title: "Self-hosted Grafana Loki integration | Grafana Cloud documentation"
description: "Learn about Self-hosted Grafana Loki Grafana Cloud integration."
# Self-hosted Grafana Loki integration for Grafana Cloud
Send self-monitoring metrics and logs from Grafana Loki or GEL running in your Kubernetes cluster to Grafana Cloud. The integration comes with dashboards to help monitor the health of your Loki or GEL cluster as well as understand per-tenant usage and behavior.
This integration includes 4 useful alerts and 10 pre-built dashboards to help monitor and visualize Self-hosted Grafana Loki metrics and logs.
## Before you begin
This integration works with the Loki helm chart deployed on Kubernetes.
## Install Self-hosted Grafana Loki integration for Grafana Cloud
1. In your Grafana Cloud stack, click **Connections** in the left-hand menu.
2. Find **Self-hosted Grafana Loki** and click its tile to open the integration.
3. Review the prerequisites in the **Configuration Details** tab and set up Grafana Alloy to send Self-hosted Grafana Loki metrics and logs to your Grafana Cloud instance.
4. Click **Install** to add this integration’s pre-built dashboards and alerts to your Grafana Cloud instance, and you can start monitoring your Self-hosted Grafana Loki setup.
## Configuration snippets for Grafana Alloy
### Simple mode
This integration does not officially support Grafana Alloy yet, but you can use the following snippet as a reference on how to scrape Loki deployed with the helm chart using Grafana Alloy.
### Metrics snippets
Alloy ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```alloy
discovery.relabel "loki" {
    targets = discovery.kubernetes.services.targets
    rule {
        source_labels = ["__meta_kubernetes_service_label_<loki_pod_label>"]
        regex = "<loki_pod_label_value>"
        action = "keep"
    rule {
        source_labels = ["__meta_kubernetes_service_port_number"]
        regex = "<loki_prometheus_port_number>"
        action = "keep"
    rule {
        source_labels = ["__meta_kubernetes_pod_name"]
        target_label = "instance"
prometheus.scrape "loki" {
    job_name     = "integrations/loki"
    targets      = discovery.relabel.loki.output
    honor_labels = true
    forward_to   = [prometheus.relabel.metrics_service.receiver]
## Dashboards
The Self-hosted Grafana Loki integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- Loki / Chunks
- Loki / Deletion
- Loki / Logs
- Loki / Operational
- Loki / Reads
- Loki / Reads Resources
- Loki / Recording Rules
- Loki / Retention
- Loki / Writes
- Loki / Writes Resources
## Alerts
The Self-hosted Grafana Loki integration includes the following useful alerts:
Expand table
| Alert                        | Description        |
| LokiRequestErrors            | Critical: {{ $labels.job }} {{ $labels.route }} is experiencing {{ printf “%.2f” $value }}% errors.                                               |
| LokiRequestPanics            | Critical: {{ $labels.job }} is experiencing {{ printf “%.2f” $value }}% increase of panics.                                                       |
| LokiRequestLatency           | Critical: {{ $labels.job }} {{ $labels.route }} is experiencing {{ printf “%.2f” $value }}s 99th percentile latency.                              |
| LokiTooManyCompactorsRunning | Warning: {{ $labels.namespace }} has had {{ printf “%.0f” $value }} compactors running for more than 5m. Only one compactor should run at a time. |
## Metrics
The most important metrics provided by the Self-hosted Grafana Loki integration, which are used on the pre-built dashboards and Prometheus alerts, are as follows:
- container\_cpu\_usage\_seconds\_total
- container\_fs\_writes\_bytes\_total
- container\_memory\_working\_set\_bytes
- container\_network\_receive\_bytes\_total
- container\_network\_transmit\_bytes\_total
- container\_spec\_cpu\_period
- container\_spec\_cpu\_quota
- container\_spec\_memory\_limit\_bytes
- cortex\_dynamo\_consumed\_capacity\_total
- cortex\_dynamo\_dropped\_requests\_total
- cortex\_dynamo\_failures\_total
- cortex\_dynamo\_query\_pages\_count
- cortex\_dynamo\_request\_duration\_seconds\_bucket
- cortex\_dynamo\_request\_duration\_seconds\_count
- cortex\_dynamo\_throttled\_total
- cortex\_ingester\_flush\_queue\_length
- go\_gc\_duration\_seconds
- go\_goroutines
- go\_memstats\_heap\_inuse\_bytes
- job:loki\_request\_duration\_seconds\_bucket:sum\_rate
- job:loki\_request\_duration\_seconds\_count:sum\_rate
- job:loki\_request\_duration\_seconds\_sum:sum\_rate
- job\_route:loki\_request\_duration\_seconds\_bucket:sum\_rate
- job\_route:loki\_request\_duration\_seconds\_count:sum\_rate
- job\_route:loki\_request\_duration\_seconds\_sum:sum\_rate
- kube\_deployment\_created
- kube\_persistentvolumeclaim\_labels
- kube\_pod\_container\_info
- kube\_pod\_container\_status\_last\_terminated\_reason
- kube\_pod\_container\_status\_restarts\_total
- kubelet\_volume\_stats\_capacity\_bytes
- kubelet\_volume\_stats\_used\_bytes
- loki\_azure\_blob\_request\_duration\_seconds\_bucket
- loki\_azure\_blob\_request\_duration\_seconds\_count
- loki\_bigtable\_request\_duration\_seconds\_bucket
- loki\_bigtable\_request\_duration\_seconds\_count
- loki\_boltdb\_shipper\_compact\_tables\_operation\_duration\_seconds
- loki\_boltdb\_shipper\_compact\_tables\_operation\_last\_successful\_run\_timestamp\_seconds
- loki\_boltdb\_shipper\_compact\_tables\_operation\_total
- loki\_boltdb\_shipper\_compactor\_running
- loki\_boltdb\_shipper\_query\_readiness\_duration\_seconds
- loki\_boltdb\_shipper\_request\_duration\_seconds\_bucket
- loki\_boltdb\_shipper\_request\_duration\_seconds\_count
- loki\_boltdb\_shipper\_request\_duration\_seconds\_sum
- loki\_boltdb\_shipper\_retention\_marker\_count\_total
- loki\_boltdb\_shipper\_retention\_marker\_table\_processed\_duration\_seconds\_bucket
- loki\_boltdb\_shipper\_retention\_marker\_table\_processed\_duration\_seconds\_count
- loki\_boltdb\_shipper\_retention\_marker\_table\_processed\_duration\_seconds\_sum
- loki\_boltdb\_shipper\_retention\_marker\_table\_processed\_total
- loki\_boltdb\_shipper\_retention\_sweeper\_chunk\_deleted\_duration\_seconds\_bucket
- loki\_boltdb\_shipper\_retention\_sweeper\_chunk\_deleted\_duration\_seconds\_count
- loki\_boltdb\_shipper\_retention\_sweeper\_chunk\_deleted\_duration\_seconds\_sum
- loki\_boltdb\_shipper\_retention\_sweeper\_marker\_file\_processing\_current\_time
- loki\_boltdb\_shipper\_retention\_sweeper\_marker\_files\_current
- loki\_build\_info
- loki\_chunk\_store\_deduped\_chunks\_total
- loki\_chunk\_store\_index\_entries\_per\_chunk\_count
- loki\_chunk\_store\_index\_entries\_per\_chunk\_sum
- loki\_compactor\_delete\_requests\_processed\_total
- loki\_compactor\_delete\_requests\_received\_total
- loki\_compactor\_deleted\_lines
- loki\_compactor\_load\_pending\_requests\_attempts\_total
- loki\_compactor\_oldest\_pending\_delete\_request\_age\_seconds
- loki\_compactor\_pending\_delete\_requests\_count
- loki\_consul\_request\_duration\_seconds\_bucket
- loki\_discarded\_samples\_total
- loki\_distributor\_bytes\_received\_total
- loki\_distributor\_ingester\_append\_failures\_total
- loki\_distributor\_lines\_received\_total
- loki\_gcs\_request\_duration\_seconds\_bucket
- loki\_gcs\_request\_duration\_seconds\_count
- loki\_ingester\_chunk\_age\_seconds\_bucket
- loki\_ingester\_chunk\_age\_seconds\_count
- loki\_ingester\_chunk\_age\_seconds\_sum
- loki\_ingester\_chunk\_bounds\_hours\_bucket
- loki\_ingester\_chunk\_bounds\_hours\_count
- loki\_ingester\_chunk\_bounds\_hours\_sum
- loki\_ingester\_chunk\_entries\_bucket
- loki\_ingester\_chunk\_entries\_count
- loki\_ingester\_chunk\_entries\_sum
- loki\_ingester\_chunk\_size\_bytes\_bucket
- loki\_ingester\_chunk\_utilization\_bucket
- loki\_ingester\_chunk\_utilization\_count
- loki\_ingester\_chunk\_utilization\_sum
- loki\_ingester\_chunks\_flushed\_total
- loki\_ingester\_memory\_chunks
- loki\_ingester\_memory\_streams
- loki\_ingester\_streams\_created\_total
- loki\_memcache\_request\_duration\_seconds\_bucket
- loki\_memcache\_request\_duration\_seconds\_count
- loki\_panic\_total
- loki\_request\_duration\_seconds\_bucket
- loki\_request\_duration\_seconds\_count
- loki\_request\_duration\_seconds\_sum
- loki\_ruler\_wal\_appender\_ready
- loki\_ruler\_wal\_disk\_size
- loki\_ruler\_wal\_prometheus\_remote\_storage\_highest\_timestamp\_in\_seconds
- loki\_ruler\_wal\_prometheus\_remote\_storage\_queue\_highest\_sent\_timestamp\_seconds
- loki\_ruler\_wal\_prometheus\_remote\_storage\_samples\_pending
- loki\_ruler\_wal\_prometheus\_remote\_storage\_samples\_total
- loki\_ruler\_wal\_samples\_appended\_total
- loki\_ruler\_wal\_storage\_created\_series\_total
- loki\_s3\_request\_duration\_seconds\_bucket
- loki\_s3\_request\_duration\_seconds\_count
- namespace\_job\_route:loki\_request\_duration\_seconds:99quantile
- node\_disk\_read\_bytes\_total
- node\_disk\_written\_bytes\_total
- node\_namespace\_pod\_container:container\_cpu\_usage\_seconds\_total:sum\_irate
- promtail\_custom\_bad\_words\_total
- up
## Changelog
md ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```md
# 1.0.0 - December 2025
* Chore: Fix incorrect semver to 1.0.0. No further changes
# 0.0.2 - August 2023
# 0.0.1 - September 2022
* Initial Release
## Cost
By connecting your Self-hosted Grafana Loki instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see [Active series and dpm usage](/docs/grafana-cloud/fundamentals/active-series-and-dpm/) and [Cloud tier pricing](/products/cloud/pricing/).
