title: "CockroachDB integration | Grafana Cloud documentation"
description: "Learn about CockroachDB Grafana Cloud integration."
# CockroachDB integration for Grafana Cloud
CockroachDB is a cloud-native SQL database for building global, scalable cloud services that survive disasters.
This integration includes 8 useful alerts and 4 pre-built dashboards to help monitor and visualize CockroachDB metrics.
## Before you begin
CockroachDB exposes a [Prometheus metrics endpoint](https://www.cockroachlabs.com/docs/stable/prometheus-endpoint) that is enabled by default.
## Install CockroachDB integration for Grafana Cloud
1. In your Grafana Cloud stack, click **Connections** in the left-hand menu.
2. Find **CockroachDB** and click its tile to open the integration.
3. Review the prerequisites in the **Configuration Details** tab and set up Grafana Alloy to send CockroachDB metrics to your Grafana Cloud instance.
4. Click **Install** to add this integration’s pre-built dashboards and alerts to your Grafana Cloud instance, and you can start monitoring your CockroachDB setup.
## Configuration snippets for Grafana Alloy
### Simple mode
These snippets are configured to scrape a single CockroachDB instance running locally with default ports.
First, **manually** copy and append the following snippets into your alloy configuration file.
### Metrics snippets
Alloy ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```alloy
discovery.relabel "metrics_integrations_integrations_cockroachdb" {
	targets = [{
		__address__ = "localhost:8080",
		cluster     = "cloud",
	rule {
		target_label = "instance"
prometheus.scrape "metrics_integrations_integrations_cockroachdb" {
	targets      = discovery.relabel.metrics_integrations_integrations_cockroachdb.output
	forward_to   = [prometheus.remote_write.metrics_service.receiver]
	job_name     = "integrations/cockroachdb"
	metrics_path = "/_status/vars"
### Advanced mode
To instruct Grafana Alloy to scrape your CockroachDB instances, **manually** copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
### Advanced metrics snippets
```alloy
	targets = [{
		cluster     = "cloud",
	rule {
To monitor your CockroachDB instance, you must use a [discovery.relabel](/docs/alloy/latest/reference/components/discovery.relabel/) component to discover your CockroachDB Prometheus endpoint and apply appropriate labels, followed by a [prometheus.scrape](/docs/alloy/latest/reference/components/prometheus.scrape) component to scrape it.
Configure the following properties within each `discovery.relabel` component:
- `__address__`: The address to your CockroachDB Prometheus metrics endpoint.
- `instance` label: `constants.hostname` sets the `instance` label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this CockroachDB instance.
- `cluster`: If you are running on k8s, set this to your k8s cluster name
If you have multiple CockroachDB servers to scrape, configure one `discovery.relabel` for each and scrape them by including each under `targets` within the `prometheus.scrape` component.
## Kubernetes instructions
Instructions for Kubernetes
### Before you begin with Kubernetes
**Please note**: These instructions assume the use of the [Kubernetes Monitoring Helm chart](https://github.com/grafana/k8s-monitoring-helm)
### Configuration snippets for Kubernetes Helm chart
To scrape your CockroachDB instances, **manually** modify your Kubernetes Monitoring Helm chart with these configuration snippets.
Replace any values between the angle brackets `<>` in the provided snippets with your desired configuration values.
#### Metrics snippets
```alloy
alloy-metrics:
    extraConfig: |-
        discovery.kubernetes "cockroachdb" {
            role = "service"
            selectors {
                role  = "service"
                label = "<service label>=<service label value>"
        prometheus.scrape "cockroachdb" {
            targets    = discovery.kubernetes.cockroachdb.output
            forward_to = [prometheus.remote_write.grafana_cloud_metrics.receiver]
## Dashboards
The CockroachDB integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- Cockroach Replicas
- Cockroach Runtime
- Cockroach SQL
- Cockroach Storage
**CockroachDB Replicas - 1**
**CockroachDB Runtime - 1**
**CockroachDB Storage - 1**
## Alerts
The CockroachDB integration includes the following useful alerts:
Expand table
| Alert                      | Description                                                           |
| CockroachInstanceFlapping  | Warning: CockroachDB instances have restarted in the last 10 minutes. |
| CockroachLivenessMismatch  | Warning: CockroachDB has liveness mismatches.                         |
| CockroachVersionMismatch   | Warning: CockroachDB cluster is running different versions.           |
| CockroachStoreDiskLow      | Critical: CockroachDB is at low disk capacity.                        |
| CockroachClusterDiskLow    | Critical: CockroachDB cluster is at critically low disk capacity.     |
| CockroachUnavailableRanges | Critical: CockroachDB has unavailable ranges.                         |
| CockroachNoLeaseRanges     | Warning: CockroachDB has ranges without leases.                       |
| CockroachHighOpenFDCount   | Warning: CockroachDB has too many open file descriptors.              |
## Metrics
The most important metrics provided by the CockroachDB integration, which are used on the pre-built dashboards and Prometheus alerts, are as follows:
- :cockroachdb\_capacity\_available:ratio
- build\_timestamp
- capacity
- capacity\_available
- capacity\_reserved
- clock\_offset\_meannanos
- cluster:cockroachdb\_capacity:sum
- cluster:cockroachdb\_capacity\_available:ratio
- cluster:cockroachdb\_capacity\_available:sum
- cockroachdb\_build\_timestamp
- cockroachdb\_capacity
- cockroachdb\_capacity\_available
- cockroachdb\_liveness\_livenodes
- cockroachdb\_ranges\_unavailable
- cockroachdb\_replicas\_leaders\_not\_leaseholders
- cockroachdb\_sys\_fd\_open
- cockroachdb\_sys\_fd\_softlimit
- cockroachdb\_sys\_uptime
- keybytes
- livebytes
- liveness\_livenodes
- node:cockroachdb\_capacity:sum
- node:cockroachdb\_capacity\_available:sum
- raft\_process\_commandcommit\_latency\_bucket
- raft\_process\_logcommit\_latency\_bucket
- raft\_rocksdb\_block\_cache\_hits
- raft\_rocksdb\_block\_cache\_misses
- raft\_rocksdb\_num\_sstables
- raft\_rocksdb\_read\_amplification
- raftlog\_behind
- raftlog\_selfbehind
- raftlog\_truncated
- range\_adds
- range\_removes
- range\_snapshots\_generated
- range\_snapshots\_normal\_applied
- range\_snapshots\_preemptive\_applied
- range\_splits
- ranges
- ranges\_unavailable
- ranges\_underreplicated
- rebalancing\_writespersecond
- replicas
- replicas\_leaders
- replicas\_leaders\_not\_leaseholders
- replicas\_leaseholders
- replicas\_quiescent
- replicas\_reserved
- rocksdb\_block\_cache\_hits
- rocksdb\_block\_cache\_misses
- rocksdb\_num\_sstables
- rocksdb\_read\_amplification
- round\_trip\_latency\_bucket
- sql\_bytesin
- sql\_bytesout
- sql\_conns
- sql\_ddl\_count
- sql\_delete\_count
- sql\_exec\_latency\_bucket
- sql\_insert\_count
- sql\_select\_count
- sql\_txn\_abort\_count
- sql\_txn\_begin\_count
- sql\_txn\_commit\_count
- sql\_txn\_rollback\_count
- sql\_update\_count
- sys\_cgo\_allocbytes
- sys\_cgo\_totalbytes
- sys\_cgocalls
- sys\_cpu\_sys\_ns
- sys\_cpu\_user\_ns
- sys\_fd\_open
- sys\_fd\_softlimit
- sys\_gc\_count
- sys\_gc\_pause\_ns
- sys\_go\_allocbytes
- sys\_go\_totalbytes
- sys\_goroutines
- sys\_rss
- sys\_uptime
- sysbytes
- up
- valbytes
## Changelog
md ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```md
# 1.0.0 - January 2024
* Updated dashboards to use new React based panels
* Fixed queries for histogram metrics to address panels showing "no data"
# 0.0.6 - September 2023
# 0.0.5 - May 2023
* Add summary and description to alerts to give better visibility of alerts at a glance
# 0.0.4 - February 2023
* Added Grafana Agent Operator configuration snippet to support CockroachDB in a kubernetes cluster.
# 0.0.3 - June 2022
* Add cluster label to agent config
* Rename `node` to `instance` to be consistent with other dashboards, and the prometheus scraping convention
* Add job matcher to all queries on all dashboards, with corresponding dashboard template variable
# 0.0.2 - October 2021
* Update all rate queries to use `$__rate_interval`, so they respect the default resolution
# 0.0.1 - December 2020
* Initial release
## Cost
By connecting your CockroachDB instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see [Active series and dpm usage](/docs/grafana-cloud/fundamentals/active-series-and-dpm/) and [Cloud tier pricing](/products/cloud/pricing/).
