AWX integration for Grafana Cloud
AWX provides a web-based user interface, REST API, and task engine built on top of Ansible. It is one of the upstream projects for Red Hat Ansible Automation Platform.
This integration includes 1 pre-built dashboard to help monitor and visualize AWX metrics.
Before you begin
AWX exposes an endpoint with Prometheus metrics by default, but it is authenticated. You can use either basic authentication, or OAuth2 token based authentication, the last being preferred. You can read more about the prometheus metrics capabilities of AWX in the documentation.
Install AWX integration for Grafana Cloud
- Find AWX and click its tile to open the integration.
- Review the prerequisites in the Configuration Details tab and set up Grafana Agent to send AWX metrics to your Grafana Cloud instance.
- Click Install to add this integration’s pre-built dashboard to your Grafana Cloud instance, and you can start monitoring your AWX setup.
Advanced mode
To instruct Grafana Alloy to scrape your AWX instances, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
Advanced metrics snippets
discovery.relabel "metrics_integrations_integrations_awx" {
targets = [{
__address__ = "awx.hostname",
rule {
target_label = "instance"
replacement = constants.hostname
prometheus.scrape "metrics_integrations_integrations_awx" {
targets = discovery.relabel.metrics_integrations_integrations_awx.output
job_name = "integrations/awx"
metrics_path = "/api/v2/metrics/"
authorization {
type = "Bearer"
credentials = "<your OAuth2 token>"
To monitor your AWX instance, you must use a discovery.relabel component to discover your AWX Prometheus endpoint and apply appropriate labels, followed by a prometheus.scrape component to scrape it.
component:
__address__
: The address to your AWX Prometheus metrics endpoint.instance
label:constants.hostname
sets theinstance
label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this AWX instance.
You should instruct Grafana Agent to scrape only one AWX node in the cluster.
Post-install configuration for the AWX integration
After configuring your auth method, you should instruct Grafana Agent to scrape only one AWX node in the cluster.
AWX exposes a /api/v2/metrics
endpoint. To scrape it, add the provided snippet to your agent configuration file.
Make sure to change targets
and <your OAuth2 token>
in the snippet according to your environment.
- job_name: integrations/awx
bearer_token: '<your OAuth2 token>'
metrics_path: '/api/v2/metrics/'
relabel_configs:
- replacement: '<your-instance-name>'
target_label: instance
static_configs:
- targets: ['awx.hostname']
Refer to the following Grafana Agent configuration for a complete example that contains all the snippets used for the AWX integration. This example also includes metrics that are sent to monitor your Grafana Agent instance.
Dashboards
The AWX integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- AWX
AWX overview
Metrics
The most important metrics provided by the AWX integration, which are used on the pre-built dashboard, are as follows:
- awx_instance_capacity
- awx_instance_consumed_capacity
- awx_instance_cpu
- awx_instance_info
- awx_instance_launch_type_total
- awx_instance_memory
- awx_instance_status_total
- awx_inventories_total
- awx_license_instance_free
- awx_license_instance_total
- awx_organizations_total
- awx_projects_total
- awx_running_jobs_total
- awx_schedules_total
- awx_sessions_total
- awx_status_total
- awx_system_info
- awx_teams_total
- awx_users_total
- up
Changelog
# 1.0.0 - February 2024
* Update mixin to replace all Angular panels with React based panels.
# 0.0.3 - September 2023
# 0.0.2 - June 2022
* Update mixin to latest version:
- Allow multi-select of instance dashboard template variable
# 0.0.1 - February 2022
* Initial release
Cost
By connecting your AWX instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
