Menu
GCP Logs integration for Grafana Cloud
Move your logs from GCP to Grafana Cloud using GCP Pub/Sub and the Grafana Agent
Are you interested in a version of this integration which allows you to skip setting up the agent? Consider filling out our form to be contacted in the future for Beta Access.
Before you begin
The GCP Logs integration is based on configuring the Grafana Agent to pull logs from a GCP Pub/Sub topic which contains your logs from GCP Cloud Monitoring. The logs are routed from cloud monitoring to pub/sub via customizable logging sink.
You will need to have the gcloud CLI installed and ensure you have roles pubsub.editor, and logging.configWriter to complete this setup
Setup Pubsub Topic
Google Pubsub Topic will act as the queue to persist log messages which then can be read from the agent.
bash
$ gcloud pubsub topics create $TOPIC_ID
e.g:
bash
$ gcloud pubsub topics create cloud-logs
Setup Log Sink
Next we create log sink to forward logs into pubsub topic created previously
bash
$ gcloud logging sinks create $SINK_NAME $SINK_LOCATION $OPTIONAL_FLAGS
e.g:
bash
$ gcloud logging sinks create cloud-logs pubsub.googleapis.com/projects/my-project/topics/cloud-logs \
--log-filter='resource.type=("gcs_bucket")' \
--description="Cloud logs"
Above command also adds log-filter option which represents what type of logs should get into the destination pubsub topic. For more information on adding log-filter refer this document
Grant log sink the pubsub publisher role
Find the writer identity service account of the log sink just created:
bash
gcloud logging sinks describe \
 --format='value(writerIdentity)' $SINK_NAME
For example:
bash
 --format='value(writerIdentity)' cloud-logs
Create an IAM policy binding to allow log sink to publish messages to the topic:
bash
gcloud pubsub topics add-iam-policy-binding $TOPIC_ID \
--member=$WRITER_IDENTITY --role=roles/pubsub.publisher
For example:
bash
gcloud pubsub topics add-iam-policy-binding cloud-logs \
--member=serviceAccount:pxxxxxxxxx-xxxxxx@gcp-sa-logging.iam.gserviceaccount.com --role=roles/pubsub.publisher
Create Pubsub subscription for Log Delivery
A subscription will be created for the pubsub topic configured above and the agent will use this subscription to consume log messages.
bash
$ gcloud pubsub subscriptions create cloud-logs --topic=$TOPIC_ID \
--ack-deadline=$ACK_DEADLINE \
--message-retention-duration=$RETENTION_DURATION \
e.g:
bash
$ gcloud pubsub subscriptions create cloud-logs --topic=projects/my-project/topics/cloud-logs \
--ack-deadline=10 \
--message-retention-duration=7d
For more fine grained options, refer to the gcloud pubsub subscriptions --help
Setup using Terraform
You also have the option of creating the required resources for GCP Log collection with terraform.
How to use Terraform is outside the scope of this guide. You can find this tutorial on how to work with Terraform and GCP useful.
terraform
// Provider module
provider "google" {
  project = "$GCP_PROJECT_ID"
// Topic
resource "google_pubsub_topic" "main" {
  name = "cloud-logs"
// Log sink
variable "inclusion_filter" {
  type        = string
  description = "Optional GCP Logs query which can filter logs being routed to the pub/sub topic and promtail"
resource "google_logging_project_sink" "main" {
  name                   = "cloud-logs"
  destination            = "pubsub.googleapis.com/${google_pubsub_topic.main.id}"
  filter                 = var.inclusion_filter
  unique_writer_identity = true
resource "google_pubsub_topic_iam_binding" "log-writer" {
  topic = google_pubsub_topic.main.name
  role  = "roles/pubsub.publisher"
  members = [
    google_logging_project_sink.main.writer_identity,
// Subscription
resource "google_pubsub_subscription" "main" {
  name  = "cloud-logs"
Then, to create the new resources run the snippet below after filling in the required variables.
bash
terraform apply \
    -var="inclusion_filter=<GCP Logs query of what logs to include>"
ServiceAccount for the agent
The agent will need to run with a service account that has the pubsub.subscriber permission.
This will enable the agent to read log entries from the pubsub subscription created before.
Install GCP Logs integration for Grafana Cloud
  1. In your Grafana Cloud stack, click Connections in the left-hand menu.
  2. Find GCP Logs and click its tile to open the integration.
  3. Review the prerequisites in the Configuration Details tab and set up Grafana Agent to send GCP Logs metrics and logs to your Grafana Cloud instance.
  4. Click Install to add this integration’s to your Grafana Cloud instance, and you can start monitoring your GCP Logs setup.
Post-install configuration for the GCP Logs integration
In the agent configuration file, find the placeholder <gcp_project_id> and <gcp_pubsub_subscription_name> names and replace them with the GCP project id and subscription name which was created in the pre-install steps.
Advanced configuration
The integration configuration found at logs.configs.scrape_configs can be modified further for more advanced usages. Some examples of those advanced scenarios are below.
Multiple Consumers Single Subscription
yaml
- gcplog:
    labels:
      job: integration/gcp
    project_id: project-1
    subscription: subscription-1
    subscription_type: pull
    use_incoming_timestamp: false
    job_name: integrations/gcp
    relabel_configs:
      - action: replace
        source_labels:
          - __gcp_logname
        target_label: logname
      - action: replace
        source_labels:
          - __gcp_resource_type
        target_label: resource_type
- gcplog:
    labels:
  job_name: integrations/gcp-2
  relabel_configs:
    - action: replace
      source_labels:
        - __gcp_logname
    - action: replace
      source_labels:
Multiple Subscriptions
yaml
- gcplog:
    labels:
  relabel_configs:
    - action: replace
      source_labels:
        - __gcp_logname
    - action: replace
      source_labels:
- gcplog:
    labels:
    subscription: subscription-2
  relabel_configs:
    - action: replace
      source_labels:
        - __gcp_logname
    - action: replace
      source_labels:
Below logs.configs.scrape_configs, insert the following lines according to your environment.
yaml
    - gcplog:
        project_id: <gcp_project_id>
        subscription: <gcp_pubsub_subscription_name>
        labels:
      relabel_configs:
        - action: replace
          source_labels:
            - __gcp_logname
        - action: replace
          source_labels:
Refer to the following Grafana Agent configuration for a complete example that contains all the snippets used for the GCP Logs integration. This example also includes metrics that are sent to monitor your Grafana Agent instance.
yaml
integrations:
  prometheus_remote_write:
  - basic_auth:
      password: <your_prom_pass>
      username: <your_prom_user>
    url: <your_prom_url>
  agent:
    enabled: true
    relabel_configs:
    - action: replace
      source_labels:
      - agent_hostname
      target_label: instance
    - action: replace
      target_label: job
    metric_relabel_configs:
    - action: keep
      regex: (prometheus_target_.*|prometheus_sd_discovered_targets|agent_build.*|agent_wal_samples_appended_total|process_start_time_seconds)
      source_labels:
      - __name__
logs:
  configs:
  - clients:
    - basic_auth:
        password: <your_loki_pass>
        username: <your_loki_user>
      url: <your_loki_url>
    positions:
      filename: /tmp/positions.yaml
    scrape_configs:
    - gcplog:
        labels:
      relabel_configs:
        - action: replace
          source_labels:
            - __gcp_logname
        - action: replace
          source_labels:
metrics:
  configs:
  - name: integrations
    remote_write:
    - basic_auth:
    scrape_configs:
  global:
    scrape_interval: 60s
Changelog
md
# 0.0.2 - August 2023
# 0.0.1 - December 2022
* Initial Release
Cost
By connecting your GCP Logs instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
