__
: The path to the log file.instance
sets theinstance
loki.process defines how to process logs before sending it to Loki.
loki.source.file sends logs to Loki.
This integration running MacOS machine running alongside Grafana Agent.
Each MacOS node being observed must have a dedicated Grafana Agent running.
Post-install configuration for the macOS integration
This integration is configured to work with the node_exporter
, which is embedded in Grafana Agent.
Enable the integration by adding the provided snippets to your agent configuration file.
This integration supports metrics and logs from MacOS.
If you want to show logs and metrics signals correlated in your dashboards, as a single pane of glass, ensure the following:
job
andinstance
label values must match fornode_exporter
integration andlogs
scrape config in your agent configuration file.job
label must be set tointegrations/macos-node
(already configured in the snippets).instance
label must be set to a value that uniquely identifies your MacOS Node. Please replace it according to your environment, it should be set manually. Please note that if you uselocalhost
for multiple nodes the dashboards will not be able to filter correctly by instance.
setting to the node_exporter integration to disable it:
disable_collectors:
- thermal # disable on M1
For a full description of configuration options see how to configure the node_exporter_config
block in the agent documentation.
Below integrations
node_exporter:
enabled: true
relabel_configs:
- replacement: '<your-instance-name>'
target_label: instance
- replacement: "integrations/macos-node"
target_label: job
- job_name: integrations/node_exporter_direct_scrape
static_configs:
- targets:
- localhost
labels:
__path__: /var/log/*.log
instance: '<your-instance-name>'
job: integrations/macos-node
pipeline_stages:
- multiline:
firstline: '^([\w]{3} )?[\w]{3} +[\d]+ [\d]+:[\d]+:[\d]+|[\w]{4}-[\w]{2}-[\w]{2} [\w]{2}:[\w]{2}:[\w]{2}(?:[+-][\w]{2})?'
- regex:
expression: '(?P<timestamp>([\w]{3} )?[\w]{3} +[\d]+ [\d]+:[\d]+:[\d]+|[\w]{4}-[\w]{2}-[\w]{2} [\w]{2}:[\w]{2}:[\w]{2}(?:[+-][\w]{2})?) (?P<hostname>\S+) (?P<sender>.+?)\[(?P<pid>\d+)\]:? (?P<message>(?s:.*))$'
- labels:
sender:
hostname:
pid:
- match:
selector: '{sender!="", pid!=""}'
stages:
- template:
source: message
template: '{{ .sender }}[{{ .pid }}]: {{ .message }}'
- labeldrop:
- pid
- output:
source: message
Refer to the following Grafana Agent configuration for a complete example that contains all the snippets used for the macOS integration. This example also includes metrics that are sent to monitor your Grafana Agent instance.
Dashboards
The macOS integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- MacOS / logs
- MacOS / overview
MacOS overview
MacOS logs
Alerts
The macOS integration includes the following useful alerts:
darwin-filesystem-alerts
darwin-alerts
Metrics
The most important metrics provided by the macOS integration, which are used on the pre-built dashboards and Prometheus alerts, are as follows:
- node_boot_time_seconds
- node_cpu_seconds_total
- node_disk_io_time_seconds_total
- node_disk_read_bytes_total
- node_disk_written_bytes_total
- node_filesystem_avail_bytes
- node_filesystem_files
- node_filesystem_files_free
- node_filesystem_readonly
- node_filesystem_size_bytes
- node_load1
- node_load15
- node_load5
- node_memory_compressed_bytes
- node_memory_internal_bytes
- node_memory_purgeable_bytes
- node_memory_swap_total_bytes
- node_memory_swap_used_bytes
- node_memory_total_bytes
- node_memory_wired_bytes
- node_network_receive_bytes_total
- node_network_receive_drop_total
- node_network_receive_errs_total
- node_network_receive_packets_total
- node_network_transmit_bytes_total
- node_network_transmit_drop_total
- node_network_transmit_errs_total
- node_network_transmit_packets_total
- node_os_info
- node_textfile_scrape_error
- node_uname_info
- up
Changelog
Cost
By connecting your macOS instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
