Linux is a family of open-source Unix-like operating systems based on the Linux kernel. Linux is the leading operating system on servers, and is one of the most prominent examples of free and open-source software collaboration.
The Grafana Linux Server integration collects metrics related to the operating system running on a node, including CPU usage, load average, memory usage, and disk and networking I/O using node_exporter integration.
You can also configure Alloy to collect logs.Linux Server integration for Grafana Cloud
Linux Server integration for Grafana Cloud enables you to collect metrics related to the operating system running on a node, including aspects like CPU usage, load average, memory usage, and disk and networking I/O using node_exporter integration. It also allows you to use Grafana Alloy to scrape logs.
This integration includes 24 useful alerts and 7 pre-built dashboards to help monitor and visualize Linux Server metrics and logs.
Before you begin
Each Linux node being observed must have its dedicated Grafana Alloy running.
If you want to monitor more than one Linux Node with this integration, we recommend you to use the Ansible collection for Grafana Cloud to deploy Grafana Alloy to multiple machines, as described in this documentation.
Install Linux Server integration for Grafana Cloud
- Find Linux Server and click its tile to open the integration.
- Review the prerequisites in the Configuration Details tab and set up Grafana Alloy to send Linux Server metrics and logs to your Grafana Cloud instance.
- Click Install to add this integration’s pre-built dashboards and alerts to your Grafana Cloud instance, and you can start monitoring your Linux Server setup.
Simple mode
These snippets are configured to scrape a single Linux Server instance running locally with default ports.
Manually copy and append the following snippets into your Grafana Alloy configuration file.
Integrations snippets
discovery.relabel "integrations_node_exporter" {
targets = prometheus.exporter.unix.integrations_node_exporter.targets
rule {
target_label = "instance"
replacement = constants.hostname
rule {
target_label = "job"
replacement = "integrations/node_exporter"
prometheus.exporter.unix "integrations_node_exporter" {
disable_collectors = ["ipvs", "btrfs", "infiniband", "xfs", "zfs"]
filesystem {
fs_types_exclude = "^(autofs|binfmt_misc|bpf|cgroup2?|configfs|debugfs|devpts|devtmpfs|tmpfs|fusectl|hugetlbfs|iso9660|mqueue|nsfs|overlay|proc|procfs|pstore|rpc_pipefs|securityfs|selinuxfs|squashfs|sysfs|tracefs)$"
mount_points_exclude = "^/(dev|proc|run/credentials/.+|sys|var/lib/docker/.+)($|/)"
mount_timeout = "5s"
netclass {
ignored_devices = "^(veth.*|cali.*|[a-f0-9]{15})$"
netdev {
device_exclude = "^(veth.*|cali.*|[a-f0-9]{15})$"
prometheus.scrape "integrations_node_exporter" {
targets = discovery.relabel.integrations_node_exporter.output
forward_to = [prometheus.relabel.integrations_node_exporter.receiver]
prometheus.relabel "integrations_node_exporter" {
rule {
source_labels = ["__name__"]
regex = "node_scrape_collector_.+"
action = "drop"
}Logs snippets
linux
loki.relabel "integrations_node_exporter" {
forward_to = [loki.write.grafana_cloud_loki.receiver]
rule {
rule {
journal_module "integrations_node_exporter" {
forward_to = [loki.relabel.integrations_node_exporter.receiver]
//JOURNAL
declare "journal_module" {
argument "forward_to" {
optional = false
loki.source.journal "default" {
max_age = "12h0m0s"
forward_to = [loki.process.default.receiver]
relabel_rules = loki.relabel.default.rules
loki.relabel "default" {
rule {
source_labels = ["__journal__systemd_unit"]
target_label = "unit"
rule {
source_labels = ["__journal__boot_id"]
target_label = "boot_id"
rule {
source_labels = ["__journal__transport"]
target_label = "transport"
rule {
source_labels = ["__journal_priority_keyword"]
target_label = "level"
forward_to = []
loki.process "default" {
forward_to = argument.forward_to.value
}Advanced mode
To instruct Grafana Alloy to scrape your Linux Server instance, go though the subsequent instructions.
The snippets provide examples to guide you through the configuration process.
First, Manually copy and append the following snippets into your Grafana Alloy configuration file.
Then follow the instructions below to modify the necessary variables.
rule {
rule {
filesystem {
netclass {
netdev {
rule {
action = "drop"
}This integration uses the prometheus.exporter.unix component to collect system metrics.
The supplied configuration is tuned to exclude any metrics from the exporter which are not used by the integration’s dashboards, alerts, or recording rules. If a broader configuration which includes additional metrics is desired, the prometheus.exporter.unix component can be adjusted accordingly.
Advanced logs snippets
linux
rule {
rule {
filelogs_module "integrations_node_exporter" {
//FILELOGS
declare "filelogs_module" {
optional = false
local.file_match "default" {
path_targets = [{
__address__ = "localhost",
__path__ = "/var/log/{syslog,messages,*.log}",
loki.source.file "default" {
targets = local.file_match.default.targets
//JOURNAL
optional = false
max_age = "12h0m0s"
rule {
rule {
rule {
rule {
forward_to = []
}This integration uses the loki.source.journal, and local.file_match components to collect system logs.
This includes the systemd journal and the file(s) matching /var/log/{syslog,messages,*.log}.
If you wish to capture other log files, you must add new new maps to the path_targets list parameter of the local.file_match component. If you wish for these additionally captured logs to be labeled so that they can be seen in Linux Node integration logs dashboard, the entry must include the same instance and job labels.
Kubernetes instructions
Before you begin with Kubernetes
These instructions assume the use of the Kubernetes Monitoring Helm chart.
Configuration snippets for Kubernetes Helm chart
To scrape your Linux nodes of the Kubernetes cluster, ensure that your Kubernetes Monitoring Helm chart values has these configuration snippets.
Metrics snippets
alloy-metrics:
enabled: true
clusterMetrics:
enabled: true
node-exporter:
enabled: true
metricsTuning:
useIntegrationAllowList: trueLogs snippets
alloy-logs:
enabled: true
nodeLogs:
enabled: true
journal:
jobLabel: "integrations/node_exporter"
labelsToKeep:
["instance", "job", "level", "name", "unit", "service_name", "source", "transport", "boot_id"]
extraLogProcessingStages: |
stage.labels {
values = {
boot_id = "__journal__boot_id",
transport = "__journal__transport",
} Dashboards
The Linux Server integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- Linux node / CPU and system
- Linux node / filesystem and disks
- Linux node / fleet overview
- Linux node / logs
- Linux node / memory
- Linux node / network
- Linux node / overview
Node overview dashboard
Fleet overview dashboard
Drill down dashboards: Network interfaces
Alerts
The Linux Server integration includes the following useful alerts:
node-exporter-filesystem
node-exporter
Metrics
The most important metrics provided by the Linux Server integration, which are used on the pre-built dashboards and Prometheus alerts, are as follows:
- instance:node_num_cpu:sum
- node_arp_entries
- node_boot_time_seconds
- node_context_switches_total
- node_cpu_seconds_total
- node_disk_io_time_seconds_total
- node_disk_io_time_weighted_seconds_total
- node_disk_read_bytes_total
- node_disk_read_time_seconds_total
- node_disk_reads_completed_total
- node_disk_write_time_seconds_total
- node_disk_writes_completed_total
- node_disk_written_bytes_total
- node_filefd_allocated
- node_filefd_maximum
- node_filesystem_avail_bytes
- node_filesystem_device_error
- node_filesystem_files
- node_filesystem_files_free
- node_filesystem_readonly
- node_filesystem_size_bytes
- node_intr_total
- node_load1
- node_load15
- node_load5
- node_md_disks
- node_md_disks_required
- node_memory_Active_anon_bytes
- node_memory_Active_bytes
- node_memory_Active_file_bytes
- node_memory_AnonHugePages_bytes
- node_memory_AnonPages_bytes
- node_memory_Bounce_bytes
- node_memory_Buffers_bytes
- node_memory_Cached_bytes
- node_memory_CommitLimit_bytes
- node_memory_Committed_AS_bytes
- node_memory_DirectMap1G_bytes
- node_memory_DirectMap2M_bytes
- node_memory_DirectMap4k_bytes
- node_memory_Dirty_bytes
- node_memory_HugePages_Free
- node_memory_HugePages_Rsvd
- node_memory_HugePages_Surp
- node_memory_HugePages_Total
- node_memory_Hugepagesize_bytes
- node_memory_Inactive_anon_bytes
- node_memory_Inactive_bytes
- node_memory_Inactive_file_bytes
- node_memory_Mapped_bytes
- node_memory_MemAvailable_bytes
- node_memory_MemFree_bytes
- node_memory_MemTotal_bytes
- node_memory_SReclaimable_bytes
- node_memory_SUnreclaim_bytes
- node_memory_ShmemHugePages_bytes
- node_memory_ShmemPmdMapped_bytes
- node_memory_Shmem_bytes
- node_memory_Slab_bytes
- node_memory_SwapTotal_bytes
- node_memory_VmallocChunk_bytes
- node_memory_VmallocTotal_bytes
- node_memory_VmallocUsed_bytes
- node_memory_WritebackTmp_bytes
- node_memory_Writeback_bytes
- node_netstat_Icmp6_InErrors
- node_netstat_Icmp6_InMsgs
- node_netstat_Icmp6_OutMsgs
- node_netstat_Icmp_InErrors
- node_netstat_Icmp_InMsgs
- node_netstat_Icmp_OutMsgs
- node_netstat_IpExt_InOctets
- node_netstat_IpExt_OutOctets
- node_netstat_TcpExt_ListenDrops
- node_netstat_TcpExt_ListenOverflows
- node_netstat_TcpExt_TCPSynRetrans
- node_netstat_Tcp_InErrs
- node_netstat_Tcp_InSegs
- node_netstat_Tcp_OutRsts
- node_netstat_Tcp_OutSegs
- node_netstat_Tcp_RetransSegs
- node_netstat_Udp6_InDatagrams
- node_netstat_Udp6_InErrors
- node_netstat_Udp6_NoPorts
- node_netstat_Udp6_OutDatagrams
- node_netstat_Udp6_RcvbufErrors
- node_netstat_Udp6_SndbufErrors
- node_netstat_UdpLite_InErrors
- node_netstat_Udp_InDatagrams
- node_netstat_Udp_InErrors
- node_netstat_Udp_NoPorts
- node_netstat_Udp_OutDatagrams
- node_netstat_Udp_RcvbufErrors
- node_netstat_Udp_SndbufErrors
- node_network_carrier
- node_network_info
- node_network_mtu_bytes
- node_network_receive_bytes_total
- node_network_receive_compressed_total
- node_network_receive_drop_total
- node_network_receive_errs_total
- node_network_receive_fifo_total
- node_network_receive_multicast_total
- node_network_receive_packets_total
- node_network_speed_bytes
- node_network_transmit_bytes_total
- node_network_transmit_compressed_total
- node_network_transmit_drop_total
- node_network_transmit_errs_total
- node_network_transmit_fifo_total
- node_network_transmit_multicast_total
- node_network_transmit_packets_total
- node_network_transmit_queue_length
- node_network_up
- node_nf_conntrack_entries
- node_nf_conntrack_entries_limit
- node_os_info
- node_procs_running
- node_sockstat_FRAG6_inuse
- node_sockstat_FRAG_inuse
- node_sockstat_RAW6_inuse
- node_sockstat_RAW_inuse
- node_sockstat_TCP6_inuse
- node_sockstat_TCP_alloc
- node_sockstat_TCP_inuse
- node_sockstat_TCP_mem
- node_sockstat_TCP_mem_bytes
- node_sockstat_TCP_orphan
- node_sockstat_TCP_tw
- node_sockstat_UDP6_inuse
- node_sockstat_UDPLITE6_inuse
- node_sockstat_UDPLITE_inuse
- node_sockstat_UDP_inuse
- node_sockstat_UDP_mem
- node_sockstat_UDP_mem_bytes
- node_sockstat_sockets_used
- node_softnet_dropped_total
- node_softnet_processed_total
- node_softnet_times_squeezed_total
- node_systemd_service_restart_total
- node_systemd_unit_state
- node_textfile_scrape_error
- node_time_zone_offset_seconds
- node_timex_estimated_error_seconds
- node_timex_maxerror_seconds
- node_timex_offset_seconds
- node_timex_sync_status
- node_uname_info
- node_vmstat_oom_kill
- node_vmstat_pgfault
- node_vmstat_pgmajfault
- node_vmstat_pgpgin
- node_vmstat_pgpgout
- node_vmstat_pswpin
- node_vmstat_pswpout
- process_max_fds
- process_open_fds
- up
Changelog
# 1.6.3 - July 2026
* Remove Asserts resource recording rules now covered natively by the Asserts base pipeline
# 1.6.2 - May 2025
* Update Kubernetes Helm chart snippets.
# 1.6.1 - April 2025
* Update log snippets:
* Use new snippets to see journal logs on Node logs dashboard filters.
# 1.6.0 - March 2025
* Update node mixin:
* Add 'Load average' and 'Network usage' panels to fleet dashboard
* Fix legends in disk panels on fleet dashboard
* Fix CPU usage (per core) query.
# 1.5.2 - January 2025
* Fix status panel metrics data source.
# 1.5.1 - January 2025
* Fix status panel logs query.
# 1.5.0 - January 2025
* Update node mixin, add new alerts:
* NodeHasRebooted
* NodeProcessesCountIsHigh
* Fix logs dashboard not showing any logs if cluster label is missing.
# 1.4.2 - November 2024
* Update Log dashboard job selector to always have a selected option.
# 1.4.1 - November 2024
* Update status panel check queries.
# 1.4.0 - September 2024
* Add asserts support.
# 1.3.0 - June 2024
* Add new alert: NodeSystemdServiceCrashlooping
* Fix links in the fleet overview table.
# 1.2.3 - December 2023
* Accept `integrations/unix` for compatibility with default flow mode node_exporter job name.
# 1.2.2 - December 2023
* Fix issues with showing data on dashboards when `cluster` label has no value.
# 1.2.1 - December 2023
* Fix queries for memoryBuffers memoryCached metrics
* Update network traffic panels to show only interfaces that had traffic
* Update network errors/drops panels to show only values greater than 0.
# 1.2.0 - November 2023
* Dashboards prefixes are changed to 'Linux node/ '
* Add new Loki based annotations:
* Service failed
* Critical system event
* Session (ssh,console) opened/closed
* Apply panel changes, some examples:
* Use Sentence case in titles
* Memory TS panel: Show only 'Memory total' and 'Memory used' by default
* CPU usage TS panel: Use Blue-Yellow-Red color Schema
* Add OS and group labels(job, cluster) as columns in Fleet overview table
* NodeSystemSaturation alert severity is set to warning
* Attach integration status panel to fleet and logs dashboards.
# 1.1.2 - August 2023
* Add regex filter for logs datasource.
# 1.1.1 - July 2023
# 1.1.0 - June 2023
* This update introduces generic logs dashboard 'Node Exporter / Node Logs'
* Drop log panels 'Node Overview' dashboard.
# 1.0.1 - June 2023
* This update includes the following, by updating to the latest mixin:
* Panel description typos have been fixed
* Incorrect data links in the "Node Fleet Overview" Dashboard now correctly include the dashboard selector.
# 1.0.0 - April 2023
* This update introduces 3-tier view of linux nodes:
* TOP: Fleet view: see group of your linux instances at once
* Overview of the specific node: see specific node at a glance
* Drill down: Set of dashboards for deep analysis using advanced metrics (Memory, CPU and System, Filesystem and Disk, Networking)
* Links and data links are provided for better navigation between views
* Update agent's filter config in docs, to reduce number of timeseries generated per node
* Metrics filter instructions to exclude dynamic network devices, temp filesystems and extended scrape statistics
* Remove USE dashboards
* Convert all graphs to timeseries panels
* Add information row
* New alerts
* Split alerts into two alert groups
* Annotations for events: Reboot, OOMkill, and 'Kernel update'.
# 0.0.8 - October 2022
* Update upstream node_exporter mixin
* Enable multicluster dashboards for use in kubernetes.
* Add direct log file scrape to the agent snippets.
# 0.0.7 - September 2022
* Remove source_address from relabel_configs.
# 0.0.6 - May 2022
* Reverse fsSpaceAvailableCriticalThreshold and fsSpaceAvailableWarningThreshold
* Update units for disk and networking panels.
# 0.0.5 - May 2022
* Update 'Disk Space Usage' panel to table format.
# 0.0.4 - April 2022
* Fixed alerts and recording rules by providing proper nodeSelector.
# 0.0.3 - February 2022
* Added logs support from Loki datasource.
# 0.0.2 - October 2021
* Update all rate queries to use `$__rate_interval`.
# 0.0.1 - June 2020
* Initial release.Cost
By connecting your Linux Server instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
