GCP Metrics integration for Grafana Cloud
Google Cloud Platform (GCP), offered by Google, is a suite of cloud computing services that runs on the same infrastructure that Google uses internally for its end-user products, such as Google Search, Gmail, Google Drive, and YouTube. Alongside a set of management tools, it provides a series of modular cloud services including computing, data storage, data analytics and machine learning.
The GCP Metrics integration enables you to send metrics from your GCP projects to Grafana Cloud.
This integration includes 1 pre-built dashboard to help monitor and visualize GCP Metrics metrics.
Before you begin
To export metrics from GCP, the Google Stackdriver Exporter is used. That exporter uses the Google Golang Client Library, which offers a variety of ways to provide credentials.
Please refer to the Google Application Default Credentials documentation to see how the credentials can be provided.
If you are using IAM roles, the roles/monitoring.viewer
IAM role contains the required permissions. See the Access Control Guide for more information.
If you are still using the legacy Access scopes, the https://www.googleapis.com/auth/monitoring.read
scope is required.
Install GCP Metrics integration for Grafana Cloud
- Find GCP Metrics and click its tile to open the integration.
- Review the prerequisites in the Configuration Details tab and set up Grafana Agent to send GCP Metrics metrics to your Grafana Cloud instance.
- Click Install to add this integration’s pre-built dashboard to your Grafana Cloud instance, and you can start monitoring your GCP Metrics setup.
Post-install configuration for the GCP Metrics integration
This integration is configured to work with the GCP metrics exporter, which is embedded in the Grafana Agent. Enable the integration by adding the code snippet in the above section to your agent configuration file.
Here’s the possible configuration values:
project_ids
Google Cloud project ID from where we want to scrape metrics from.
metrics_prefixes
Google Monitoring Metric Type prefixes. In configuration, you must specify the prefixes you want to scrape metrics from, each prefix represents a specific GCP resource, potentially followed by the metric types you want to scrape. These can be as targeted or loose as needed. As an example with pubsub metrics:
All metrics:
pubsub.googleapis.com/
All snapshot specific metrics:
pubsub.googleapis.com/snapshot
All snapshot specific metrics and a few subscription metrics:
pubsub.googleapis.com/subscription/num_undelivered_messages
pubsub.googleapis.com/subscription/oldest_unacked_message_age
extra_filters
Additional filters you can put on top of the metrics described above, to further refine the resources you would like to collect metrics from.
The structure for these filters is <targeted_metric_prefix>:<filter_query>
. The targeted_metric_prefix
is used to ensure the filter is only applied to the metric_prefix(es) where it makes sense.
metrics_prefixes = pubsub.googleapis.com/snapshot, pubsub.googleapis.com/subscription/num_undelivered_messages
targeted_metric_prefix options would be:
pubsub.googleapis.com (apply to all defined prefixes)
pubsub.googleapis.com/snapshot (apply to only snapshot metrics)
pubsub.googleapis.com/subscription (apply to only subscription metrics)
request_interval
The time range used when querying for metrics.
ingest_delay
Offset for the Google Monitoring Metrics interval into the past by the ingest delay from the metric metadata. When enabled this automatically adjusts the time range used when querying for metrics backwards based on the metadata GCP has published for how long the data can take to be ingested.
request_offset
Offset for the Google Monitoring Metrics interval into the past;
drop_delegated_projects
Drop metrics from attached projects and fetch project_id
only;
gcp_client_timeout
How long should the collector wait for a result from the API;
Below integrations
gcp_exporter:
enabled: true
project_ids:
- '<your-project>'
gcp_client_timeout: 15s
metrics_prefixes:
- run.googleapis.com/
- cloudfunctions.googleapis.com/
- compute.googleapis.com/nat
- logging.googleapis.com/billing
- logging.googleapis.com/exports
- serviceruntime.googleapis.com/quota/
- storage.googleapis.com/
- pubsub.googleapis.com/subscription
Refer to the following Grafana Agent configuration for a complete example that contains all the snippets used for the GCP Metrics integration. This example also includes metrics that are sent to monitor your Grafana Agent instance.
integrations:
prometheus_remote_write:
- basic_auth:
password: <your_prom_pass>
username: <your_prom_user>
url: <your_prom_url>
agent:
enabled: true
relabel_configs:
- action: replace
source_labels:
- agent_hostname
target_label: instance
- action: replace
target_label: job
metric_relabel_configs:
- action: keep
regex: (prometheus_target_.*|prometheus_sd_discovered_targets|agent_build.*|agent_wal_samples_appended_total|process_start_time_seconds)
source_labels:
- __name__
gcp_exporter:
enabled: true
project_ids:
- '<your-project>'
metrics_prefixes:
logs:
configs:
- clients:
- basic_auth:
password: <your_loki_pass>
username: <your_loki_user>
url: <your_loki_url>
positions:
filename: /tmp/positions.yaml
scrape_configs:
metrics:
configs:
- name: integrations
remote_write:
- basic_auth:
scrape_configs:
global:
scrape_interval: 60s
Dashboards
The GCP Metrics integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- GCP Metrics Overview
Overview
Changelog
# 0.0.1 - April 2023
* Initial release
Cost
By connecting your GCP Metrics instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
