title: "Docker integration | Grafana Cloud documentation"
description: "Learn about Docker Grafana Cloud integration."
# Docker integration for Grafana Cloud
Docker is a popular open-source platform that enables developers to create, deploy, and run applications in a virtualized environment called a container. It allows developers to package an application with all its dependencies, libraries, and other components required to run it, into a single container image. The Docker integration collects metrics and logs from a Docker instance and provides useful pre-built dashboards to monitor them.
This integration includes 2 pre-built dashboards to help monitor and visualize Docker metrics and logs.
## Before you begin
This integration uses Grafana Alloy Docker service discovery feature to identify and collect logs. To do this, it must have access to docker daemon. To give this access, add the “alloy” user to “docker” group with the following command:
![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```none
sudo usermod -a -G docker alloy
Elevated privileges are required to run cAdvisor in Grafana Alloy in standalone mode, See [cAdvisor documentation](https://github.com/google/cadvisor/blob/master/docs/running.md#standalone). After installing Grafana Alloy, you must give it elevated permissions. Follow the instructions below:
Open the systemctl unit file to change the user running Grafana Alloy process:
```none
sudo systemctl edit --full alloy.service
Change `User=alloy` to `User=root` and save the file.
Reload systemctl changes using:
```none
sudo systemctl daemon-reload
Then restart Grafana Alloy:
```none
sudo systemctl restart alloy.service
In order to successfully collect logs and test the integration connection, at least one container should be running in the docker engine.
## Install Docker integration for Grafana Cloud
1. In your Grafana Cloud stack, click **Connections** in the left-hand menu.
2. Find **Docker** and click its tile to open the integration.
3. Review the prerequisites in the **Configuration Details** tab and set up Grafana Alloy to send Docker metrics and logs to your Grafana Cloud instance.
4. Click **Install** to add this integration’s pre-built dashboards to your Grafana Cloud instance, and you can start monitoring your Docker setup.
## Configuration snippets for Grafana Alloy
### Simple mode
These snippets are configured to scrape a single Docker engine running locally with default ports.
**Manually** copy and append the following snippets into your Grafana Alloy configuration file.
### Integrations snippets
Alloy ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```alloy
prometheus.exporter.cadvisor "integrations_cadvisor" {
    docker_only = true
discovery.relabel "integrations_cadvisor" {
    targets = prometheus.exporter.cadvisor.integrations_cadvisor.targets
    rule {
        target_label = "job"
        replacement  = "integrations/docker"
    rule {
        target_label = "instance"
prometheus.scrape "integrations_cadvisor" {
    targets    = discovery.relabel.integrations_cadvisor.output
### Logs snippets
#### linux
```alloy
discovery.docker "logs_integrations_docker" {
    host             = "unix:///var/run/docker.sock"
    refresh_interval = "5s"
discovery.relabel "logs_integrations_docker" {
    targets = []
    rule {
    rule {
    rule {
        source_labels = ["__meta_docker_container_name"]
        regex         = "/(.*)"
        target_label  = "container"
    rule {
        source_labels = ["__meta_docker_container_log_stream"]
        target_label  = "stream"
loki.source.docker "logs_integrations_docker" {
    targets          = discovery.docker.logs_integrations_docker.targets
    forward_to       = [loki.write.grafana_cloud_loki.receiver]
    relabel_rules    = discovery.relabel.logs_integrations_docker.rules
### Advanced mode
To instruct Grafana Alloy to scrape your docker engine, go though the subsequent instructions.
The snippets provide examples to guide you through the configuration process.
First, **manually** copy and append the following snippets into your Grafana Alloy configuration file.
Then follow the instructions below to modify the necessary variables.
### Advanced integrations snippets
```alloy
    docker_only = true
    rule {
    rule {
Add a pair of [prometheus.exporter.cadvisor](/docs/alloy/latest/reference/components/prometheus.exporter.cadvisor) and [discovery.relabel](/docs/alloy/latest/reference/components/discovery.relabel) to your Grafana Alloy configuration to monitor a docker daemon.
For ease of use, the provided snippets sets the `instance` label to the hostname using the `constants.hostname` Agent Flow constant variable.
If you want to monitor more than one daemon running within the same host, set a different value for each to avoid `instance` label conflicts. You will also need to set the `docker_host` and `containerd_host` properties within `prometheus.exporter.cadvisor` for each daemon.
There is an array of options available within this component, like setting up tls connection, specific cgroup collection, amongst others.
Refer to [prometheus.exporter.cadvisor](/docs/alloy/latest/reference/components/prometheus.exporter.cadvisor/) in Grafana Alloy reference documentation for a complete description of the configuration options.
Finally, reference each `discovery.relabel` component within the `targets` property of the [prometheus.scrape](/docs/alloy/latest/reference/components/prometheus.scrape) component.
### Advanced logs snippets
#### linux
```alloy
    targets = []
    rule {
    rule {
    rule {
        regex         = "/(.*)"
    rule {
Add a group of [discovery.docker](/docs/alloy/latest/reference/components/discovery.docker/), [discovery.relabel](/docs/alloy/latest/reference/components/discovery.relabel/) and [loki.source.docker](/docs/alloy/latest/reference/components/loki.source.docker/) to your Grafana Alloy configuration to monitor a docker daemon.
If you want to monitor more than one daemon running within the same host, set a different value for each to avoid `instance` label conflicts. You will also need to set the `host` property within `discovery.docker` and `loki.source.docker` for each daemon.
Make sure that for each docker daemon you are monitoring the instance label is set to the same value within the `discovery.relabel` components collecting cadvisor metrics and the daemon logs.
## Dashboards
The Docker integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- Docker logs
- Docker overview
**Overview &amp; Compute**
**Logs**
## Metrics
The most important metrics provided by the Docker integration, which are used on the pre-built dashboards, are as follows:
- container\_cpu\_usage\_seconds\_total
- container\_fs\_reads\_total
- container\_fs\_usage\_bytes
- container\_fs\_writes\_total
- container\_last\_seen
- container\_memory\_usage\_bytes
- container\_network\_receive\_bytes\_total
- container\_network\_receive\_errors\_total
- container\_network\_receive\_packets\_dropped\_total
- container\_network\_transmit\_bytes\_total
- container\_network\_transmit\_errors\_total
- container\_network\_transmit\_packets\_dropped\_total
- container\_spec\_memory\_reservation\_limit\_bytes
- machine\_memory\_bytes
- machine\_scrape\_error
- up
## Changelog
md ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```md
# 1.4.0 - April 2026
* Update to latest mixin
* Fix alloy snippet regex accidentally dropping a required metric
  * Please note, Alloy config requires manual update with the new snippet
# 1.3.4 - December 2024
* Removes ID filter for containers
* Updates status version panel
# 1.3.3 - November 2024
* Update status panel check queries
# 1.3.2 - September 2024
* Mixin update:
  - Split DiskIO metric into reads/writes metrics
  - Legend improvements:
      - Add {{device}} to all disks signals
      - Add {{interface}} to all network signals
  - fix softmax=100 on CPU panel.
# 1.3.1 - August 2024
* Update mixin
* Add filter for root cgroup metrics
# 1.3.0 - July 2024
* Add asserts support
# 1.2.1 - June 2024
* Update pre instructions
# 1.2.0 - May 2024
* Mixin update:
  - Reworked panels based on commonlib
  - Added storage metrics
  - Added network errors/drops metrics
  - Updated logs dashboard
# 1.1.0 - January 2024
* Remove windows and darwin as supported platforms
  - For windows and darwin, the recommended integration to use now is docker-desktop
# 1.0.0 - January 2024
* Update mixin to remove deprecated angular panels
# 0.1.0 - September 2023
* Add updated status panels
# 0.0.8 - August 2023
# 0.0.7 - August 2023
# 0.0.6 - April 2023
* Add missing descriptions to panels
# 0.0.5 - November 2022
* Add integration status panel
# 0.0.4 - May 2022
* Update mixin to latest version:
  - Fix log line counts
# 0.0.3 - April 2022
* Add instructions for scraping docker logs
* Update integration to work with embedded Grafana agent Cadvisor
# 0.0.2 - April 2022
  - Update variable display names
  - Rename datasource to prometheus_datasource
  - Group by instance as well on disk usage
  - Fix total images / containers showing up as double
  - Add integration status panels
  - Convert to gridpos
  - Remove deprecated singlestat panel
  - Disable shared tooltip
# 0.0.1 - October 2020
* Initial release
## Cost
By connecting your Docker instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see [Active series and dpm usage](/docs/grafana-cloud/fundamentals/active-series-and-dpm/) and [Cloud tier pricing](/products/cloud/pricing/).
