title: "Asterisk integration | Grafana Cloud documentation"
description: "Learn about Asterisk Grafana Cloud integration."
# Asterisk integration for Grafana Cloud
Asterisk is a free and open source framework for building communications applications and is sponsored by Sangoma. Asterisk enables the creation of communication applications such as PBX (private branch exchange), VoIP (Voice over Internet Protocol), and conference servers. The Asterisk integration can monitor useful metrics and logs of an asterisk instance.
This integration includes 4 useful alerts and 2 pre-built dashboards to help monitor and visualize Asterisk metrics and logs.
## Before you begin
In order for this integration to work, you must enable the embedded [Prometheus exporter in Asterisk](https://wiki.asterisk.org/wiki/display/AST/Asterisk+18+Configuration_res_prometheus) to collect and expose Asterisk metrics. The embedded Prometheus exporter also requires the embedded [Asterisk HTTP server](https://docs.asterisk.org/Configuration/Core-Configuration/Asterisk-Builtin-mini-HTTP-Server/) to be [enabled](https://docs.asterisk.org/Configuration/Interfaces/Asterisk-Manager-Interface-AMI/Asynchronous-Javascript-Asterisk-Manager-AJAM/Setting-up-the-Asterisk-HTTP-server/).
When both the Asterisk HTTP server and Prometheus exporter are enabled - the metrics are exposed by default on the URL: `http://localhost:8088/metrics`
To enable logs collection, [logging to file](https://docs.asterisk.org/Configuration/Core-Configuration/Logging-Configuration/) must be enabled in asterisk configuration.
Sample res\_prometheus configuration `/etc/asterisk/prometheus.conf`
![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```none
[general]
enabled = yes
core_metrics_enabled = yes
uri = metrics
Sample http\_server configuration `/etc/asterisk/http.conf`
```none
[general]
enabled=yes
enablestatic=yes
bindaddr=0.0.0.0
bindport=8088
prefix=
sessionlimit=100
session_inactivity=30000
session_keep_alive=15000
Sample file logging configuration in `/etc/asterisk/logger.conf`
```none
[logfiles]
full => notice,warning,error,verbose,dtmf,fax
Once the configurations are updated, restart the Asterisk server with the following command: `sudo systemctl restart asterisk` Check the status of the Asterisk server: `sudo systemctl status asterisk` Then login to the Asterisk CLI to verify it’s running: `sudo asterisk -r`
The metrics should be exposed by the embedded Prometheus exporter on the URL `http:/localhost:8088/metrics`
## Install Asterisk integration for Grafana Cloud
1. In your Grafana Cloud stack, click **Connections** in the left-hand menu.
2. Find **Asterisk** and click its tile to open the integration.
3. Review the prerequisites in the **Configuration Details** tab and set up Grafana Alloy to send Asterisk metrics and logs to your Grafana Cloud instance.
4. Click **Install** to add this integration’s pre-built dashboards and alerts to your Grafana Cloud instance, and you can start monitoring your Asterisk setup.
## Configuration snippets for Grafana Alloy
### Simple mode
These snippets are configured to scrape a single Asterisk instance running locally with default ports.
First, **manually** copy and append the following snippets into your alloy configuration file.
### Metrics snippets
Alloy ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```alloy
discovery.relabel "metrics_integrations_integrations_asterisk_prom" {
	targets = [{
		__address__ = "localhost:8088",
	rule {
		target_label = "instance"
prometheus.scrape "metrics_integrations_integrations_asterisk_prom" {
	targets    = discovery.relabel.metrics_integrations_integrations_asterisk_prom.output
	job_name   = "integrations/asterisk-prom"
### Logs snippets
#### darwin
```alloy
local.file_match "logs_integrations_integrations_asterisk_logs" {
	path_targets = [{
		__address__ = "localhost",
		__path__    = "/var/log/asterisk/full",
		instance    = constants.hostname,
		job         = "integrations/asterisk-logs",
loki.source.file "logs_integrations_integrations_asterisk_logs" {
	targets    = local.file_match.logs_integrations_integrations_asterisk_logs.targets
	forward_to = [loki.write.grafana_cloud_loki.receiver]
#### linux
```alloy
	path_targets = [{
#### windows
```alloy
	path_targets = [{
### Advanced mode
To instruct Grafana Alloy to scrape your Asterisk instances, **manually** copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
### Advanced metrics snippets
```alloy
	targets = [{
	rule {
To monitor your Asterisk instance, you must use a [discovery.relabel](/docs/alloy/latest/reference/components/discovery.relabel/) component to discover your Asterisk Prometheus endpoint and apply appropriate labels, followed by a [prometheus.scrape](/docs/alloy/latest/reference/components/prometheus.scrape) component to scrape it.
Configure the following properties within each `discovery.relabel` component:
- `__address__`: The address to your Asterisk Prometheus metrics endpoint.
- `instance` label: `constants.hostname` sets the `instance` label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this Asterisk instance. Make sure this label value is the same for all telemetry data collected for this instance.
If you have multiple Asterisk servers to scrape, configure one `discovery.relabel` for each and scrape them by including each under `targets` within the `prometheus.scrape` component.
### Advanced logs snippets
#### darwin
```alloy
	path_targets = [{
To monitor your Asterisk instance logs, you will use a combination of the following components:
- [local.file\_match](/docs/alloy/latest/reference/components/local.file_match) defines where to find the log file to be scraped. Change the following properties according to your environment:
  - `__address__`: The Asterisk instance address
  - `__path__`: The path to the log file. Alloy also must be configured to collect logs from the `full` Asterisk log file as shown in the snippet.
- [loki.source.file](/docs/alloy/latest/reference/components/loki.source.file) sends logs to Loki.
#### linux
```alloy
	path_targets = [{
#### windows
```alloy
	path_targets = [{
## Dashboards
The Asterisk integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- Asterisk - Logs
- Asterisk - Overview
**Overview**
**Logs Overview**
**Channels Information**
## Alerts
The Asterisk integration includes the following useful alerts:
Expand table
| Alert                        | Description                                               |
| AsteriskRestarted            | Critical: Asterisk instance restarted in the last minute. |
| AsteriskReloaded             | Warning: Asterisk instance reloaded in the last minute.   |
| AsteriskHighScrapeTime       | Critical: Asterisk instance core high scrape time.        |
| AsteriskHighActiveCallsCount | Warning: Asterisk high active call count.                 |
## Metrics
The most important metrics provided by the Asterisk integration, which are used on the pre-built dashboards and Prometheus alerts, are as follows:
- asterisk\_bridges\_channels\_count
- asterisk\_bridges\_count
- asterisk\_calls\_count
- asterisk\_calls\_sum
- asterisk\_channels\_count
- asterisk\_channels\_duration\_seconds
- asterisk\_channels\_state
- asterisk\_core\_last\_reload\_seconds
- asterisk\_core\_properties
- asterisk\_core\_scrape\_time\_ms
- asterisk\_core\_uptime\_seconds
- asterisk\_endpoints\_channels\_count
- asterisk\_endpoints\_count
- up
## Changelog
md ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```md
# 1.0.0 - December 2025
* Chore: Fix incorrect semver to 1.0.0. No further changes
# 0.0.5 - September 2023
# 0.0.4 - August 2023
# 0.0.3 - February 2023
* Add missing units to panel
* Rename alert summaries based on linting standards
# 0.0.2 - June 2022
* Update mixin to latest version:
  - Fix job variable regex
# 0.0.1 - March 2022
* Initial release
## Cost
By connecting your Asterisk instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see [Active series and dpm usage](/docs/grafana-cloud/fundamentals/active-series-and-dpm/) and [Cloud tier pricing](/products/cloud/pricing/).
