Go integration for Grafana Cloud
The Go programming language (golang) is a programming language designed at Google to make programmers more productive in applications with strong networking concurrency needs. This integration enables the agent to send Golang runtime metrics instrumented by Prometheus client_golang or OpenTelemetry Golang runtime metrics to Grafana Cloud along with a useful default dashboard for visualization.
This integration includes 1 pre-built dashboard to help monitor and visualize Go metrics.
Before you begin
This integration monitors the Go runtime for a process that exposes metrics through Golang client.
Please check the docs for details on how to expose your Go runtime metrics.
Install Go integration for Grafana Cloud
- Find Go and click its tile to open the integration.
- Review the prerequisites in the Configuration Details tab and set up Grafana Agent to send Go metrics to your Grafana Cloud instance.
- Click Install to add this integration’s pre-built dashboard to your Grafana Cloud instance, and you can start monitoring your Go setup.
Simple mode
These snippets are configured to scrape a single Go instance running locally with default ports.
Metrics snippets
discovery.relabel "metrics_integrations_integrations_go" {
targets = [{
__address__ = "localhost:8080",
rule {
target_label = "instance"
replacement = constants.hostname
prometheus.scrape "metrics_integrations_integrations_go" {
targets = discovery.relabel.metrics_integrations_integrations_go.output
job_name = "integrations/go"
Advanced mode
To instruct Grafana Alloy to scrape your Go instances, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
Advanced metrics snippets
targets = [{
rule {
To monitor your Go instance, you must use a discovery.relabel component to discover your Go Prometheus endpoint and apply appropriate labels, followed by a prometheus.scrape component to scrape it.
component:
__address__
: The address to your Go Prometheus metrics endpoint.instance
label:constants.hostname
sets theinstance
label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this Go instance.
If you have multiple Go servers to scrape, configure one discovery.relabel
for each and scrape them by including each under targets
within the prometheus.scrape
component.
Post-install configuration for the Go integration
After enabling the metrics generation, you should instruct Grafana Agent to scrape your go runtime instance.
The client_golang lib exposes a /metrics
endpoint. To scrape it, add the provided snippet to your agent configuration file.
Make sure to change targets
in the snippet according to your environment.
- job_name: integrations/go
relabel_configs:
- replacement: '<your-instance-name>'
target_label: instance
static_configs:
- targets: ['localhost:8080']
Refer to the following Grafana Agent configuration for a complete example that contains all the snippets used for the Go integration. This example also includes metrics that are sent to monitor your Grafana Agent instance.
Dashboards
The Go integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- Golang runtime
Go runtime metrics
Metrics
The most important metrics provided by the Go integration, which are used on the pre-built dashboard, are as follows:
- go_cgo_go_to_c_calls_calls_total
- go_gc_duration_seconds
- go_goroutines
- go_info
- go_memstats_alloc_bytes
- go_memstats_buck_hash_sys_bytes
- go_memstats_gc_sys_bytes
- go_memstats_heap_alloc_bytes
- go_memstats_heap_idle_bytes
- go_memstats_heap_inuse_bytes
- go_memstats_heap_objects
- go_memstats_heap_released_bytes
- go_memstats_heap_sys_bytes
- go_memstats_mcache_sys_bytes
- go_memstats_mspan_sys_bytes
- go_memstats_other_sys_bytes
- go_memstats_stack_sys_bytes
- go_memstats_sys_bytes
- go_threads
- process_runtime_go_cgo_calls
- process_runtime_go_gc_pause_ns_bucket
- process_runtime_go_goroutines
- process_runtime_go_mem_heap_alloc
- process_runtime_go_mem_heap_alloc_bytes
- process_runtime_go_mem_heap_idle
- process_runtime_go_mem_heap_idle_bytes
- process_runtime_go_mem_heap_inuse
- process_runtime_go_mem_heap_inuse_bytes
- process_runtime_go_mem_heap_objects
- process_runtime_go_mem_heap_released
- process_runtime_go_mem_heap_released_bytes
- process_start_time_seconds
- runtime_uptime
- runtime_uptime_milliseconds_total
- up
Changelog
Cost
By connecting your Go instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
