GitHub integration for Grafana Cloud
GitHub is a provider of Internet hosting for software development and version control using Git.
This integration includes 2 pre-built dashboards to help monitor and visualize GitHub metrics.
Before you begin
It is advised that you provide a GitHub personal access token so that the API ratelimit is not reached prematurely.
We strongly recommend that you give it only the strictly mandatory security privileges necessary for monitoring your repositories, which are all read-only, as per the official documentation.
Install GitHub integration for Grafana Cloud
- Find GitHub and click its tile to open the integration.
- Review the prerequisites in the Configuration Details tab and set up Grafana Agent to send GitHub metrics to your Grafana Cloud instance.
- Click Install to add this integration’s pre-built dashboards to your Grafana Cloud instance, and you can start monitoring your GitHub setup.
Advanced mode
To instruct Grafana Alloy to scrape your GitHub instances, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
prometheus.exporter.github "integrations_github_exporter" {
repositories = ["grafana/agent"]
api_token = "<your github api token>"
discovery.relabel "integrations_github_exporter" {
targets = prometheus.exporter.github.integrations_github_exporter.targets
rule {
target_label = "instance"
replacement = constants.hostname
rule {
target_label = "job"
replacement = "integrations/github_exporter"
prometheus.scrape "integrations_github_exporter" {
targets = discovery.relabel.integrations_github_exporter.output
job_name = "integrations/github_exporter"
This integrations uses the prometheus.exporter.github component to generate metrics from a GitHub instance.
In the agent configuration file, you must specify the repositories for which you wish to collect statistics. This can be a combination of specifying entire orgs, or users, and listing repositories explicitly. We also recommend that you use the api_token_file
parameter to avoid setting the authentication token directly on the agent config file.
For the full array of configuration options, refer to the prometheus.exporter.github component reference documentation.
This exporter must be linked with a discovery.relabel component to apply the necessary relabelings.
For each GitHub instance to be monitored you must create a pair of these components.
component:
instance
label:constants.hostname
sets theinstance
label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this GitHub instance.
You can then scrape them by including each discovery.relabel
under targets
within the prometheus.scrape component.
Post-install configuration for the GitHub integration
This integration is configured to work with the Github exporter
, which is embedded in the Grafana Agent.
Enable the integration by adding the provided snippet to your agent configuration file.
For a full description of configuration options see how to configure the github_exporter_config
block in the agent documentation.
Below integrations
github_exporter:
enabled: true
api_token: '<your github api token>'
repositories:
- grafana/agent
relabel_configs:
- replacement: '<your-instance-name>'
target_label: instance
Refer to the following Grafana Agent configuration for a complete example that contains all the snippets used for the GitHub integration. This example also includes metrics that are sent to monitor your Grafana Agent instance.
Dashboards
The GitHub integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- GitHub API Usage
- GitHub Repository Stats
Metrics
The most important metrics provided by the GitHub integration, which are used on the pre-built dashboards, are as follows:
- github_rate_limit
- github_rate_remaining
- github_repo_forks
- github_repo_open_issues
- github_repo_pull_request_count
- github_repo_size_kb
- github_repo_stars
- github_repo_watchers
- up
Changelog
# 1.0.0 - February 2024
* Update mixin to replace all Angular panels with React based panels.
# 0.0.5 - September 2023
* Update Grafana Agent configuration snippets to include filtered metrics used in gauge panels
# 0.0.4 - August 2023
# 0.0.3 - September 2022
* Update dashboard panels descriptions.
# 0.0.2 - October 2021
* Update mixin to latest version:
- Update the datasource template variable label to 'Data Source'
# 0.0.1 - August 2021
* Initial release
Cost
By connecting your GitHub instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
