title: "ElasticSearch integration | Grafana Cloud documentation"
description: "Learn about ElasticSearch Grafana Cloud integration."
# ElasticSearch integration for Grafana Cloud
Elasticsearch is a search engine based on the Lucene library. It provides a distributed, multitenant-capable full-text search engine with an HTTP web interface and schema-free JSON documents.
This integration enables Grafana Alloy to send metrics to Grafana Cloud along with a useful pre-built dashboard for visualization.
This integration includes 1 pre-built dashboard to help monitor and visualize ElasticSearch metrics.
## Before you begin
This integration relies on a dedicated Elastic Search cluster running alongside Grafana Alloy. See the following sections for details.
We strongly recommend that you configure a separate user for Alloy, and give it only the strictly mandatory security privileges necessary for monitoring your node, as per the [official documentation](https://github.com/prometheus-community/elasticsearch_exporter#elasticsearch-7x-security-privileges).
## Install ElasticSearch integration for Grafana Cloud
1. In your Grafana Cloud stack, click **Connections** in the left-hand menu.
2. Find **ElasticSearch** and click its tile to open the integration.
3. Review the prerequisites in the **Configuration Details** tab and set up Grafana Alloy to send ElasticSearch metrics to your Grafana Cloud instance.
4. Click **Install** to add this integration’s pre-built dashboard to your Grafana Cloud instance, and you can start monitoring your ElasticSearch setup.
## Configuration snippets for Grafana Alloy
### Simple mode
These snippets are configured to scrape a single ElasticSearch instance running locally with default ports.
First, **manually** copy and append the following snippets into your alloy configuration file.
### Integrations snippets
Alloy ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```alloy
prometheus.exporter.elasticsearch "integrations_elasticsearch_exporter" { }
discovery.relabel "integrations_elasticsearch_exporter" {
	targets = prometheus.exporter.elasticsearch.integrations_elasticsearch_exporter.targets
	rule {
		target_label = "job"
		replacement  = "integrations/elasticsearch_exporter"
	rule {
		target_label = "instance"
prometheus.scrape "integrations_elasticsearch_exporter" {
	targets    = discovery.relabel.integrations_elasticsearch_exporter.output
	job_name   = "integrations/elasticsearch_exporter"
### Advanced mode
To instruct Grafana Alloy to scrape your ElasticSearch instances, **manually** copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
### Advanced integrations snippets
```alloy
	rule {
	rule {
This integrations uses the [prometheus.exporter.elasticsearch](/docs/alloy/latest/reference/components/prometheus.exporter.elasticsearch/) component to generate metrics from a ElasticSearch instance.
Set the `address` argument to the address of your ElasticSearch instance.
For the full array of configuration options, refer to the [prometheus.exporter.elasticsearch](/docs/alloy/latest/reference/components/prometheus.exporter.elasticsearch/) component reference documentation.
This exporter must be linked with a [discovery.relabel](/docs/alloy/latest/reference/components/discovery.relabel/) component to apply the necessary relabelings.
For each ElasticSearch instance to be monitored you must create a pair of these components.
Configure the following properties within each `discovery.relabel` component:
- `instance` label: `constants.hostname` sets the `instance` label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this ElasticSearch instance.
You can then scrape them by including each `discovery.relabel` under `targets` within the [prometheus.scrape](/docs/alloy/latest/reference/components/prometheus.scrape/) component.
## Dashboards
The ElasticSearch integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- ElasticSearch Overview
## Metrics
The most important metrics provided by the ElasticSearch integration, which are used on the pre-built dashboard, are as follows:
- elasticsearch\_breakers\_estimated\_size\_bytes
- elasticsearch\_breakers\_limit\_size\_bytes
- elasticsearch\_breakers\_tripped
- elasticsearch\_cluster\_health\_active\_primary\_shards
- elasticsearch\_cluster\_health\_active\_shards
- elasticsearch\_cluster\_health\_delayed\_unassigned\_shards
- elasticsearch\_cluster\_health\_initializing\_shards
- elasticsearch\_cluster\_health\_number\_of\_data\_nodes
- elasticsearch\_cluster\_health\_number\_of\_nodes
- elasticsearch\_cluster\_health\_number\_of\_pending\_tasks
- elasticsearch\_cluster\_health\_relocating\_shards
- elasticsearch\_cluster\_health\_status
- elasticsearch\_cluster\_health\_unassigned\_shards
- elasticsearch\_filesystem\_data\_available\_bytes
- elasticsearch\_filesystem\_data\_size\_bytes
- elasticsearch\_indices\_docs
- elasticsearch\_indices\_docs\_deleted
- elasticsearch\_indices\_docs\_primary
- elasticsearch\_indices\_fielddata\_evictions
- elasticsearch\_indices\_fielddata\_memory\_size\_bytes
- elasticsearch\_indices\_filter\_cache\_evictions
- elasticsearch\_indices\_flush\_time\_seconds
- elasticsearch\_indices\_flush\_total
- elasticsearch\_indices\_get\_exists\_time\_seconds
- elasticsearch\_indices\_get\_exists\_total
- elasticsearch\_indices\_get\_missing\_time\_seconds
- elasticsearch\_indices\_get\_missing\_total
- elasticsearch\_indices\_get\_time\_seconds
- elasticsearch\_indices\_get\_tota
- elasticsearch\_indices\_indexing\_delete\_time\_seconds\_total
- elasticsearch\_indices\_indexing\_delete\_total
- elasticsearch\_indices\_indexing\_index\_time\_seconds\_total
- elasticsearch\_indices\_indexing\_index\_total
- elasticsearch\_indices\_merges\_docs\_total
- elasticsearch\_indices\_merges\_total
- elasticsearch\_indices\_merges\_total\_size\_bytes\_total
- elasticsearch\_indices\_merges\_total\_time\_seconds\_total
- elasticsearch\_indices\_query\_cache\_evictions
- elasticsearch\_indices\_query\_cache\_memory\_size\_bytes
- elasticsearch\_indices\_refresh\_time\_seconds\_total
- elasticsearch\_indices\_refresh\_total
- elasticsearch\_indices\_search\_fetch\_time\_seconds
- elasticsearch\_indices\_search\_fetch\_total
- elasticsearch\_indices\_search\_query\_time\_seconds
- elasticsearch\_indices\_search\_query\_total
- elasticsearch\_indices\_segment\_doc\_values\_memory\_bytes\_primary
- elasticsearch\_indices\_segment\_doc\_values\_memory\_bytes\_total
- elasticsearch\_indices\_segment\_fields\_memory\_bytes\_primary
- elasticsearch\_indices\_segment\_fields\_memory\_bytes\_total
- elasticsearch\_indices\_segments\_count
- elasticsearch\_indices\_segments\_memory\_bytes
- elasticsearch\_indices\_store\_size\_bytes\_primary
- elasticsearch\_indices\_store\_size\_bytes\_total
- elasticsearch\_indices\_store\_throttle\_time\_seconds\_total
- elasticsearch\_indices\_translog\_operations
- elasticsearch\_indices\_translog\_size\_in\_bytes
- elasticsearch\_jvm\_gc\_collection\_seconds\_count
- elasticsearch\_jvm\_gc\_collection\_seconds\_sum
- elasticsearch\_jvm\_memory\_committed\_bytes
- elasticsearch\_jvm\_memory\_max\_bytes
- elasticsearch\_jvm\_memory\_pool\_peak\_used\_bytes
- elasticsearch\_jvm\_memory\_used\_bytes
- elasticsearch\_os\_load1
- elasticsearch\_os\_load15
- elasticsearch\_os\_load5
- elasticsearch\_process\_cpu\_percent
- elasticsearch\_process\_open\_files\_count
- elasticsearch\_thread\_pool\_active\_count
- elasticsearch\_thread\_pool\_completed\_count
- elasticsearch\_thread\_pool\_rejected\_count
- elasticsearch\_transport\_rx\_size\_bytes\_total
- elasticsearch\_transport\_tx\_size\_bytes\_total
- up
## Changelog
md ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```md
# 1.0.0 - February 2024
* Update mixin to replace all Angular panels with React based panels.
# 0.0.3 - August 2023
# 0.0.2 - September 2022
* Update mixin to latest version:
  - Update the datasource template variable label to 'Data Source'
# 0.0.1 - February 2021
* Initial release
## Cost
By connecting your ElasticSearch instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see [Active series and dpm usage](/docs/grafana-cloud/fundamentals/active-series-and-dpm/) and [Cloud tier pricing](/products/cloud/pricing/).
