title: "ClickHouse integration | Grafana Cloud documentation"
description: "Learn about ClickHouse Grafana Cloud integration."
# ClickHouse integration for Grafana Cloud
ClickHouse is an open-source column-oriented database management system that allows generating analytical data reports in real-time. This integration helps you monitor a ClickHouse cluster metrics and error logs, with an accompanying dashboard to visualize it.
This integration supports ClickHouse 22.6.8.35+.
This integration includes 4 useful alerts and 4 pre-built dashboards to help monitor and visualize ClickHouse metrics and logs.
## Before you begin
ClickHouse supports multi-file configurations using either a `/etc/clickhouse-server/config.xml` or `/etc/clickhouse-server/config.yaml`. This example shows `config.xml` snippets required to collect metrics and logs.
Prometheus metrics are generated using the [ClickHouse Prometheus instrumentation](https://clickhouse.com/docs/en/operations/server-configuration-parameters/settings#prometheus) that must be configured under the Global Server Settings, within the `config.xml` file. Some ClickHouse installations have these commented out, else include this snippet:
xml ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```xml
    <prometheus>
        <endpoint>/metrics</endpoint>
        <port>9363</port>
        <metrics>true</metrics>
        <events>true</events>
        <asynchronous_metrics>true</asynchronous_metrics>
        <status_info>true</status_info>
    </prometheus>
ClickHouse error logs are scraped using a Promtail agent that targets the default `/var/log/clickhouse-server/clickhouse-server.err.log` path. Logs are enabled by including the target path inside the `<errorlog>` within the `config.xml` file. Some ClickHouse installations have the error log set by default, which would be located at the top of the `config.xml` file.
```xml
    <logger>
        <errorlog>/var/log/clickhouse-server/clickhouse-server.err.log</errorlog>
    </logger>
For more information please check ClickHouse [logger settings](https://clickhouse.com/docs/en/operations/server-configuration-parameters/settings/#server_configuration_parameters-logger).
After editing the `config.xml` file, restart the ClickHouse server:
sh ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```sh
sudo service clickhouse-server restart
## Install ClickHouse integration for Grafana Cloud
1. In your Grafana Cloud stack, click **Connections** in the left-hand menu.
2. Find **ClickHouse** and click its tile to open the integration.
3. Review the prerequisites in the **Configuration Details** tab and set up Grafana Alloy to send ClickHouse metrics and logs to your Grafana Cloud instance.
4. Click **Install** to add this integration’s pre-built dashboards and alerts to your Grafana Cloud instance, and you can start monitoring your ClickHouse setup.
## Configuration snippets for Grafana Alloy
### Simple mode
These snippets are configured to scrape a single ClickHouse instance running locally with default ports.
First, **manually** copy and append the following snippets into your alloy configuration file.
### Metrics snippets
Alloy ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```alloy
discovery.relabel "metrics_integrations_integrations_clickhouse" {
	targets = [{
		__address__ = "localhost:9363",
	rule {
		target_label = "instance"
prometheus.scrape "metrics_integrations_integrations_clickhouse" {
	targets    = discovery.relabel.metrics_integrations_integrations_clickhouse.output
	job_name   = "integrations/clickhouse"
### Logs snippets
#### linux
```alloy
local.file_match "logs_integrations_integrations_clickhouse" {
	path_targets = [{
		__address__ = "localhost",
		__path__    = "/var/log/clickhouse-server/clickhouse-server.log",
		instance    = constants.hostname,
		job         = "integrations/clickhouse",
loki.process "logs_integrations_integrations_clickhouse" {
	forward_to = [loki.write.grafana_cloud_loki.receiver]
	stage.multiline {
		firstline     = "^([\\d]{4}).([\\d]{1,2}).([\\d]{1,2}) (([\\d]+):([\\d]+):([\\d]+).([\\d]+))"
		max_lines     = 0
		max_wait_time = "3s"
	stage.regex {
		expression = `(?P<timestamp>([\d]{4}).([\d]{1,2}).([\d]{1,2}) (([\d]+):([\d]+):([\d]+).([\d]+))) \[ (?P<thread_id>\d+) \] \{(?P<query_id>.*)\} <(?P<level>.+?)> (?P<message>(?s:.*))$`
	stage.labels {
		values = {
			level = null,
loki.source.file "logs_integrations_integrations_clickhouse" {
	targets    = local.file_match.logs_integrations_integrations_clickhouse.targets
	forward_to = [loki.process.logs_integrations_integrations_clickhouse.receiver]
### Advanced mode
To instruct Grafana Alloy to scrape your ClickHouse instances, **manually** copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
### Advanced metrics snippets
```alloy
	targets = [{
	rule {
To monitor your ClickHouse instance, you must use a [discovery.relabel](/docs/alloy/latest/reference/components/discovery.relabel/) component to discover your ClickHouse Prometheus endpoint and apply appropriate labels, followed by a [prometheus.scrape](/docs/alloy/latest/reference/components/prometheus.scrape) component to scrape it.
Configure the following properties within each `discovery.relabel` component:
- `__address__`: The address to your ClickHouse Prometheus metrics endpoint.
- `instance` label: `constants.hostname` sets the `instance` label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this ClickHouse instance. Make sure this label value is the same for all telemetry data collected for this instance.
If you have multiple ClickHouse servers to scrape, configure one `discovery.relabel` for each and scrape them by including each under `targets` within the `prometheus.scrape` component.
### Advanced logs snippets
#### linux
```alloy
	path_targets = [{
	stage.multiline {
		max_lines     = 0
	stage.regex {
		expression = "(?P<timestamp>([\\d]{4}).([\\d]{1,2}).([\\d]{1,2}) (([\\d]+):([\\d]+):([\\d]+).([\\d]+))) \\[ \\d+ \\] \\{.*\\} <(?P<level>.+)> (?P<message>(?s:.*))$"
	stage.labels {
		values = {
			level = null,
To monitor your ClickHouse instance logs, you will use a combination of the following components:
- [local.file\_match](/docs/alloy/latest/reference/components/local.file_match) defines where to find the log file to be scraped. Change the following properties according to your environment:
  - `__address__`: The ClickHouse instance address
  - `__path__`: The path to the log file.
- [loki.process](/docs/alloy/latest/reference/components/loki.process) defines how to process logs before sending it to Loki.
- [loki.source.file](/docs/alloy/latest/reference/components/loki.source.file) sends logs to Loki.
On Linux, you will also need to add the `alloy` user to the `clickhouse` group to get logs. Run the following command to configure the user as required:
```sh
sudo usermod -a -G clickhouse alloy
## Kubernetes instructions
Instructions for Kubernetes
### Before you begin with Kubernetes
**Please note**: These instructions assume the use of the [Kubernetes Monitoring Helm chart](https://github.com/grafana/k8s-monitoring-helm)
```xml
    <prometheus>
        <port>9363</port>
    </prometheus>
```xml
    <logger>
    </logger>
```sh
### Configuration snippets for Kubernetes Helm chart
To scrape your Clickhouse instances, **manually** modify your Kubernetes Monitoring Helm chart with these configuration snippets.
Replace any values between the angle brackets `<>` in the provided snippets with your desired configuration values.
#### Metrics snippets
```alloy
alloy-metrics:
    extraConfig: |-
        discovery.kubernetes "metrics_clickhouse" {
            role = "endpoints"
            selectors {
                role = "endpoints"
                label = "<endpoints label>=<endpoints label value>"
        discovery.relabel "metrics_clickhouse" {
            targets = discovery.kubernetes.metrics_clickhouse.targets
            rule {
                source_labels = ["__meta_kubernetes_endpoint_port_name"]
                regex = "<clickhouse service listening port>"
                action = "keep"
            rule {
                source_labels = ["__meta_kubernetes_pod_label_clickhouse_cluster"]
                target_label = "clickhouse_cluster"
            rule {
                source_labels = ["__meta_kubernetes_pod_name"]
        prometheus.scrape "metrics_clickhouse" {
            targets      = discovery.relabel.metrics_clickhouse.output
            honor_labels = true
            forward_to   = [prometheus.remote_write.grafana_cloud_metrics.receiver]
#### Logs snippets
```alloy
podLogs:
    extraDiscoveryRules: |-
        rule {
            source_labels = ["__meta_kubernetes_namespace", "__meta_kubernetes_pod_label_<your_clickhouse_pod_label_name>"]
            separator     = ":"
            regex         = "<your_clickhouse_namespace>:<your_clickhouse_pod_label_value>"
            replacement   = "clickhouse"
            target_label  = "integration"
    extraLogProcessingStages: |-
        stage.match {
            selector = "{integration=\\"clickhouse\\"}"
            stage.multiline {
                firstline     = \`^([\\d]{4}).([\\d]{1,2}).([\\d]{1,2}) (([\\d]+):([\\d]+):([\\d]+).([\\d]+))\`
                max_lines     = 0
                max_wait_time = "0s"
            stage.regex {
                expression = \`(?P<timestamp>([\\d]{4}).([\\d]{1,2}).([\\d]{1,2}) (([\\d]+):([\\d]+):([\\d]+).([\\d]+))) \\[ \\d+ \\] \\{.*\\} <(?P<level>.+)> (?P<message>(?s:.*))$\`
            stage.template {
                source   = "instance"
                template = "{{ .namespace }}-{{ .container }}"
            stage.labels {
                values = {
                    instance = "pod",
                    level = "",
            stage.static_labels {
                values = {
                    clickhouse_cluster = "<your_clickhouse_cluster_name>",
## Dashboards
The ClickHouse integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- ClickHouse latency
- ClickHouse logs
- ClickHouse overview
- ClickHouse replica
**ClickHouse Overview Dashboard 1**
**ClickHouse Overview Dashboard 2**
**ClickHouse Latency Dashboard**
## Alerts
The ClickHouse integration includes the following useful alerts:
Expand table
| Alert                               | Description                                                    |
| ClickHouseRejectedInserts           | Critical: ClickHouse has too many rejected inserts.            |
| ClickHouseReplicasInReadOnly        | Critical: ClickHouse has too many replicas in read only state. |
| ClickHouseReplicationQueueBackingUp | Warning: ClickHouse replica max queue size backing up.         |
| ClickHouseZookeeperSessions         | Critical: ClickHouse has too many Zookeeper sessions.          |
## Metrics
The most important metrics provided by the ClickHouse integration, which are used on the pre-built dashboards and Prometheus alerts, are as follows:
- ClickHouseAsyncMetrics\_OSMemoryTotal
- ClickHouseAsyncMetrics\_ReplicasMaxQueueSize
- ClickHouseMetrics\_HTTPConnection
- ClickHouseMetrics\_InterserverConnection
- ClickHouseMetrics\_MemoryTracking
- ClickHouseMetrics\_MySQLConnection
- ClickHouseMetrics\_PostgreSQLConnection
- ClickHouseMetrics\_ReadonlyReplica
- ClickHouseMetrics\_TCPConnection
- ClickHouseMetrics\_VersionInteger
- ClickHouseMetrics\_ZooKeeperRequest
- ClickHouseMetrics\_ZooKeeperSession
- ClickHouseMetrics\_ZooKeeperWatch
- ClickHouseProfileEvents\_AsyncInsertQuery
- ClickHouseProfileEvents\_DiskReadElapsedMicroseconds
- ClickHouseProfileEvents\_DiskWriteElapsedMicroseconds
- ClickHouseProfileEvents\_FailedInsertQuery
- ClickHouseProfileEvents\_FailedSelectQuery
- ClickHouseProfileEvents\_InsertQuery
- ClickHouseProfileEvents\_NetworkReceiveBytes
- ClickHouseProfileEvents\_NetworkReceiveElapsedMicroseconds
- ClickHouseProfileEvents\_NetworkSendBytes
- ClickHouseProfileEvents\_NetworkSendElapsedMicroseconds
- ClickHouseProfileEvents\_Query
- ClickHouseProfileEvents\_RejectedInserts
- ClickHouseProfileEvents\_ReplicatedPartChecks
- ClickHouseProfileEvents\_ReplicatedPartFetches
- ClickHouseProfileEvents\_ReplicatedPartMerges
- ClickHouseProfileEvents\_ReplicatedPartMutations
- ClickHouseProfileEvents\_SelectQuery
- ClickHouseProfileEvents\_ZooKeeperWaitMicroseconds
- up
## Changelog
md ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```md
# 1.1.0 - August 2024
* Add Asserts support
* Update mixin:
  - Add resolve delay for alerts
  - Fix dashboards' legends
  - Fix network panels
* Fix logs regex in the instructions
# 1.0.1 - July 2024
* Update instructions with the correct ClickHouse Prometheus instrumentation documentation link.
# 1.0.0 - November 2023
* Added Grafana Agent Operator configuration snippet to support Clickhouse in kubernetes cluster.
* Added cluster selector to dashboard for kubernetes support.
* Update Grafana Agent configuration snippets to include filtered metrics used in gauge panels.
# 0.1.2 - September 2023
# 0.1.1 - August 2023
* Add regex filter for logs datasource.
# 0.1.0 - July 2023
* Update logs
  * Move logs panel to separate dashboard.
  * Update agent logs snippet to extract level label and collect all logs.
# 0.0.2 - May 2023
* Update legends for latency metrics.
# 0.0.1 - February 2023
* Initial release.
## Cost
By connecting your ClickHouse instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see [Active series and dpm usage](/docs/grafana-cloud/fundamentals/active-series-and-dpm/) and [Cloud tier pricing](/products/cloud/pricing/).
