title: "AWX integration | Grafana Cloud documentation"
description: "Learn about AWX Grafana Cloud integration."
# AWX integration for Grafana Cloud
AWX provides a web-based user interface, REST API, and task engine built on top of Ansible. It is one of the upstream projects for Red Hat Ansible Automation Platform.
This integration includes 1 pre-built dashboard to help monitor and visualize AWX metrics.
## Before you begin
AWX exposes an endpoint with Prometheus metrics by default, but it is authenticated. You can use either basic authentication, or OAuth2 token based authentication, the last being preferred. You can read more about the prometheus metrics capabilities of AWX in the [documentation](https://docs.ansible.com/ansible-tower/latest/html/administration/metrics.html).
## Install AWX integration for Grafana Cloud
1. In your Grafana Cloud stack, click **Connections** in the left-hand menu.
2. Find **AWX** and click its tile to open the integration.
3. Review the prerequisites in the **Configuration Details** tab and set up Grafana Alloy to send AWX metrics to your Grafana Cloud instance.
4. Click **Install** to add this integration’s pre-built dashboard to your Grafana Cloud instance, and you can start monitoring your AWX setup.
## Configuration snippets for Grafana Alloy
### Advanced mode
To instruct Grafana Alloy to scrape your AWX instances, **manually** copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
### Advanced metrics snippets
Alloy ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```alloy
discovery.relabel "metrics_integrations_integrations_awx" {
	targets = [{
		__address__ = "awx.hostname",
	rule {
		target_label = "instance"
prometheus.scrape "metrics_integrations_integrations_awx" {
	targets      = discovery.relabel.metrics_integrations_integrations_awx.output
	forward_to   = [prometheus.remote_write.metrics_service.receiver]
	job_name     = "integrations/awx"
	metrics_path = "/api/v2/metrics/"
	authorization {
		type        = "Bearer"
		credentials = "<your OAuth2 token>"
To monitor your AWX instance, you must use a [discovery.relabel](/docs/alloy/latest/reference/components/discovery.relabel/) component to discover your AWX Prometheus endpoint and apply appropriate labels, followed by a [prometheus.scrape](/docs/alloy/latest/reference/components/prometheus.scrape) component to scrape it.
Configure the following properties within each `discovery.relabel` component:
- `__address__`: The address to your AWX Prometheus metrics endpoint.
- `instance` label: `constants.hostname` sets the `instance` label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this AWX instance.
You should instruct Alloy to scrape **only one AWX node** in the cluster.
## Dashboards
The AWX integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- AWX
**AWX overview**
## Metrics
The most important metrics provided by the AWX integration, which are used on the pre-built dashboard, are as follows:
- awx\_hosts\_total
- awx\_instance\_capacity
- awx\_instance\_consumed\_capacity
- awx\_instance\_cpu
- awx\_instance\_info
- awx\_instance\_launch\_type\_total
- awx\_instance\_memory
- awx\_instance\_status\_total
- awx\_inventories\_total
- awx\_job\_templates\_total
- awx\_license\_instance\_free
- awx\_license\_instance\_total
- awx\_organizations\_total
- awx\_projects\_total
- awx\_running\_jobs\_total
- awx\_schedules\_total
- awx\_sessions\_total
- awx\_status\_total
- awx\_system\_info
- awx\_teams\_total
- awx\_users\_total
- awx\_workflow\_job\_templates\_total
- up
## Changelog
md ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```md
# 1.0.0 - February 2024
* Update mixin to replace all Angular panels with React based panels.
# 0.0.3 - September 2023
# 0.0.2 - June 2022
* Update mixin to latest version:
  - Allow multi-select of instance dashboard template variable
# 0.0.1 - February 2022
* Initial release
## Cost
By connecting your AWX instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see [Active series and dpm usage](/docs/grafana-cloud/fundamentals/active-series-and-dpm/) and [Cloud tier pricing](/products/cloud/pricing/).
