title: "Gitea integration | Grafana Cloud documentation"
description: "Learn about Gitea Grafana Cloud integration."
# Gitea integration for Grafana Cloud
Gitea is an open-source forge software package for hosting software development version control using Git as well as other collaborative features like bug tracking, wikis and code review.
This integration provides the dashboard with metrics exposed by Gitea, including application’s key stats as well as CPU, memory, file descriptors utilization.
This integration includes 1 pre-built dashboard to help monitor and visualize Gitea metrics.
## Before you begin
In order for the integration to work, on Gitea instance you need to configure [metrics](https://docs.gitea.io/en-us/config-cheat-sheet/#metrics-metrics) section to enable /metrics endpoint:
ini ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```ini
[metrics]
ENABLED=true
In order to see issues stats grouped by repositores and labels, Gitea 1.16.0 or above is required with the following flags set:
```ini
[metrics]
ENABLED=true
ENABLED_ISSUE_BY_REPOSITORY=true
ENABLED_ISSUE_BY_LABEL=true
## Install Gitea integration for Grafana Cloud
1. In your Grafana Cloud stack, click **Connections** in the left-hand menu.
2. Find **Gitea** and click its tile to open the integration.
3. Review the prerequisites in the **Configuration Details** tab and set up Grafana Alloy to send Gitea metrics to your Grafana Cloud instance.
4. Click **Install** to add this integration’s pre-built dashboard to your Grafana Cloud instance, and you can start monitoring your Gitea setup.
## Configuration snippets for Grafana Alloy
### Simple mode
These snippets are configured to scrape a single Gitea instance running locally with default ports.
First, **manually** copy and append the following snippets into your alloy configuration file.
### Metrics snippets
Alloy ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```alloy
discovery.relabel "metrics_integrations_integrations_gitea" {
	targets = [{
		__address__ = "localhost:3000",
	rule {
		target_label = "instance"
prometheus.scrape "metrics_integrations_integrations_gitea" {
	targets    = discovery.relabel.metrics_integrations_integrations_gitea.output
	job_name   = "integrations/gitea"
### Advanced mode
To instruct Grafana Alloy to scrape your Gitea instances, **manually** copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
### Advanced metrics snippets
```alloy
	targets = [{
	rule {
To monitor your Gitea instance, you must use a [discovery.relabel](/docs/alloy/latest/reference/components/discovery.relabel/) component to discover your Gitea Prometheus endpoint and apply appropriate labels, followed by a [prometheus.scrape](/docs/alloy/latest/reference/components/prometheus.scrape) component to scrape it.
Configure the following properties within each `discovery.relabel` component:
- `__address__`: The address to your Gitea Prometheus metrics endpoint.
- `instance` label: `constants.hostname` sets the `instance` label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this Gitea instance.
If you have multiple Gitea servers to scrape, configure one `discovery.relabel` for each and scrape them by including each under `targets` within the `prometheus.scrape` component.
## Dashboards
The Gitea integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- Gitea Overview
**Gitea overview**
## Metrics
The most important metrics provided by the Gitea integration, which are used on the pre-built dashboard, are as follows:
- gitea\_issues\_by\_label
- gitea\_issues\_by\_repository
- gitea\_issues\_closed
- gitea\_issues\_open
- gitea\_milestones
- gitea\_organizations
- gitea\_releases
- gitea\_repositories
- gitea\_stars
- gitea\_teams
- gitea\_users
- process\_cpu\_seconds\_total
- process\_max\_fds
- process\_open\_fds
- process\_resident\_memory\_bytes
- process\_start\_time\_seconds
- up
## Changelog
md ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```md
# 1.0.0 - December 2025
* Chore: Fix incorrect semver to 1.0.0. No further changes
# 0.0.4 - September 2023
# 0.0.3 - September 2022
* Update dashboard panels descriptions.
# 0.0.2 - January 2022
* Update mixin to latest version:
  - fix dashboard templates to use `$datasource` variable
  - allow multiselect for job
# 0.0.1 - December 2021
* Initial release
## Cost
By connecting your Gitea instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see [Active series and dpm usage](/docs/grafana-cloud/fundamentals/active-series-and-dpm/) and [Cloud tier pricing](/products/cloud/pricing/).
