title: "OpenTelemetry Collector integration | Grafana Cloud documentation"
description: "Learn about OpenTelemetry Collector Grafana Cloud integration."
# OpenTelemetry Collector integration for Grafana Cloud
The OpenTelemetry Collector integration offers prebuilt dashboards and alerts based on the [OpenTelemetry Collector internal telemetry](https://opentelemetry.io/docs/collector/internal-telemetry/).
This integration includes 4 useful alerts and 1 pre-built dashboard to help monitor and visualize OpenTelemetry Collector metrics, traces.
## Dashboards
The OpenTelemetry Collector integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- Collector overview
**Collector overview**
**Receiver and processor statistics**
**Exporter statistics and process uptime**
## Alerts
The OpenTelemetry Collector integration includes the following useful alerts:
Expand table
| Alert                  | Description                                     |
| ExporterQueueSaturated | Warning: Exporter queue is reaching limit.      |
| MetricsFailedToSend    | Critical: Failed to enqueue metrics for export. |
| LogsFailedToSend       | Critical: Failed to enqueue logs for export.    |
| SpansFailedToSend      | Critical: Failed to enqueue spans for export.   |
## Metrics
The most important metrics provided by the OpenTelemetry Collector integration, which are used on the pre-built dashboard and Prometheus alerts, are as follows:
- otelcol\_exporter\_enqueue\_failed\_log\_records\_total
- otelcol\_exporter\_enqueue\_failed\_metric\_points\_total
- otelcol\_exporter\_enqueue\_failed\_spans\_total
- otelcol\_exporter\_queue\_capacity
- otelcol\_exporter\_queue\_size
- otelcol\_exporter\_send\_failed\_log\_records\_total
- otelcol\_exporter\_send\_failed\_metric\_points\_total
- otelcol\_exporter\_send\_failed\_spans\_total
- otelcol\_exporter\_sent\_log\_records\_total
- otelcol\_exporter\_sent\_metric\_points\_total
- otelcol\_exporter\_sent\_spans\_total
- otelcol\_process\_cpu\_seconds\_total
- otelcol\_process\_memory\_rss\_bytes
- otelcol\_process\_uptime\_seconds\_total
- otelcol\_processor\_incoming\_items\_total
- otelcol\_processor\_outgoing\_items\_total
- otelcol\_receiver\_accepted\_log\_records\_total
- otelcol\_receiver\_accepted\_metric\_points\_total
- otelcol\_receiver\_accepted\_spans\_total
- otelcol\_receiver\_refused\_log\_records\_total
- otelcol\_receiver\_refused\_metric\_points\_total
- otelcol\_receiver\_refused\_spans\_total
- up
## Changelog
md ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```md
# 1.0.0 - March 2026
* Initial release
## Cost
By connecting your OpenTelemetry Collector instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see [Active series and dpm usage](/docs/grafana-cloud/fundamentals/active-series-and-dpm/) and [Cloud tier pricing](/products/cloud/pricing/).
