title: "etcd integration | Grafana Cloud documentation"
description: "Learn about etcd Grafana Cloud integration."
# etcd integration for Grafana Cloud
etcd is a distributed key-value store that is designed for distributed systems. This integration enables Grafana Alloy to send metrics to Grafana Cloud along with a useful pre-built dashboard for visualization.
This integration includes 15 useful alerts and 1 pre-built dashboard to help monitor and visualize etcd metrics.
## Before you begin
etcd exposes a [Prometheus metrics endpoint](https://etcd.io/docs/current/metrics/) enabled by default.
## Install etcd integration for Grafana Cloud
1. In your Grafana Cloud stack, click **Connections** in the left-hand menu.
2. Find **etcd** and click its tile to open the integration.
3. Review the prerequisites in the **Configuration Details** tab and set up Grafana Alloy to send etcd metrics to your Grafana Cloud instance.
4. Click **Install** to add this integration’s pre-built dashboard and alerts to your Grafana Cloud instance, and you can start monitoring your etcd setup.
## Configuration snippets for Grafana Alloy
### Simple mode
These snippets are configured to scrape a single etcd instance running locally with default ports.
First, **manually** copy and append the following snippets into your alloy configuration file.
### Metrics snippets
Alloy ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```alloy
discovery.relabel "metrics_integrations_integrations_etcd" {
	targets = [{
		__address__ = "localhost:2379",
	rule {
		target_label = "instance"
prometheus.scrape "metrics_integrations_integrations_etcd" {
	targets    = discovery.relabel.metrics_integrations_integrations_etcd.output
	job_name   = "integrations/etcd"
### Advanced mode
To instruct Grafana Alloy to scrape your etcd instances, **manually** copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
### Advanced metrics snippets
```alloy
	targets = [{
	rule {
To monitor your etcd instance, you must use a [discovery.relabel](/docs/alloy/latest/reference/components/discovery.relabel/) component to discover your etcd Prometheus endpoint and apply appropriate labels, followed by a [prometheus.scrape](/docs/alloy/latest/reference/components/prometheus.scrape) component to scrape it.
Configure the following properties within each `discovery.relabel` component:
- `__address__`: The address to your etcd Prometheus metrics endpoint.
- `instance` label: `constants.hostname` sets the `instance` label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this etcd instance.
If you have multiple etcd servers to scrape, configure one `discovery.relabel` for each and scrape them by including each under `targets` within the `prometheus.scrape` component.
## Kubernetes instructions
Instructions for Kubernetes
### Before you begin with Kubernetes
These instructions assume the use of the Kubernetes Monitoring Helm chart.
Please see official [documentation](/docs/grafana-cloud/monitor-infrastructure/kubernetes-monitoring/configuration/helm-chart-config/) for the Helm chart deployment guide.
### Configuration snippets for Kubernetes Helm chart
To scrape etcd, modify your Kubernetes Monitoring Helm chart with these configuration snippets.
Replace any values between the angle brackets `<>` in the provided snippets with your desired configuration values.
#### Metrics snippets
```alloy
integrations:
  etcd:
    instances:
      - name: etcd
        labelSelectors:
          <etcd-pod-label>: <etcd-pod-label-value>
## Dashboards
The etcd integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- etcd
## Alerts
The etcd integration includes the following useful alerts:
Expand table
| Alert                              | Description        |
| etcdMembersDown                    | Critical: etcd cluster members are down.                                             |
| etcdInsufficientMembers            | Critical: etcd cluster has insufficient number of members.                           |
| etcdNoLeader                       | Critical: etcd cluster has no leader.                                                |
| etcdHighNumberOfLeaderChanges      | Warning: etcd cluster has high number of leader changes.                             |
| etcdHighNumberOfFailedGRPCRequests | Warning: etcd cluster has high number of failed grpc requests.                       |
| etcdHighNumberOfFailedGRPCRequests | Critical: etcd cluster has high number of failed grpc requests.                      |
| etcdGRPCRequestsSlow               | Critical: etcd grpc requests are slow                                                |
| etcdMemberCommunicationSlow        | Warning: etcd cluster member communication is slow.                                  |
| etcdHighNumberOfFailedProposals    | Warning: etcd cluster has high number of proposal failures.                          |
| etcdHighFsyncDurations             | Warning: etcd cluster 99th percentile fsync durations are too high.                  |
| etcdHighFsyncDurations             | Critical: etcd cluster 99th percentile fsync durations are too high.                 |
| etcdHighCommitDurations            | Warning: etcd cluster 99th percentile commit durations are too high.                 |
| etcdDatabaseQuotaLowSpace          | Critical: etcd cluster database is running full.                                     |
| etcdExcessiveDatabaseGrowth        | Warning: etcd cluster database growing very fast.                                    |
| etcdDatabaseHighFragmentationRatio | Warning: etcd database size in use is less than 50% of the actual allocated storage. |
## Metrics
The most important metrics provided by the etcd integration, which are used on the pre-built dashboard and Prometheus alerts, are as follows:
- etcd\_disk\_backend\_commit\_duration\_seconds\_bucket
- etcd\_disk\_wal\_fsync\_duration\_seconds\_bucket
- etcd\_mvcc\_db\_total\_size\_in\_bytes
- etcd\_mvcc\_db\_total\_size\_in\_use\_in\_bytes
- etcd\_network\_client\_grpc\_received\_bytes\_total
- etcd\_network\_client\_grpc\_sent\_bytes\_total
- etcd\_network\_peer\_received\_bytes\_total
- etcd\_network\_peer\_round\_trip\_time\_seconds\_bucket
- etcd\_network\_peer\_sent\_bytes\_total
- etcd\_network\_peer\_sent\_failures\_total
- etcd\_server\_has\_leader
- etcd\_server\_leader\_changes\_seen\_total
- etcd\_server\_proposals\_failed\_total
- etcd\_server\_quota\_backend\_bytes
- grpc\_server\_handled\_total
- grpc\_server\_handling\_seconds\_bucket
- grpc\_server\_started\_total
- process\_resident\_memory\_bytes
- up
## Changelog
md ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```md
# 1.0.0 - July 2025
* Update Kubernetes snippets to work with v2.x version of Grafana Monitoring Helm chart.
# 0.0.6 - September 2023
# 0.0.5 - July 2023
* Add Grafana Agent Operator configuration snippet to support etcd integration in the Kubernetes app
* Change panels to timeseries
* Style with sentence case
* Update alerts
  - Add new etcdDatabaseHighFragmentationRatio alert
# 0.0.4 - January 2023
* Update mixin to latest version:
  - Add missing summaries to alerts
  - Add lint config
# 0.0.3 - September 2022
  - Update the datasource template variable label to 'Data Source'
# 0.0.2 - October 2021
  - Fix job variable
  - Fix alerts descriptions
# 0.0.1 - October 2020
* Initial release
## Cost
By connecting your etcd instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see [Active series and dpm usage](/docs/grafana-cloud/fundamentals/active-series-and-dpm/) and [Cloud tier pricing](/products/cloud/pricing/).
