title: "Cert Manager integration | Grafana Cloud documentation"
description: "Learn about Cert Manager Grafana Cloud integration."
# Cert Manager integration for Grafana Cloud
cert-manager is a native [Kubernetes](https://kubernetes.io/) certificate management controller. It can help with issuing certificates from a variety of sources, such as Let’s Encrypt, HashiCorp Vault, Venafi, a simple signing key pair, or self signed.
This integration includes 4 useful alerts and 1 pre-built dashboard to help monitor and visualize Cert Manager metrics.
## Before you begin
Cert-manager exposes a [prometheus metrics endpoint](https://cert-manager.io/docs/usage/prometheus-metrics/) that is enabled by default.
## Install Cert Manager integration for Grafana Cloud
1. In your Grafana Cloud stack, click **Connections** in the left-hand menu.
2. Find **Cert Manager** and click its tile to open the integration.
3. Review the prerequisites in the **Configuration Details** tab and set up Grafana Alloy to send Cert Manager metrics to your Grafana Cloud instance.
4. Click **Install** to add this integration’s pre-built dashboard and alerts to your Grafana Cloud instance, and you can start monitoring your Cert Manager setup.
## Configuration snippets for Grafana Alloy
### Simple mode
These snippets are configured to scrape a single Cert Manager instance running locally with default ports.
First, **manually** copy and append the following snippets into your alloy configuration file.
### Metrics snippets
Alloy ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```alloy
discovery.relabel "metrics_integrations_integrations_cert_manager" {
	targets = [{
		__address__ = "localhost:9402",
	rule {
		target_label = "instance"
prometheus.scrape "metrics_integrations_integrations_cert_manager" {
	targets    = discovery.relabel.metrics_integrations_integrations_cert_manager.output
	job_name   = "integrations/cert-manager"
### Advanced mode
To instruct Grafana Alloy to scrape your Cert Manager instances, **manually** copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
### Advanced metrics snippets
```alloy
	targets = [{
	rule {
To monitor your Cert Manager instance, you must use a [discovery.relabel](/docs/alloy/latest/reference/components/discovery.relabel/) component to discover your Cert Manager Prometheus endpoint and apply appropriate labels, followed by a [prometheus.scrape](/docs/alloy/latest/reference/components/prometheus.scrape) component to scrape it.
Configure the following properties within each `discovery.relabel` component:
- `__address__`: The address to your Cert Manager Prometheus metrics endpoint.
- `instance` label: `constants.hostname` sets the `instance` label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this Cert Manager instance.
If you have multiple Cert Manager servers to scrape, configure one `discovery.relabel` for each and scrape them by including each under `targets` within the `prometheus.scrape` component.
## Kubernetes instructions
Instructions for Kubernetes
### Before you begin with Kubernetes
These instructions assume the use of the Kubernetes Monitoring Helm chart.
Please see official [documentation](/docs/grafana-cloud/monitor-infrastructure/kubernetes-monitoring/configuration/helm-chart-config/) for the Helm chart deployment guide.
### Configuration snippets for Kubernetes Helm chart
To scrape your cert-manager instances, modify your Kubernetes Monitoring Helm chart with these configuration snippets.
Replace any values between the angle brackets `<>` in the provided snippets with your desired configuration values.
#### Metrics snippets
```alloy
integrations:
  cert-manager:
    instances:
      - name: cert-manager
        labelSelectors:
          <cert-manager-pod-label>: <cert-manager-pod-label-value>
## Dashboards
The Cert Manager integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- Cert Manager
## Alerts
The Cert Manager integration includes the following useful alerts:
**cert-manager**
Expand table
| Alert             | Description                                                               |
| CertManagerAbsent | Critical: Cert Manager has disappeared from Prometheus service discovery. |
**certificates**
Expand table
| CertManagerCertExpirySoon    | Warning: The cert is nearing expiry, it should have renewed over a week ago. |
| CertManagerCertNotReady      | Critical: The cert is not ready to serve traffic.                            |
| CertManagerHittingRateLimits | Critical: Cert manager hitting LetsEncrypt rate limits.                      |
## Metrics
The most important metrics provided by the Cert Manager integration, which are used on the pre-built dashboard and Prometheus alerts, are as follows:
- certmanager\_certificate\_expiration\_timestamp\_seconds
- certmanager\_certificate\_ready\_status
- certmanager\_clock\_time\_seconds
- certmanager\_controller\_sync\_call\_count
- certmanager\_http\_acme\_client\_request\_count
- certmanager\_http\_acme\_client\_request\_duration\_seconds\_count
- certmanager\_http\_acme\_client\_request\_duration\_seconds\_sum
- container\_cpu\_cfs\_periods\_total
- container\_cpu\_cfs\_throttled\_periods\_total
- container\_cpu\_usage\_seconds\_total
- container\_memory\_usage\_bytes
- container\_network\_receive\_bytes\_total
- container\_network\_transmit\_bytes\_total
- kube\_pod\_container\_resource\_limits\_cpu\_cores
- kube\_pod\_container\_resource\_limits\_memory\_bytes
- kube\_pod\_container\_resource\_requests\_cpu\_cores
- kube\_pod\_container\_resource\_requests\_memory\_bytes
- up
## Changelog
md ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```md
# 1.0.1 - July 2025
* Update Kubernetes snippets to work with v2.x version of Grafana Monitoring Helm chart.
# 1.0.0 - February 2024
* Update mixin to replace all Angular panels with React based panels.
# 0.0.5 - September 2023
# 0.0.4 - March 2023
* Enable cluster template variable
* Add support for kubernetes via Grafana Agent Operator
# 0.0.3 - June 2022
* Unify job name across instructions and alert definition
# 0.0.2 - October 2021
* Update to latest upstream mixin
* Update all rate queries to use `$__rate_interval`, so they respect the default resolution
# 0.0.1 - January 2021
* Initial release
## Cost
By connecting your Cert Manager instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see [Active series and dpm usage](/docs/grafana-cloud/fundamentals/active-series-and-dpm/) and [Cloud tier pricing](/products/cloud/pricing/).
